  2. Export assistance
  3. [Export] Garmin
  4. Mac to Garmin Zumo XT* GPX Transfer
macgpxfile transferimportexport
17 Posts 7 Posters 1.6k Views 2 Watching
  • Steve Jarrellundefined Online
    Steve Jarrell
    If you currently use MRB with PC and transfer your .gpx files to your Garmin XT, XT2 or XT3 via a USB connection, this post probably isn't for you.
    The PC and Garmin XTs play nicely together. You just plug the XT into the PC's USB port and the XT is automatically seen as another drive in File Explorer. You can then easily the XT's file structure from File Explorer. I have a PC that I can use if I want to, but I prefer to use my Macbook Pro whenever I possibly can.
    Also, if you're happy with whatever method that you use to transfer your .gpx files to your XT (the Drive or Tread app, the MRA connector, Basecamp, osmosis 🙂 or whatever), by all means keep doing what you're doing!
    However, for me, I'm old school and I like the speed, reliability and simplicity of manually placing my .gpx files into the XT's /gpx folder, then letting the XT import them when I start it up. I despise Basecamp, Garmin Express is outdated and I keep getting messages that a couple of it's components are not going to be supported in future Mac operating system releases, and I've found the Drive and Tread apps to be very cumbersome.
    I also do NOT want my to sync my content back and forth to Garmin's servers. My new XT3 uses the new Tread app instead of the older Drive app. It does have cool features (provides weather and traffic info, makes connecting your headset really easy, etc.), however I found it's file synching with explore.garmin.com to be terribly unreliable, slow and frustrating, even on a very fast WiFi connection.
    The issue in connecting the Mac to the XT, according to Garmin's own information (the XTs are on the list that is mentioned), is that, and I quote,
    "The following MTP Mode devices are able to connect to Garmin Express™ software on a Mac computer; however, they will not appear as a separate drive and the device's internal files cannot be accessed.
    A Windows computer must be used to view the internal contents of these devices. This includes any log files needed for troubleshooting."
    This is partially true. If you plug your XT into your Mac the XT will be able go into file transfer mode, however you can't see it from your Mac's Finder screen. There is a very easy, simple, fast, bulletproof and FREE solution though!
    There is an app called OpenMTP that can be downloaded here. If you want to make a donation to the developer (which I did) that's totally up to you, however it's not mandatory and there are no nag screens or limited features if you decide not to.
    The interface is "simply elegant" with your computer's folders on the left side, and your XT's folders on the right, and you drag files back and forth in either directly. It looks like this:
    The transfer is instantaneous, and you KNOW that it has successfully completed because you can physically see that the files have been transferred! When you're finished with the transfer you simply close the OpenMTP app, unplug your XT and it will turn off, then turn it back on and you'll be prompted to import the .gpx files that you just put into the /gpx folder.
    This methodology works flawlessly 100% of the time.
    Not that it matters to this discussion, but once your XT has imported the .gpx files from the /gpx folder to its "hidden" internal memory, you can then delete the .gpx files from the /gpx folder the next time you connect to it if you want to keep it cleaned out.
    I have been doing a lot of testing regarding the .gpx 1.1 and 1.2 file formats and their pros and cons, and I'll create another post in the near future on that subject and link it here if you're interested.
    Steve
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1200GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    Nick Carthewundefined Eric Perron 0undefined 2 Replies Last reply
    • Steve Jarrellundefined Steve Jarrell
      Steve
      @Steve-Jarrell Great solution and explanation of what has been a nagging problem for some time. Thanks @steve-jarrell 👍
      Steve Jarrellundefined 1 Reply Last reply
      • Steve Jarrellundefined Steve Jarrell referenced this topic on
        Steve Jarrell
        @Nick-Carthew You're very welcome. Here's the link to my second post regarding the gpx 1.1 and 1.2 file formats that I mentioned above. I tried to add it to my first post but I guess I waited too long to edit it!
        Steve
        Steve Jarrell
        2025 BMW R1200GS
        2025 Can-Am Spyder
        Garmin XT3
          @steve-jarrell I am going to move this Topic and your .gpx 1.1 vs 1.2 Topic to the dedicated Export assistance Garmin section of this forum as they will be more easily found by Garmin users.
          • Nick Carthewundefined Nick Carthew moved this topic from [Web] Suggestions and Discussion on
          • Nick Carthewundefined Nick Carthew pinned this topic on
            Steve Jarrell
            @Nick-Carthew Thanks Nick. I'll post any "Garmin only" content there in the future!
            Steve Jarrell
            2025 BMW R1200GS
            2025 Can-Am Spyder
            Garmin XT3
            • Van Hammée Lucundefined Offline
              Van Hammée Luc
              Hello Steve, Thank you for this very interesting information and your explanations. I'm also considering buying a Garmin XT2 or XT3 . Currently I use the NAVIGATOR V and a Carpuride W502 BS. But I'm going to change motorcycles (Honda Transalp - no CarPlay like on the Africa Twin). Thanks for the information. I will follow your future updates with interest. Thank you.
              • Van Hammée Lucundefined Van Hammée Luc
                Steve Jarrell
                @Van-Hammée-Luc You're very welcome. I'm glad that I could help!
                Steve Jarrell
                2025 BMW R1200GS
                2025 Can-Am Spyder
                Garmin XT3
                  Van Hammée Luc
                  Very thanks for you reply.
                  Luc Van Hammée
                  Belgium
                    @steve-jarrell Thank you for this topic. Coincidently, I just bought an XT3 that should arrive today. I'm coming off of the original XT, where I perform manual GPX 1.1 transfers much the same as you describe. I was dreading having to deal with anything Tread/Explore, but your explanations will make the whole setup manageable.
                    BTW, on Mac, I've been using MacDroid for GPX file transfer to my XT. OpenMTP looks appealing, and I will download it for comparison. Thanks!
                      Steve Jarrell
                      You're very welcome. I agree about Tread/Explore 100%!! I tried MacDroid and while it does work, I found OpenMTP to be much more straightforward and simple to use for my application, and it's 100% free (although I did send the developer a contribution as it's WELL worth it!).
                      Please report back and let us know your experience both with the XT3, 1.2 .gpx and OpenMTP!
                      Steve Jarrell
                      2025 BMW R1200GS
                      2025 Can-Am Spyder
                      Garmin XT3
                      John S Parryundefined 1 Reply Last reply
                      • Lenny Oundefined Offline
                        Lenny O
                        I use Garmin Drive App to wirelessly transfer the routes from MRA to my XT. Never failed yet.
                        • Mzokkundefined Online
                          There are many differences between the XT,XT2 and XT3. For the XT the Garmin Drive app works flawlessly for transferring routes wirelessly from your phone to the XT. It also works as a hub to connect your phone to weather information, traffic information and "Smart Notifications". But for the love of all that is holy do not connect it or the XT unit to Garmin Explore and sync your routes and tracks as you are in for a world of pain. I've done it a few times to see if its improved.....it hasn't. The XT is also capable of transferring routes via bluetooth to another XT device, a BMW NAV5 and 6 all of the 3XX Zumo's and the Zumo 590 and 595. This was/is handy if transferring routes others basically using any Garmin Zumo that has bluetooth sharing capability. I believe this is more complicated now and files cannot be shared directly from the XT2 or 3 to older Zumo's.
                          That said if you use MRA for route planning you can share files with old zumo devices using this arrangement (at least in Android I don't know about IOs)
                          Older Zumo's and any sd card contained therein are seen as a mass storage devices by Android phones you can cable connect the phone to the Zumo (make sure you use a Garmin lead!) and GPX files you download from MRA can be installed directly into the device or SD card.
                            Steve Jarrell
                            Very good information. I don't have my XT anymore to test with as I gave it to my brother when I got the XT3. I also don't have an Android based phone so those are two major variables.
                            You have to give it to Garmin though.... they have a way of convoluting things that should be rock solid simple into a frustrating experience in many cases. They also should be applauded for creating one of the world's worst user interfaces with Basecamp IMO :).
                            Steve Jarrell
                            2025 BMW R1200GS
                            2025 Can-Am Spyder
                            Garmin XT3
                              @Steve-Jarrell Step one compete. I followed your Tread setup instructions, completely avoiding Explore (no bueno on external Storage). I did enable the BT connection from the app to the XT3 for Weather and Traffic. So far, so good.
                              From my Windows PC, I copied a GPX to the GPX folder on my XT3 SD Card. The XT3 recognized it, and I saved it. I'll do a test run later today.
                              This XT3 is a different animal from the XT. It's going to take some getting used to, but my feeling is that it's going to be a nice upgrade.
                                Steve Jarrell
                                @John-S-Parry Excellent. Yes, the XT3 is different, but once I got used to it I do like it more than the XT.
                                Let us know how it goes!
                                Steve Jarrell
                                2025 BMW R1200GS
                                2025 Can-Am Spyder
                                Garmin XT3
                                  Steve
                                  Eric Perron 0undefined Offline
                                  Eric Perron 0
                                  @Steve-Jarrell Great post; however, I cannot see my Garmin DriveSmart 76 in the right window of openmtp. I"m searching for a solution and wondering if you have an easy solution ? Many thanks, Eric
                                    Steve Jarrell
                                    What type of computer are you using?
                                    Steve Jarrell
                                    2025 BMW R1200GS
                                    2025 Can-Am Spyder
                                    Garmin XT3
                                    Steve Jarrell
                                    Lenny Oundefined
                                    Lenny O
                                    Mzokkundefined
                                    Eric Perron 0
                                    Van Hammée Luc
                                    • Map overlay indicating the road's (known) speed limit?
                                      Jaspal Bhatti 0undefined
                                      Jaspal Bhatti 0
                                      Lenny Oundefined
                                      Lenny O
                                    • Repeat the last instruction?
                                      Lenny Oundefined
                                      Lenny O
                                      Gerard Wullinkundefined
                                      Gerard Wullink
                                    • Location always on, why?
                                      Leike Lodiersundefined
                                    • v5.2 (473) Feedback
                                    • Unknown symbol
                                    • exporteren naar xt2
                                      Mzokkundefined
