  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 30.5k Views 7 Watching
    Yes, I read your test! Indeed interesting.
    I will check the audio delay setting in the upcoming 5.1 update 🙂
      I've made some changes in 5.0.4! 😃
      Haug 1 Reply Last reply
        Haug
        Haug
        Haug
        @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
        Many thanks for your support.
        Günter
        • Haug Haug
          Günter
          @Haug Glad to read my changes seem to work! 🙂
            #52
            I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
            My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
            I did hear differences but not what i expected.
            I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
            The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
            B.t.w I have a Sena SRL 3 headset.
            • Haug
              Haug
              Haug
              Hallo everybody,
              since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
              Did you change anything? Can you check please?
              Thanks
              Günter
              • Haug
                Haug
                Haug
                @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                  The same issue with current final and previous final release. The slider doesn't work as it should.
                  When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                  • Haug
                    Haug
                    Haug
                    For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                    • Haug
                      Haug
                      Haug
                      @corjan-meijerink : any News about this Problem?
                      • Haug
                        Haug
                        Haug
                        @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                        • Haug
                          Haug
                          Haug
                          Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                          Also no response from you @corjan-meijerink
                          This is not very friendly!
                            Haug
                            Haug
                            Haug
                            @M.-Schrijver
                            Hello M.
                            have you still the Audio Problem like me?
                            First second of the Audio command is missing.
                            Thanks and regards
                            Günter
                              With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                              during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                              • Haug
                                Haug
                                Haug
                                If you have a Media playing during Navigation with MRA, the Audio commands work without any Problem. This is due to an open bluetooth Connection with music. But I have normally during motorcycle ride no music playing.
                                • Haug Haug
                                  It's still a public forum and this is not a support ticket 🙂
                                  Pushing me definitely won't help me finding motivation for looking into an issue one users reports.
                                  From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
                                  • Haug
                                    Haug
                                    Haug
                                    Ok clear, but it seems, I am not the only one with this problem.
                                    For me it means, that the MRA is not useable anymore.
                                      To be fair, I don't really see many complaints about this.
                                      The biggest issue with the Android Auto audio channels has been solved.
                                      • Haug
                                        Haug
                                        Haug
                                        wrote on last edited by Haug
                                        #66
                                        Strange, that it was working with 5.0.4. But if it’s not an issue for you, I will leave MRA.
                                          We take all feedback serious but please, create a support ticket.
                                          Then we have an official way to communicate.
                                          Obviously audio is critical.
                                          • 4
                                          Haug
                                          Haug
                                          richard 3v
                                          richard 3v
                                          Jan Weerheim
                                          Jan Weerheim
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            3.6k
                                            Robineke
                                            Robineke
                                            Reinhard Grossmann h 0
                                          • Overlay Routes like the App does and waypoints without routes
                                            Rob Kelley
                                            Rob Kelley
                                          • Route Breakdown
                                            Scarecrow
                                            Scarecrow
                                          • Brittany routes
                                            Tony 13
                                            Tony 13
                                          • Vergrendel scherm zet alles op z'n kop
