  3. Terrain map not visible?
18 Posts 8 Posters 3.1k Views 1 Watching
  • Frans Halleen Frans Halleen
    When I try to switch between maps all is wll until I go to the terrain map. This one will not display. Just a gray bacjground with the route.
    Any suggestions somebody?
    Thnx, Frans
    @Frans-Halleen I think it's server related. The maps are not on your device but online...
      @Frans-Halleen
      I have the same issue.
      Nit only the Here 'terrain" map but 'hybrid' and 'satellite' also.
      • Frans Halleen
        Frans Halleen
        Frans Halleen
        Is er ergens een MRA guru/werknemer die hier iets over kan zeggen? Of gewoon fixen?
        En inderdaad, de satteliet en hybrid kaarten van HERE zijn ook niet beschikbaar...
          @Frans-Halleen
          You can create a Support ticket (click).
          • Nick Carthew
            Problem resolved.
            TJ189 1 Reply Last reply
              Problem resolved.
              TJ189
              TJ189
              TJ189
              @Nick-Carthew Here Default only partially showing, a number of other maps not showing at all
              • TJ189 TJ189
                @TJ189 Try again.
                Rob Verhoeff TJ189 2 Replies Last reply
                  @TJ189 Try again.
                  @Nick-Carthew the speed of loading maps is still not OK!
                  HERE standard map loads partially...
                  After refreshing the screen some other blocks won't show.
                    @TJ189 Try again.
                    TJ189
                    TJ189
                    TJ189
                    @Nick-Carthew Nope,
                    • Nick Carthew
                      The developers are looking at it right now and a fix should only take a few minutes.
                      • Robert Bürgisser
                        Robert Bürgisser
                        Robert Bürgisser
                        Thank you for working to solve the problem. Very sympathetic. I've had the problem for about 3 days.
                          HERE terrain / satellite / hybrid maps are visible as expected.
                          I am looking into the loading issues right now. We are experiencing quite some visitors at this point. Trying to add some more capacity!
                          Rob Verhoeff Herko ter Horst 2 Replies Last reply
                          • Frans Halleen
                            Frans Halleen
                            Frans Halleen
                            Maps are visible, thank you for your help
                              @Corjan-Meijerink no more dropouts. Thnx 👍
                                @Corjan-Meijerink it's not fixed when I look at it now. The TomTom map also seems to be flaky, especially when zooming first in, then out a single level.
                                  @Herko-ter-Horst weird... no lag in zooming in or out over here with any map (10:12pm).
                                  Edit 10:35pm: it becomes weirder... I started a complete new session in Firefox and then zoom in to the max. The screen builds up pretty quick. Zooming out again and I experience lag in building the map. So @Herko-ter-Horst do has a point!
                                    TJ189
                                    TJ189
                                    TJ189
                                    Here Default still not responding correctly
                                    TJ189
                                    TJ189
                                    Frans Halleen
                                    Frans Halleen
                                    Robert Bürgisser
                                    Robert Bürgisser
                                      TomOnTour
                                      TomOnTour
                                    • Newsletter optimisation
                                    • route aanklikken in overzichtskaart
                                    • Trekking tool: sun/shade
                                    • How can I change colours in the route overview?
                                      Kudee
                                      Kudee
                                    • Skip feature in the MRA Classic
                                      TomOnTour
                                      TomOnTour
