  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 11.4k Views 9 Watching
    In the current situation where the red bar shows north and the bar is on right side of the compass, you need do a conversion to conclude you are riding in west direction. When the red bar shows the direction you're heading. You instant know you're riding to the east.
    BMcG 1 Reply Last reply
      wrote on last edited by BMcG
      #29
      the app & display are doing exactly as designed / intended
      the issue is that in North Up mode you have to do the mental gymnastics that it shows 2 differing north at the same time 🙃
      I have to say I find 2 norths a slightly confusing concepts but it is easily resolved
      either use a different compass mode, I normally use dynamic so this is not a problem for me
      or turn of the altitude display completely, its not really important / relevant information
      & I would rather use the few brain cells I have on figuring out what is happening ahead of me on the road than deciding which north is real 😂
        I've never an old analogue compass at all. Maybe that is the reason why i think it is more logical that the red bar shows the direction your heading and north always is on top on the compass.
        If this view is used does the compass then also be more sensible in the North Up view?
        #30
        @M.-Schrijver ...that's the same idea like in the map, if you use the north up view 🙄
        • MotoCon
          If the red segment did show the direction of travel, it would not be called a compass. A compass just shows where North is. I bet in about ten years people also cannot read analogue clocks anymore 😉 To be honest, if we have to think about the direction of travel when we know where North is, knowing the direction of travel probably has little value at all.
          Maybe a green segment showing the direction of travel is an idea?
          Or indeed an extra ring showing N, E, S and W.
          Dave J 0 LennyO 2 Replies Last reply
          • Rob Verhoeff
            I usually get off my bike, find a tree, and check which side has the most moss growing on it!
              @Rob-Verhoeff, Tip From Flip: check the time, look at the sun, no need to get off your bike 😉
                @Con-Hennekens only works with no clouds 😉
                  #35
                  @Con-Hennekens ring with N, S, E and W would be helpful or as the image I posted above.
                  And the importance of direction or travel with using a compass: https://osmaps.com/discover/guides/a-beginners-guide-to-using-a-compass/
                  Ducati Multistrada V4 Rally
                  iPhone 18 Pro
                  CHIGEE AIO-6 LTE
                  Google Pixel 6 Pro
                    @Con-Hennekens i agree! And wholeheartedly vote for the N, S, W, E marking on the segment ring.
                    Personally, my map is oriented North, making the compass unnecessary. But during pracricing all the options i found this red segment confusing, thus i created this topic. Turns out i was not the only one. I am sure there are many more who are just silent or do not use the forum. So, hopefully something good will come out of it!
                    • LennyO LennyO
                      @LennyO, Remember that "North UP" does not show where North is whatsoever. It just indicates you are not holding the map upside down... 😉
                      LennyO 1 Reply Last reply
                        What about #2 in this descripption:
                        • LennyO LennyO
                          @LennyO I think it should say: “In this camera mode, the map does not rotate with your direction of travel but always remains oriented toward the top of the map.”
                            @Rob-Verhoeff Bravo! That would stop the confusion for everyone! And this change should be announced to all, as I suspect many people are confused to the point of being frustrated.... me included.
                              @nick-carthew Hi, Nick! Would you please assist in correcting the Manual. Thx!
                              • LennyO LennyO
                                @LennyO I’m not responsible for the manual and personally I think the wording is perfectly clear. The view is called ‘North up’ and the definition in the manual says
                                ‘North will always be up’ I’m unsure what part is unclear!
                                  @Nick-Carthew Hi, Nick!
                                  Sorry... i thought you are a part of the crew.
                                  The issue is the fact that North will not always be up. I wish it was.
                                  if you put the map in this orientation, you often see that the Red segment on the elevation circle is NOT pointing up, thus contradicting the manual.
                                  Thank you!
                                  • LennyO LennyO
                                    Thank you!
                                    Thank you!
                                    @nick-carthew Nick, to clarify my previous post I should add - when you are in fact heading North on the map in North up orientation, the Red segment may be pointing somewhere else, but be at the 12 o'clock. And since the Red segment always shows where the North is there is a conflict in the definition in the manual.
                                    • LennyO LennyO
                                      Thank you!
                                      @LennyO
                                      Corjan is aware of the situation and although he doesn’t reply to many forum posts he does read them.
                                        @LennyO
                                        I don’t? 😮
                                          I don’t? 😮
                                          @Corjan-Meijerink A direct contradiction 😉
                                          • 4
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
