track between waypoints is not showing
@andrew-15 said in track between waypoints is not showing:
I have checked this and it is at 100%
Did you change transparency to 20%?
@andrew-15 Ive tried on chrome and mozilla firefox and still cannot see the black line.
are you two gold members?
@andrew-15 Yes, I have a gold account. I will test your route on my PC now.
i have a 6000 mile route saved on my account but the black line showing which roads ill be taking is no longer showing. it has been like this for a week now? is this a bug that is getting fixed?
Thanks
Maybe you misread my post.
“You could check the “Route Line Transparency” in the Toolkit and make sure it is not set to 100%.”As Jack said , 100% means the route line is completely transparent as in not visible.
@andrew-15 I have opened your route on my PC using my Gold account and my Basic test account. Both accounts show the track line using Chrome. I would check what Jack and Steve have mentioned about route line transparency.
Thanks
@steve-lynch Well aren't I embarrassed!
that was the issue all along.
i cannot believe it was that, im so stupid.
Thank you all for your patience and taking the time to talk me through it. it was really stressing me out
@andrew-15
No problem Andrew.
Enjoy your trip. -
@Andrew-15 We all learn from our mistakes. I bet you don’t make the same mistake again
Enjoy your tour
Enjoy your tour
@nick-carthew
A mi, me pasa exactamente lo mismo, y tengo el % de transparencia al 20%.....
Alguien puede ayudarme.??
Gracias. -
@nick-carthew
Gracias.@matias-arnó-ibarz-0 said in track between waypoints is not showing:
Gracias.Please post a link to your route.
Don't forget to set the privacy setting to 'public'. -
Don't forget to set the privacy setting to 'public'.@jack-van-tilburg
@jack-van-tilburg
I don't understand what's going on here.
With OpenStreetMap (OSM) I don't see a route line.
I see that with TomTom and Here map.
This is food for a technician. Possibly an issue with OSM? -
This is food for a technician. Possibly an issue with OSM?@jack-van-tilburg said in track between waypoints is not showing:
With Opens Street Map (OSM) I don't see a route line.
This is food for a technician. Possibly an issue with OSM?Es posible que sea un problema de servidor..... hasta ayer funcionó bien, pude hacer rutas, pero hoy al querer continuar ya no funcionaba.....
Una solución, por favor....!! -
This is food for a technician. Possibly an issue with OSM?Also when creating a new route I don't see a line when using OSM.
The calculation of the route also takes a very long time. -
The calculation of the route also takes a very long time.@jack-van-tilburg
Yes, having problems too. No track line showing. Transparency NOT set to 100%.
These are routes that previously displayed fine. Running slow too. -
I have reported the problem with the OpenStreetMap to the developers.
The OpenStreetMap will be operational again shortly.
Una solución, por favor....!!OSM is now showing the route line for me.
@steve-lynch said in track between waypoints is not showing:
Si.... ya funciona...
Gracias.
