  4. Audio cuttet via Bluetooth
57 Posts 14 Posters 20.6k Views 7 Watching
  • Aiello antoninoundefined Offline
    #41
    Honestly, I think I'll wait any longer, I still read about a lot of problems...
      In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
      nomkoundefined Offline
      @Corjan-Meijerink said in Audio cuttet via Bluetooth:
      where can we configure this?
      | MRA Gold Member |
      | MRA Next + Kawasaki Z650 |
      • nomkoundefined nomko
        Nick Carthewundefined Online
        @Nomko-Nomden Navigation settings > Audio
        • Aiello antoninoundefined Aiello antonino
          I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
          Haugundefined Offline
          Haug
          @Aiello-antonino
          Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
          • Haugundefined Offline
            Haug
            Any new experience about this problem?
              Haug
              @Corjan-Meijerink:
              Hello Corjan, today I tested several things regarding Audio via Bluetooth.
              1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              now the interesting thing!
              1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
              Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
              I really have the feeling, that the delay slider is not working at all in MRA.
              Could you pleas check again?
              Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
              Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
              Many Thanks in Advance and Regards
              Günter
                Haug
                @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                  Yes, I read your test! Indeed interesting.
                  I will check the audio delay setting in the upcoming 5.1 update 🙂
                    I've made some changes in 5.0.4! 😃
                    Haugundefined 1 Reply Last reply
                      Haug
                      @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
                      Many thanks for your support.
                      Regards
                      Günter
                      • Haugundefined Haug
                        Regards
                        Günter
                        @Haug Glad to read my changes seem to work! 🙂
                          M. Schrijverundefined Offline
                          #52
                          I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                          My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                          I did hear differences but not what i expected.
                          I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                          The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                          B.t.w I have a Sena SRL 3 headset.
                            Haug
                            Hallo everybody,
                            since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
                            Did you change anything? Can you check please?
                            Thanks
                            Günter
                              Haug
                              @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                                The same issue with current final and previous final release. The slider doesn't work as it should.
                                When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                                  Haug
                                  For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                                    Haug
                                    @corjan-meijerink : any News about this Problem?
                                    • 3
                                    Jörgenundefined
                                    richard 3vundefined
                                    richard 3v
                                    Haugundefined
                                    Haug
                                    Jan Weerheimundefined
                                    Jan Weerheim
                                    Marco Straniundefined
                                    Marco Strani
                                    Robert Laudensackundefined
                                    Robert Laudensack
                                      Simon James Hancockundefined
                                      Simon James Hancock
                                      2.9k
                                    • What is this? (Basic account)
                                    • Move blocks of routepoints
                                      Jörgenundefined
                                    • What is this red line
                                    • Download itn,gpx etc on android app - Folder location
                                    • Updated beta! 5.2.1 (486)
                                    • Roundabout Symbol and Exit Number
                                      b0hd1undefined
