  3. Terrain map not visible?
18 Posts 8 Posters 1.8k Views 1 Watching
  • Frans Halleenundefined Offline
    Frans Halleen
    When I try to switch between maps all is wll until I go to the terrain map. This one will not display. Just a gray bacjground with the route.
    Any suggestions somebody?
    Thnx, Frans
    • Frans Halleenundefined Frans Halleen
      Thnx, Frans
      Rob Verhoeffundefined Online
      @Frans-Halleen I think it's server related. The maps are not on your device but online...
        Jack van Tilburg
        @Frans-Halleen
        I have the same issue.
        Nit only the Here 'terrain" map but 'hybrid' and 'satellite' also.
          Frans Halleen
          Is er ergens een MRA guru/werknemer die hier iets over kan zeggen? Of gewoon fixen?
          En inderdaad, de satteliet en hybrid kaarten van HERE zijn ook niet beschikbaar...
            Jack van Tilburg
            @Frans-Halleen
            You can create a Support ticket (click).
              Problem resolved.
              TJ189undefined 1 Reply Last reply
                Problem resolved.
                TJ189undefined Offline
                TJ189
                @Nick-Carthew Here Default only partially showing, a number of other maps not showing at all
                • TJ189undefined TJ189
                  @TJ189 Try again.
                  Rob Verhoeffundefined TJ189undefined 2 Replies Last reply
                    @TJ189 Try again.
                    @Nick-Carthew the speed of loading maps is still not OK!
                    HERE standard map loads partially...
                    After refreshing the screen some other blocks won't show.
                      @TJ189 Try again.
                      TJ189
                      @Nick-Carthew Nope,
                        The developers are looking at it right now and a fix should only take a few minutes.
                        • Robert Bürgisserundefined Offline
                          Robert Bürgisser
                          Thank you for working to solve the problem. Very sympathetic. I've had the problem for about 3 days.
                            HERE terrain / satellite / hybrid maps are visible as expected.
                            I am looking into the loading issues right now. We are experiencing quite some visitors at this point. Trying to add some more capacity!
                            Rob Verhoeffundefined Herko ter Horstundefined 2 Replies Last reply
                              Frans Halleen
                              Maps are visible, thank you for your help
                                @Corjan-Meijerink no more dropouts. Thnx 👍
                                  @Corjan-Meijerink it's not fixed when I look at it now. The TomTom map also seems to be flaky, especially when zooming first in, then out a single level.
                                    @Herko-ter-Horst weird... no lag in zooming in or out over here with any map (10:12pm).
                                    Edit 10:35pm: it becomes weirder... I started a complete new session in Firefox and then zoom in to the max. The screen builds up pretty quick. Zooming out again and I experience lag in building the map. So @Herko-ter-Horst do has a point!
                                      TJ189
                                      Here Default still not responding correctly
                                      Jack van Tilburg
                                      TJ189undefined
                                      TJ189
                                      Frans Halleen
                                      Robert Bürgisser
                                      • Next+ 1st impressions
                                        GT JWRundefined
                                      • Riding mode in routeplanner
                                        luc 1aundefined
                                        luc 1a
                                      • Shaping points and Via points
                                        Herman Veldhuizenundefined
                                        1.3k
                                        Lex.Kloet.RXundefined
                                        Lex.Kloet.RX
                                      • Free Ride Mode - Speed Warnings
                                      • Audible speed camera alerts without active route in CarPlay
