  2. Routes & Tracks
  3. track between waypoints is not showing
28 Posts 6 Posters 11.2k Views
  • Andrew 15
    Andrew 15
    Andrew 15
    i have a 6000 mile route saved on my account but the black line showing which roads ill be taking is no longer showing. it has been like this for a week now? is this a bug that is getting fixed?
    Thanks
    TorqueRider Steve Lynch 4 Replies Last reply
    • Andrew 15 Andrew 15
      Thanks
      @andrew-15
      Can you post a link of the route here?
      Do you use MRA RoutePlanner or MRA Mobile app?
      Don't forget to make the route status "public".
      Andrew 15 1 Reply Last reply
        Thanks
        Steve Lynch
        Steve Lynch
        Steve Lynch
        @andrew-15
        You could check the “Route Line Transparency” in the Toolkit and make sure it is not set to 100%.
        • TorqueRider TorqueRider
          @andrew-15
          Andrew 15
          Andrew 15
          Andrew 15
          @jack-van-tilburg
          Hi Jack,
          https://www.myrouteapp.com/route/open/6156185
          does that work?
          • Steve Lynch Steve Lynch
            @andrew-15
            Andrew 15
            Andrew 15
            Andrew 15
            @steve-lynch
            Thanks Steve,
            I have checked this and it is at 100%
            TorqueRider 2 Replies Last reply
              @jack-van-tilburg
              Hi Jack,
              does that work?
              @andrew-15 The track line is visible for me.
                @steve-lynch
                Thanks Steve,
                @andrew-15 said in track between waypoints is not showing:
                @steve-lynch
                Thanks Steve,
                So the problem is solved?
                Because 100% is totally transparent and invisible.
                I myself have Transparency at 20%.
                  Andrew 15
                  Andrew 15
                  Andrew 15
                  @nick-carthew haha, this is so strange becuase that black line is totally not ! there when i go in.
                  Perhaps is the web browser i am using???
                    Andrew 15
                    Andrew 15
                    Andrew 15
                    @andrew-15 Ive tried on chrome and mozilla firefox and still cannot see the black line.
                    are you two gold members?
                      @steve-lynch
                      Thanks Steve,
                      Did you change transparency to 20%?
                        @andrew-15 Yes, I have a gold account. I will test your route on my PC now.
                          Thanks
                          Steve Lynch
                          Steve Lynch
                          Steve Lynch
                          @andrew-15
                          Maybe you misread my post.
                          “You could check the “Route Line Transparency” in the Toolkit and make sure it is not set to 100%.”
                          As Jack said , 100% means the route line is completely transparent as in not visible.
                            @andrew-15 I have opened your route on my PC using my Gold account and my Basic test account. Both accounts show the track line using Chrome. I would check what Jack and Steve have mentioned about route line transparency.
                              Thanks
                              Steve Lynch
                              Steve Lynch
                              Steve Lynch
                              @andrew-15
                              Do not set the transparency to 100%
                                @andrew-15
                                Andrew 15
                                Andrew 15
                                Andrew 15
                                @steve-lynch Well aren't I embarrassed!
                                that was the issue all along.
                                i cannot believe it was that, im so stupid.
                                Thank you all for your patience and taking the time to talk me through it. it was really stressing me out 🤦
                                  Steve Lynch
                                  Steve Lynch
                                  Steve Lynch
                                  @andrew-15
                                  No problem Andrew.
                                  Enjoy your trip.
                                  • Nick Carthew
                                    @Andrew-15 We all learn from our mistakes. I bet you don’t make the same mistake again 😅 Enjoy your tour 👍🏼
                                    Matias Arnó Ibarz 0 1 Reply Last reply
                                      Matias Arnó Ibarz 0
                                      Matias Arnó Ibarz 0
                                      Matias Arnó Ibarz 0
                                      @nick-carthew
                                      A mi, me pasa exactamente lo mismo, y tengo el % de transparencia al 20%.....
                                      Alguien puede ayudarme.??
                                      Gracias.
                                      • Matias Arnó Ibarz 0 Matias Arnó Ibarz 0
                                        @nick-carthew
                                        Gracias.
                                        @matias-arnó-ibarz-0 said in track between waypoints is not showing:
                                        Gracias.
                                        Please post a link to your route.
                                        Don't forget to set the privacy setting to 'public'.
                                          Gracias.
                                          Matias Arnó Ibarz 0
                                          Matias Arnó Ibarz 0
                                          Matias Arnó Ibarz 0
                                          @jack-van-tilburg
                                          https://www.myrouteapp.com/route/open/6163803
                                          Matias Arnó Ibarz 0
                                          Matias Arnó Ibarz 0
                                          Steve Lynch
                                          Steve Lynch
                                          James Blythe
                                          James Blythe
                                          Andrew 15
                                          Andrew 15
                                            Vincible
                                            Vincible
