  4. Audio cuttet via Bluetooth
73 Posts 15 Posters 38.0k Views 7 Watching
  • Haug Haug
    Exactly, my car has no CarPlay.
    The same happens, if I just connect a headphone.
    Can even try another apple device
    @Haug said in Audio cuttet via Bluetooth:
    Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
    Haug 2 Replies Last reply
      Haug
      Haug
      Haug
      @Con-Hennekens it’s a Bluetooth headset
        Haug
        Haug
        Haug
        Directly via speaker in the phone, there is no problem
        Haug 1 Reply Last reply
        • Haug Haug
          Haug
          Haug
          Haug
          Ok, could you reproduce this error?
          • Haug Haug
            @Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
            richard 3v Haug 2 Replies Last reply
              richard 3v
              richard 3v
              richard 3v
              @Con-Hennekens said in Audio cuttet via Bluetooth:
              That's an interesting concept !
                Haug
                Haug
                Haug
                I do use Intercom on my bike but I repeat: the same Problem exist with my carradio (Bluetooth Connection) and with a jabra Bluetooth headphone.
                • Haug
                  Haug
                  Haug
                  Did something change about this issue in the latest update?
                  • Aiello antonino
                    #39
                    I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
                      @Aiello-antonino
                      I would switch to iOS 26.2..
                      • Aiello antonino
                        #41
                        Honestly, I think I'll wait any longer, I still read about a lot of problems...
                          In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                          Banned
                          @Corjan-Meijerink said in Audio cuttet via Bluetooth:
                          where can we configure this?
                          • nomko nomko
                            @Nomko-Nomden Navigation settings > Audio
                              Haug
                              Haug
                              Haug
                              @Aiello-antonino
                              Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
                              • Haug
                                Haug
                                Haug
                                Any new experience about this problem?
                                • Haug
                                  Haug
                                  Haug
                                  @Corjan-Meijerink:
                                  Hello Corjan, today I tested several things regarding Audio via Bluetooth.
                                  1. Bluetooth connection Iphone 15( IOS 26.2) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                    1. Bluetooth connection Iphone 12( IOS 26.01) to my Car-Audio System (Audi OEM - no Carplay) >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                  2. Bluetooth connection Iphone 15( IOS 26.2) to my Jabra Envolve 2 65 Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                  3. Bluetooth connection Iphone 15( IOS 26.2) to Sena SRL2 Helmet Headset >> always the first 2 Seconds of a Audio Command are missing. It does not matter, whether the slider for the delay is at ZERO or at 2sec. The cut at the beginning is always the same!
                                  now the interesting thing!
                                  1. Bluetooth connection Iphone 15( IOS 26.2) to Apple AirPods >> the voice of Myroute App comes perfect and without any cut and it has no effect, if the slider for delay is at Zero or at 2 Sec.
                                  Then I did the same tests with Scenic Navi APP, which has as well a slider for the delay. It works perfect with all Bluetooth devices, if I set the delay to 2 Sec.
                                  I really have the feeling, that the delay slider is not working at all in MRA.
                                  Could you pleas check again?
                                  Then the question is, what is different between Apple Airpods and all other Bluetooth devices?
                                  Could you please again investigate in this problem? Please let me know, if I can help something to fix this problem.
                                  Many Thanks in Advance and Regards
                                  Günter
                                  • Haug
                                    Haug
                                    Haug
                                    @Corjan-Meijerink: did you read my Post about my tests? Did not get any reply from you.
                                      Yes, I read your test! Indeed interesting.
                                      I will check the audio delay setting in the upcoming 5.1 update 🙂
                                        I've made some changes in 5.0.4! 😃
                                          Haug
                                          Haug
                                          Haug
                                          @Corjan-Meijerink Hi Corjan, now it seems to be working. I tried today with my bluetooth headset and will try it on Sunday with my SRL2 in helmet. Now the delay slider has really an effect and I will keep you updated.
                                          Many thanks for your support.
                                          Günter
                                          • 4
                                          Haug
                                          Haug
                                          Jan Weerheim
                                          Jan Weerheim
                                          richard 3v
                                          richard 3v
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
