  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 27.4k Views 7 Watching
  • Aiello antonino Offline
    #41
    Honestly, I think I'll wait any longer, I still read about a lot of problems...
      In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
      nomko Offline
      nomko Offline
      Banned
      @Corjan-Meijerink said in Audio cuttet via Bluetooth:
      where can we configure this?
      • nomko nomko
        Nick Carthew Offline
        @Nomko-Nomden Navigation settings > Audio
          I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
          Haug Offline
          Haug Offline
          Haug
          @Aiello-antonino
          Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
          • Haug Offline
            Haug Offline
            Haug
            Any new experience about this problem?
            • Haug Offline
              Haug Offline
              Haug
              @Corjan-Meijerink:
              Hello Corjan, today I tested several things regarding Audio via Bluetooth.
              1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
              now the interesting thing!
              1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
              Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
              I really have the feeling, that the delay slider is not working at all in MRA.
              Could you pleas check again?
              Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
              Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
              Many Thanks in Advance and Regards
              Günter
              • Haug Offline
                Haug Offline
                Haug
                @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                • Corjan Meijerink Offline
                  Yes, I read your test! Indeed interesting.
                  I will check the audio delay setting in the upcoming 5.1 update 🙂
                    I've made some changes in 5.0.4! 😃
                    Haug 1 Reply Last reply
                      Haug Offline
                      Haug Offline
                      Haug
                      @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
                      Many thanks for your support.
                      Günter
                      • Haug Haug
                        Günter
                        @Haug Glad to read my changes seem to work! 🙂
                        • M. Schrijver Offline
                          #52
                          I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
                          My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
                          I did hear differences but not what i expected.
                          I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
                          The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
                          B.t.w I have a Sena SRL 3 headset.
                          • Haug Offline
                            Haug Offline
                            Haug
                            Hallo everybody,
                            since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
                            Did you change anything? Can you check please?
                            Thanks
                            Günter
                            • Haug Offline
                              Haug Offline
                              Haug
                              @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                                The same issue with current final and previous final release. The slider doesn't work as it should.
                                When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                                • Haug Offline
                                  Haug Offline
                                  Haug
                                  For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                                  • Haug Offline
                                    Haug Offline
                                    Haug
                                    @corjan-meijerink : any News about this Problem?
                                    • Haug Offline
                                      Haug Offline
                                      Haug
                                      @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                                      • Haug Offline
                                        Haug Offline
                                        Haug
                                        Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                                        Also no response from you @corjan-meijerink
                                        This is not very friendly!
                                          Haug Offline
                                          Haug Offline
                                          Haug
                                          @M.-Schrijver
                                          Hello M.
                                          have you still the Audio Problem like me?
                                          First second of the Audio command is missing.
                                          Thanks and regards
                                          Günter
                                          • 4
                                          Haug
                                          Haug
                                          richard 3v
                                          richard 3v
                                          Jan Weerheim
                                          Jan Weerheim
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Update 5.2.2 - Quick fix
                                            1.3k
                                          • scherm bevrirzing
                                          • Position Arrow
                                            Huibertus
                                            Huibertus
                                          • Carpuride W702 icm Carplay
                                            17.5k
