  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
    I've made some changes in 5.0.4! 😃
    Haug 1 Reply Last reply
      Haug
      Haug
      Haug
      @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
      Many thanks for your support.
      Günter
      • Haug Haug
        Günter
        @Haug Glad to read my changes seem to work! 🙂
          #52
          I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
          My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
          I did hear differences but not what i expected.
          I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
          The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.
          B.t.w I have a Sena SRL 3 headset.
          • Haug
            Haug
            Haug
            Hallo everybody,
            since the last update to version 5.2 I have the same problem with the delay at Bluetooth devices. It does not matter, in which position the slider is.
            Did you change anything? Can you check please?
            Thanks
            Günter
            • Haug
              Haug
              Haug
              @corjan-meijerink: hi corjan, did you change the fix back? Have again the problem with 5.2.
                The same issue with current final and previous final release. The slider doesn't work as it should.
                When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel.
                • Haug
                  Haug
                  Haug
                  For me Version 5.0.4 was working, when Corjan wrote, that he changed something. But now it seems, the fix has gone.
                  • Haug
                    Haug
                    Haug
                    @corjan-meijerink : any News about this Problem?
                    • Haug
                      Haug
                      Haug
                      @corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
                      • Haug
                        Haug
                        Haug
                        Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
                        Also no response from you @corjan-meijerink
                        This is not very friendly!
                          Haug
                          Haug
                          Haug
                          @M.-Schrijver
                          Hello M.
                          have you still the Audio Problem like me?
                          First second of the Audio command is missing.
                          Thanks and regards
                          Günter
                            With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
                            during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay.
                            • Haug
                              Haug
                              Haug
                              If you have a Media playing during Navigation with MRA, the Audio commands work without any Problem. This is due to an open bluetooth Connection with music. But I have normally during motorcycle ride no music playing.
                              • Haug Haug
                                It's still a public forum and this is not a support ticket 🙂
                                Pushing me definitely won't help me finding motivation for looking into an issue one users reports.
                                From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
                                • Haug
                                  Haug
                                  Haug
                                  Ok clear, but it seems, I am not the only one with this problem.
                                  For me it means, that the MRA is not useable anymore.
                                    To be fair, I don't really see many complaints about this.
                                    The biggest issue with the Android Auto audio channels has been solved.
                                    • Haug
                                      Haug
                                      Haug
                                      wrote on last edited by Haug
                                      #66
                                      Strange, that it was working with 5.0.4. But if it’s not an issue for you, I will leave MRA.
                                        We take all feedback serious but please, create a support ticket.
                                        Then we have an official way to communicate.
                                        Obviously audio is critical.
                                        • Haug
                                          Haug
                                          Haug
                                          Hello, on Version 6 same problem.
                                          Anybody else?
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
