  4. Volume too low
Volume too low
41 Posts 14 Posters 24.6k Views 7 Watching
    You can adjust this to some extend in the Cardo app (background volume).
    • M. Schrijver M. Schrijver
      @M-Schrijver Yes, thank you I have the app.
        @Hans-van-de-Ven-MR-MRA
        Yes, that may be the case with your setup, I was pointing out that not all issues with the volume are related to MRA Navigation Next. The volume for turn by turn instructions a notes is very loud when I don’t have an intercom connection.
        My devices and settings are different to yours and so we have a different experience. As far as I am concerned, the app volume is fine except when I am connected to another intercom. The same happens with my TomTom or Google Maps, turn by turn instructions cannot be heard when the intercom is connected but perfectly clear when not.
        You don’t have to be Sherlock 🕵️ Holmes to work out that in my case the Cardo is at fault.
        @Nick-Carthew
        I don’t think Sena is the problem, I tried another app and that works fine, volume is loud and clear also connected to the XT2 and XT.
          @Rob-Verhoeff Yes, it connects with mesh or Bluetooth and I’ve tried both. Both show the same behaviour.
          @Nick-Carthew said in Volume too low:
          Then the "problem-solver" has a nice challenge... 😉
          Patrick S0 1 Reply Last reply
            Patrick S0
            Patrick S0
            Patrick S0
            Regarding the volume issue, it remains quiet from the developers' side...
            By the way, I use MRA and Android Auto in my car, I don't have a motorcycle and therefore don't have all those interfaces
            • Patrick S0 Patrick S0
              @Patrick-S0 said in Volume too low:
              Holiday trip... back soon!
              • Murat Güven
                Murat Güven
                Murat Güven
                wrote on last edited by Murat Güven
                #27
                My (working) setup:
                I use an Android phone (Nothing phone 2a) which is quite close to bare Android, I think.
                With this, I can increase the volume above normal limits (for which I get a warning from the phone). With this volume level, I'm able to hear MRA and Spotify in a good level, although I'm using Earplugs.
                The audio system is Cardo Packtalk Edge.
                The iPhone / iOS does not allow this extended increase of the volume I think. Also separate adjustment of volumes per function is not possible on iOS.
                Regards,
                Murat
                • marc van der heijden
                  idd het geluid is bijna niet verstaanbaar, het is ook geen probleem wat nog maar kort bestaat, vooralsnog lijkt het niet opgelost te worden.
                  Aan de ontwikkelaars dus de vraag: Wanneer is het eens opgelost?
                  Als ik met Google Maps navigeer heb ik voldoende geluid bij de gesproken instructies, dus het ligt niet aan de telefoon of headset, heb al vanalles geprobeerd, maar de mra navigatie blijft de instructies fluisteren
                    @marc-van-der-heijden, als ik met GMaps navigeer doet zich exact hetzelfde probleem voor met het stem volume.
                    marc van der heijden 1 Reply Last reply
                      @Con-Hennekens said in Volume too low:
                      Bij mij dus niet, heb het deze week nog geprobeerd nadat ik een route aan het rijden was met mra in de auto en onderweg ( ja ik weet het dat kan ook met mra ) met Google Maps een restaurant zocht en met google er naar toe navigeerde, het geluid was toen duidelijk verstaanbaar en later toen ik weer met mra navigeerde was het op fluisterniveau
                      Bouke Ent 1 Reply Last reply
                        afgelopen 2 weken MRA Next gebruikt op ulefone armor x10 pro en mijn backup samsung a40. ik gebruik geen headset of andere zaken, gewoon volume van de telefoon. op ulefone prima en op samsung te laag. mijn conclusie is dan het ligt aan hardware en niet aan MRA Next app.
                          MRA Next is gebaseerd op het HereWeGo platform. Het HereWeGo platform leunt op de als standaard ingestelde TTS engine van je smartphone voor de aanwijzingen. Het heeft geen eigen stemmen.
                          Iedere Android telefoon heeft de Google TTS engine aan boord. Met deze Engine zal MRA Next (en HereWeGo) op iedere telefoon hetzelfde klinken met hetzelfde volume.
                          Veel Android telefoon hebben een eigen skin, zoals OneUI bij Samsung. Met deze skin kan er ook een aparte TTS engine meekomen wel dan als default ingesteld wordt. Dit zorgt ervoor dat er zoveel verschil tussen de verschillende telefoons zit.
                          Kortom het is NIET MRA die dit verschil veroorzaakt maar je eigen telefoon.
                            @M-Schrijver
                            Dat denk ik niet, altijd duidelijke aanwijzingen gehad uit Next en de XT en XT2, nu hoor ik Next nog nauwelijks, de XT2 komt luid en duidelijk door.
                            Zelfs met het volume vol open hoor ik Next nauwelijks.
                            Nog steeds dezelfde iPhone.
                            • Leike Lodiers
                              #34
                              Dit weekend nog 250km gereden op motor info was luid en duidelijk. ik gebruik een carpe iter tablet en mijn telefoon met een cardo edge samen. De gegeven route instructies zijn luid en duidelijk te verstaan en ik moet de cardo zelf minder volume laten geven. ik gebruik google tts en dan even een stem zoeken die hard genog is voor jouw.
                              • Leike Lodiers Leike Lodiers
                                @Leike-Lodiers said in Volume too low:
                                even een vraagje over de stem vinden die hard genoeg is, als ik in mra bij stemmen kijk zijn er slechts een paar Nederlandse stemmen, veel keus is er niet, ik heb bijv niks aan een arabische stem, dus hoezo kan je kiezen?
                                Leike Lodiers MotoCon 2 Replies Last reply
                                  @marc-van-der-heijden ik heb 11 Nederlandse en 5 Belgische stemmen en sommige klinken niet zo duidelijk vindt ik zelf. Dus ff moeten luisteren naar ze allemaal om een te kiezen die mij beviel.
                                    @marc-van-der-heijden, als je de stem kiest via het MRA App menu in plaats van de systeeminstellingen in je telefoon, krijg je iets meer keuze. In mijn beleving zijn ze echter allemaal even luid.
                                      De keuze van stemmen is MRA is volledig afhankelijk van het aanbod dat jouw merk telefoon in zijn software meelevert.
                                      Je kan zelf via een app als Acapela meer stemmen toevoegen.
                                      MRA zelf heeft geen stemmen
                                      Het onderliggende Here platform heeft ook zelf geen stemmen.
                                      MRA zou zelf een goede TTS engine mee kunnen leveren. Hierdoor kan iedereen een goede stem gebruiken.
                                        @Thomas-Keßler Try a new voice from your iPhone.
                                        Go to your iPhone Settings > Accessibility > Spoken content > Voices.
                                        Paul Smith b
                                        Paul Smith b
                                        Paul Smith b
                                        @Nick-Carthew thanks for the info I'll give it a try as I've had the same issue on my iphone throwing to my Carpuride
                                          Thomas Keßler
                                          Thomas Keßler
                                          Thomas Keßler
                                          @Nick-Carthew As I was at Lago die Garda for 1 week I was now able to see whether the approach of changing the iPhone's voice settings helps. I can confirm that it got a lot better changing the used voice in addition to turning the volume og the phone to max while MRA is open and in foreground. With this current state I can use MRA on my motorbike while listening to Spotify in parallel. Thanks a lot for the hint!
                                          • 3
                                          Niels Elferink
                                          Niels Elferink
                                          Thomas Keßler
                                          Thomas Keßler
                                          Paul Smith b
                                          Paul Smith b
                                          Tom Cat
                                          Tom Cat
                                          Murat Güven
                                          Murat Güven
                                          Patrick S0
                                          Patrick S0
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
