  2. Announcements
  3. LAUNCH: upgrade waypoint menu
46 Posts 15 Posters 31.5k Views 5 Watching
  • Tony 13
    Tony 13
    Tony 13
    Hi
    I am getting the same problem on Firefox, but on Android is OK. any old route more than two waypoints long is not loading or failing.
    Tony
    • Reinhard-32
      Reinhard-32
      Reinhard-32
      I have tested MRA in at a Windows 10 computer with the chrome browser. I works but not smooth.
      Kindly regards
      Reinhard
      Montana 700i and Mac
        @Jack-van-Tilburg
        Tested your route both on MS Edge and Google Chrome, both load the routeplanner correctly and show the route. On chrome the loading took a little longer (a little strange, but nothing otherworldly) but the route loaded. How long have you waited? Do you see the blue web-loading bar on the top of your browser move at all?
        @Reinhard-32 thank you very much for this info. While I can't reproduce this myself this will help our developers in the search for a solution.
        Kind regards,
        Timo
        Steve Lynch
        Steve Lynch
        Steve Lynch
        @Timo-Martosatiman-MRA
        Tested on iOS iPAD Pro using Chrome and Safari.
        Existing Routes are not loading for Here Map.
        “RS6 Rykas Loop” is a Public Route
        https://www.myrouteapp.com/en/social/route/3937795?mode=share
        “RS6 Waterfall Walk Safe Route” is a Public Route.
        This is set to OpenStreetMap uses the Offroad mode
        Transport Mode is “by foot”
        This route does open immediately.
        https://www.myrouteapp.com/en/social/route/5224950?mode=share
        Same as above using the iOS MyRoute Application
        Samsung S10 5G using the App
        “RS6 Rykas Loop” opens in about 7 Seconds
        “RS6 Waterfall Walk Safe Route” opens instantly.
        MS Surface Pro 4
        “RS6 Rykas Loop” opens in about 7 Seconds.
        • MotorradTeam Mannheim
          I have tested MRA with WIN 10 and edge browser (version 94.0.992.38 (official build) (64-bit)). it works. Even the favorites are there.
          Tested with an "old" route with 143 waypoints over 3120km.
          (https://www.myrouteapp.com/de/social/route/4825168?mode=share)
          it works smooth
          It doesn't work with Firefox 92.01
          Markus
          • TorqueRider TorqueRider
            @Reinhard-32
            I wonder if there is a connection between the malfunction and the upgrade of the waypoint menu. 😞
            Steve 25
            Steve 25
            Steve 25
            @Jack-van-Tilburg said in LAUNCH: upgrade waypoint menu:
            @Reinhard-32
            I'm also unable to load any existing routes since this upgrade. I run MacBook Pro and Safari.
            • Steve Lynch
              Steve Lynch
              Steve Lynch
              #26
              Maybe this is Mac/iOS specific?
              That’s what my tests indicate?
              Update:
              Doesn’t affect MRA Navigation on iOS or Android for me.
              Steve 25 Reinhard-32 2 Replies Last reply
              • Steve Lynch Steve Lynch
                Update:
                Steve 25
                Steve 25
                Steve 25
                @Steve-Lynch said in LAUNCH: upgrade waypoint menu:
                I've just retested based on your comment (I have a MacBookPro and Safari). I downloaded Chrome and routes opened OK. So with a MacBook and Chrome it works for me. My preference is for Safari but can make it work until you guys come up with the full solution.
                • Richard Ward
                  Richard Ward
                  Richard Ward
                  Same issue here. Must be the connectivity to the database or hosting services. some form of announcement would be appreciated. I have some observer runs this week and I'd like to plan for them.
                    Update:
                    Reinhard-32
                    Reinhard-32
                    Reinhard-32
                    @Steve-Lynch For me as well. I think the problem is mainly Apple and safari browser related.
                    Kindly regards
                    Reinhard
                    Richard Ward 1 Reply Last reply
                    • Reinhard-32 Reinhard-32
                      Richard Ward
                      Richard Ward
                      Richard Ward
                      @Reinhard-32 said in LAUNCH: upgrade waypoint menu:
                      I just tested this and Safari works fine on Windows. All browsers fail in Mac OSX and iOS.
                      • Richard Ward Richard Ward
                        Reinhard-32
                        Reinhard-32
                        Reinhard-32
                        @Richard-Ward Just noticed that the old menues are back an the routes are working.
                        Kindly regards
                        Reinhard
                          Administrator
                          Hello everyone,
                          After working on this throughout the day we haven't been able to resolve it. Sadly, this meant pulling everything offline until tomorrow. I've adjusted the topic to reflect that sentiment.
                          Your routes should be working again with the "old" waypointmenu.
                          Kind regards,
                          Timo
                          • TorqueRider
                            I believe I once read that MRA has 300,000 users. And then it is quite sad that a bug is caused when a new function is introduced. Good pre-testing should prevent this. If things still go wrong, a decision must be taken quickly for a Roll-Back. Because, as mentioned, a large user base that is potentially duped.
                            • Jd Price
                              Jd Price
                              Jd Price
                              Saw the annct for the new Waypoint launch and was able to update my route with the new symbols before they went away.
                              LOVED IT! No issues, except the Gas icon seemed broken.
                              Apologies for the last minute ask, but would it be possible to add a 'Hotel' icon?
                              Thanks!
                              LOVE using the app on my Win10 computer. Then 'Save as' a gpx 1.1 file.
                              Transfers flawlessly to my Gold Wing nav system.
                                Administrator
                                Update Tuesday 10:20 AM:
                                We believe to have found a solution and have implemented it in our testing environment. If you experienced this problem and would like to help us and see if it is now resolved, please leave a reply on this thread. I'll mail you an access key to the testing environment.
                                TorqueRider David Bonner 2 Replies Last reply
                                • HABVEN aka MrMRA
                                  Works fine for me on Windows 10 and Chrome, even the speed is ok!
                                    @Timo-Martosatiman-MRA said in LAUNCH: upgrade waypoint menu:
                                    Hi Timo,
                                    I definitely want to help with testing.
                                      Administrator
                                      @Jack-van-Tilburg
                                      That'd be amazing, thank you!
                                      I have forwarded you the details to gain access to the testing environment.
                                        @Jack-van-Tilburg
                                        Tested and my (positive) findings in the chat sent to Timo.
                                          Administrator
                                          @Jack-van-Tilburg thank you so much. We've received other good feedback too and have confirmed that the update works on all devices. We're preparing to deploy the update again.
                                          • 3
                                          Pierre c
                                          Pierre c
                                          Reinhard-32
                                          Reinhard-32
                                          Tony 13
                                          Tony 13
                                          Steve 25
                                          Steve 25
                                          Steve Lynch
                                          Steve Lynch
                                          David Bonner
                                          David Bonner
                                          Richard Ward
                                          Richard Ward
                                          Jd Price
                                          Jd Price
                                          Emily 3
                                          Emily 3
                                          Lemons
                                          Lemons
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
