  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 10.1k Views 9 Watching
  • Con Hennekens
    If the red segment did show the direction of travel, it would not be called a compass. A compass just shows where North is. I bet in about ten years people also cannot read analogue clocks anymore 😉 To be honest, if we have to think about the direction of travel when we know where North is, knowing the direction of travel probably has little value at all.
    Maybe a green segment showing the direction of travel is an idea?
    Or indeed an extra ring showing N, E, S and W.
    Dave J 0 LennyO 2 Replies Last reply
    • Rob Verhoeff
      I usually get off my bike, find a tree, and check which side has the most moss growing on it!
        @Rob-Verhoeff, Tip From Flip: check the time, look at the sun, no need to get off your bike 😉
          @Con-Hennekens only works with no clouds 😉
            #35
            @Con-Hennekens ring with N, S, E and W would be helpful or as the image I posted above.
            And the importance of direction or travel with using a compass: https://osmaps.com/discover/guides/a-beginners-guide-to-using-a-compass/
            Ducati Multistrada V4 Rally
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
              @Con-Hennekens i agree! And wholeheartedly vote for the N, S, W, E marking on the segment ring.
              Personally, my map is oriented North, making the compass unnecessary. But during pracricing all the options i found this red segment confusing, thus i created this topic. Turns out i was not the only one. I am sure there are many more who are just silent or do not use the forum. So, hopefully something good will come out of it!
              • LennyO LennyO
                @LennyO, Remember that "North UP" does not show where North is whatsoever. It just indicates you are not holding the map upside down... 😉
                LennyO 1 Reply Last reply
                  What about #2 in this descripption:
                  • LennyO LennyO
                    @LennyO I think it should say: “In this camera mode, the map does not rotate with your direction of travel but always remains oriented toward the top of the map.”
                      @Rob-Verhoeff Bravo! That would stop the confusion for everyone! And this change should be announced to all, as I suspect many people are confused to the point of being frustrated.... me included.
                        @nick-carthew Hi, Nick! Would you please assist in correcting the Manual. Thx!
                        • LennyO LennyO
                          @LennyO I’m not responsible for the manual and personally I think the wording is perfectly clear. The view is called ‘North up’ and the definition in the manual says
                          ‘North will always be up’ I’m unsure what part is unclear!
                            @Nick-Carthew Hi, Nick!
                            Sorry... i thought you are a part of the crew.
                            The issue is the fact that North will not always be up. I wish it was.
                            if you put the map in this orientation, you often see that the Red segment on the elevation circle is NOT pointing up, thus contradicting the manual.
                            Thank you!
                            • LennyO LennyO
                              Thank you!
                              Thank you!
                              @nick-carthew Nick, to clarify my previous post I should add - when you are in fact heading North on the map in North up orientation, the Red segment may be pointing somewhere else, but be at the 12 o'clock. And since the Red segment always shows where the North is there is a conflict in the definition in the manual.
                              • LennyO LennyO
                                Thank you!
                                @LennyO
                                Corjan is aware of the situation and although he doesn’t reply to many forum posts he does read them.
                                  @LennyO
                                  I don’t? 😮
                                    I don’t? 😮
                                    @Corjan-Meijerink A direct contradiction 😉
                                    • LennyO LennyO
                                      @LennyO, "North will always be up" in this context refers to the north of the map, not to the north pole 😉
                                        I know the North Pole and North on the map are not exact the same. But considering the few segments of the compass, should then the north pole and north on the map be same?
                                          @M.-Schrijver, I don't think that makes it easier for most 😉
                                          BertM 1 Reply Last reply
                                          • 4
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                          • Lock route editing
                                          • Opgeslagen routes met TOMTOM kaart laden niet meer.
                                          • Group ride
                                          • Laat bijbehorende POI zien
                                            Albert van den Elsen
                                          • Save locations/positions
                                          • How do you navigate off-road routes with Next?
                                          • MRA Routeplanner, Zumo XT and a list of waypoints
                                            2.6k
