  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 11.4k Views 9 Watching
    @Rob-Verhoeff, Tip From Flip: check the time, look at the sun, no need to get off your bike ๐Ÿ˜‰
    @Con-Hennekens only works with no clouds ๐Ÿ˜‰
    ๐Ÿ’ป Routelab on MacBook Air & iMac (Golden Gate & Ventura)
      If the red segment did show the direction of travel, it would not be called a compass. A compass just shows where North is. I bet in about ten years people also cannot read analogue clocks anymore ๐Ÿ˜‰ To be honest, if we have to think about the direction of travel when we know where North is, knowing the direction of travel probably has little value at all.
      Maybe a green segment showing the direction of travel is an idea?
      Or indeed an extra ring showing N, E, S and W.
      #35
      @Con-Hennekens ring with N, S, E and W would be helpful or as the image I posted above.
      And the importance of direction or travel with using a compass: https://osmaps.com/discover/guides/a-beginners-guide-to-using-a-compass/
      Ducati Multistrada V4 Rally
      iPhone 18 Pro
      CHIGEE AIO-6 LTE
      Google Pixel 6 Pro
        @Con-Hennekens i agree! And wholeheartedly vote for the N, S, W, E marking on the segment ring.
        Personally, my map is oriented North, making the compass unnecessary. But during pracricing all the options i found this red segment confusing, thus i created this topic. Turns out i was not the only one. I am sure there are many more who are just silent or do not use the forum. So, hopefully something good will come out of it!
        • LennyO LennyO
          @LennyO, Remember that "North UP" does not show where North is whatsoever. It just indicates you are not holding the map upside down... ๐Ÿ˜‰
          LennyO 1 Reply Last reply
            ๐Ÿ˜ฐ
            What about #2 in this descripption:
            • LennyO LennyO
              ๐Ÿ˜ฐ
              @LennyO I think it should say: โ€œIn this camera mode, the map does not rotate with your direction of travel but always remains oriented toward the top of the map.โ€
              LennyO 2 Replies Last reply
                @Rob-Verhoeff Bravo! That would stop the confusion for everyone! And this change should be announced to all, as I suspect many people are confused to the point of being frustrated.... me included.
                  @nick-carthew Hi, Nick! Would you please assist in correcting the Manual. Thx!
                  • LennyO LennyO
                    @LennyO Iโ€™m not responsible for the manual and personally I think the wording is perfectly clear. The view is called โ€˜North upโ€™ and the definition in the manual says
                    โ€˜North will always be upโ€™ Iโ€™m unsure what part is unclear!
                      @Nick-Carthew Hi, Nick!
                      Sorry... i thought you are a part of the crew.
                      The issue is the fact that North will not always be up. I wish it was.
                      if you put the map in this orientation, you often see that the Red segment on the elevation circle is NOT pointing up, thus contradicting the manual.
                      Thank you!
                      • LennyO LennyO
                        Thank you!
                        Thank you!
                        @nick-carthew Nick, to clarify my previous post I should add - when you are in fact heading North on the map in North up orientation, the Red segment may be pointing somewhere else, but be at the 12 o'clock. And since the Red segment always shows where the North is there is a conflict in the definition in the manual.
                        • LennyO LennyO
                          Thank you!
                          @LennyO
                          Corjan is aware of the situation and although he doesnโ€™t reply to many forum posts he does read them.
                            @LennyO
                            I donโ€™t? ๐Ÿ˜ฎ
                              I donโ€™t? ๐Ÿ˜ฎ
                              @Corjan-Meijerink A direct contradiction ๐Ÿ˜‰
                              • LennyO LennyO
                                @LennyO, "North will always be up" in this context refers to the north of the map, not to the north pole ๐Ÿ˜‰
                                  I know the North Pole and North on the map are not exact the same. But considering the few segments of the compass, should then the north pole and north on the map be same?
                                    @M.-Schrijver, I don't think that makes it easier for most ๐Ÿ˜‰
                                    BertM 1 Reply Last reply
                                      ๐Ÿ™‚
                                      then this post goes from 50 to 500 ๐Ÿ˜‰
                                        #52
                                        @Con-Hennekens Ok, Con! I get it! Not the most intuitive implementation, but it is what it is....
                                        Having said that, I strongly feel that the manual needs to be updated to state what you and @rob-verhoeff are saying.
                                        Every GPS unit is actually North up if you select such an orientation.
                                        Who would ever deduce, reading the manual, that North does not really mean North when it clearly strates that " in the North Up camera vew ( map orientation ) North will always be up".
                                        When people read "North" they can not imagine that it means "North of the map"....
                                        And that includes myself, which caused a major confusion in my head.
                                        What's going on???? I see a discrepancy between what I thought was North and the Red segment! Re-check the manual. The manual says so, then the Red segment must be wrong, correct?
                                        This whoole thing could be easily resolved in two simple steps:
                                        1. Update the manual
                                        2. Put the N,E,S,W cardinal markings on the segmented circle.
                                          DONE!
                                          I am sure you would agree with that ๐Ÿ˜•
                                        Many people are having issues with this thing, so something needs to be done and hopefully soon.
                                        Thank you!
                                        • MotoCon
                                          @lennyo, In "North Up" North does not mean top, UP means top (of your phone, or paper map, or whatever). Projection of a map has really nothing to do with where North is. North Up is only about how you hold the map. I agree that adding E,S and W would help for some in that it obviously does not indicate your heading, but then again North will still not always point to the top of your phone ๐Ÿ˜‰
                                          • 4
                                          Stanisล‚aw
                                          Stanisล‚aw
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
