  4. Audio cuttet via Bluetooth
67 Posts 14 Posters 27.4k Views 7 Watching
    @Con-Hennekens We all know what number it says 🙂
    This setting has only been available since the last update!
    @Haug If the delay does not work could you share the following info?
    • What phone are you using?
    • What version of the above?
    • Does the delay setting actually add a delay (disregard that you still have the issue but is there a noticeable different between 0 and 2 seconds)
    Haug Offline
    Haug Offline
    Haug
    Good evening,
    App version is 5.0.1 - 433
    I use iPhone 15 with iOS 26.1
    There is a delay but even at 2 sec it’s not enough
    Haug 1 Reply Last reply
    • Haug Haug
      Good evening,
      Haug Offline
      Haug Offline
      Haug
      Hello Corjan,
      Today I did some Tests in the car, connected via Bluetooth to my Autoradio. It doesn’t matter, what delay you adjust, the cut at the beginning is always the same length.
      So I assume,
      the slider is just fake.
      Günter
      • Haug Haug
        Hello Corjan,
        So I assume,
        Günter
        Corjan Meijerink Offline
        @Haug Thanks for your reply!
        I can guarantee you, the slider isn't fake 🙂
        Your audio system not respecting it, is another thing.
        I haven't yet seen any iOS device with these issues.
        It's always Android to be honest 😉
        I'll test some different configurations to see if I can reproduce this.
        Just to be sure, you are not using CarPlay but simply the car radio as bluetooth audio device?
          Haug Offline
          Haug Offline
          Haug
          Exactly, my car has no CarPlay.
          The same happens, if I just connect a headphone.
          Can even try another apple device
          Haug Con Hennekens 2 Replies Last reply
          • Haug Haug
            Haug Offline
            Haug Offline
            Haug
            Ok, it’s the same on iPhone and iPad. The slider makes no difference if 0 sec or 2 sec.
            The length of the cut at the beginning is slightly different on every Bluetooth device. I did the test with headphones and Bluetooth speakers.
            I even tried to change to English language.
            Every time the same.
            • Haug Haug
              @Haug said in Audio cuttet via Bluetooth:
              Wait a minute... Assuming you plug the headphone into your phone: Are you saying this also occurs if audio comes directly from your phone...?
              Haug 2 Replies Last reply
                Haug Offline
                Haug Offline
                Haug
                @Con-Hennekens it’s a Bluetooth headset
                  Haug Offline
                  Haug Offline
                  Haug
                  Directly via speaker in the phone, there is no problem
                  • Haug Haug
                    Haug Offline
                    Haug Offline
                    Haug
                    Ok, could you reproduce this error?
                    • Haug Haug
                      @Haug, No I cannot reproduce it, because on my devices it does not occur anymore. I bet your headset is one with intercom function active, which is why it needs to do audio ducking for the navigation instructions. It looks like it is doing that purely based on volume monitoring. If you don't use the intercom function, you could try pairing your phone as intercom, it will probably become higher up in the chain of priorities.
                      richard 3v Haug 2 Replies Last reply
                        richard 3v Offline
                        richard 3v Offline
                        richard 3v
                        @Con-Hennekens said in Audio cuttet via Bluetooth:
                        That's an interesting concept !
                          Haug Offline
                          Haug Offline
                          Haug
                          I do use Intercom on my bike but I repeat: the same Problem exist with my carradio (Bluetooth Connection) and with a jabra Bluetooth headphone.
                          • Haug Offline
                            Haug Offline
                            Haug
                            Did something change about this issue in the latest update?
                            • Aiello antonino Offline
                              #39
                              I read on the Apple Facebook pages, that many users with iOS 26 are having problems with CarPlay, that's why I haven't updated yet and I stayed on iOS 18, but the behavior is strange that it also happens with the intercom connected directly to the CP, I also use the same configuration, I think it's useless to interpose an additional device when the audio source still comes from the iPhone, it goes through CP and then goes to the intercom...
                              • Hubert Thoring Offline
                                @Aiello-antonino
                                I would switch to iOS 26.2..
                                  #41
                                  Honestly, I think I'll wait any longer, I still read about a lot of problems...
                                    In the 5.0.1 update coming week it will be possible to configure your own audio delay 🙂
                                    nomko Offline
                                    nomko Offline
                                    Banned
                                    @Corjan-Meijerink said in Audio cuttet via Bluetooth:
                                    where can we configure this?
                                    • nomko nomko
                                      Nick Carthew Offline
                                      @Nomko-Nomden Navigation settings > Audio
                                        Haug Offline
                                        Haug Offline
                                        Haug
                                        @Aiello-antonino
                                        Audio goes not through CarPlay device, it goes directly from iPhone to bluetooth headset
                                        • Haug Offline
                                          Haug Offline
                                          Haug
                                          Any new experience about this problem?
                                          • 4
                                          Haug
                                          Haug
                                          richard 3v
                                          richard 3v
                                          Jan Weerheim
                                          Jan Weerheim
                                          Marco Strani
                                          Marco Strani
                                          Robert Laudensack
                                          Robert Laudensack
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • scherm bevrirzing
                                          • Update 5.2.2 - Quick fix
                                            1.3k
                                          • Position Arrow
                                            Huibertus
                                            Huibertus
                                          • Carpuride W702 icm Carplay
                                            17.5k
