  3. Terrain map not visible?
18 Posts 8 Posters 3.1k Views 1 Watching
  • Frans Halleen
    Frans Halleen
    Frans Halleen
    When I try to switch between maps all is wll until I go to the terrain map. This one will not display. Just a gray bacjground with the route.
    Any suggestions somebody?
    Thnx, Frans
    • Frans Halleen Frans Halleen
      Thnx, Frans
      @Frans-Halleen I think it's server related. The maps are not on your device but online...
        @Frans-Halleen
        I have the same issue.
        Nit only the Here 'terrain" map but 'hybrid' and 'satellite' also.
        • Frans Halleen
          Frans Halleen
          Frans Halleen
          Is er ergens een MRA guru/werknemer die hier iets over kan zeggen? Of gewoon fixen?
          En inderdaad, de satteliet en hybrid kaarten van HERE zijn ook niet beschikbaar...
            @Frans-Halleen
            You can create a Support ticket (click).
            • Nick Carthew
              Problem resolved.
              TJ189 1 Reply Last reply
                Problem resolved.
                TJ189
                TJ189
                TJ189
                @Nick-Carthew Here Default only partially showing, a number of other maps not showing at all
                • TJ189 TJ189
                  @TJ189 Try again.
                  Rob Verhoeff TJ189 2 Replies Last reply
                    @TJ189 Try again.
                    @Nick-Carthew the speed of loading maps is still not OK!
                    HERE standard map loads partially...
                    After refreshing the screen some other blocks won't show.
                      @TJ189 Try again.
                      TJ189
                      TJ189
                      TJ189
                      @Nick-Carthew Nope,
                      • Nick Carthew
                        The developers are looking at it right now and a fix should only take a few minutes.
                        • Robert Bürgisser
                          Robert Bürgisser
                          Robert Bürgisser
                          Thank you for working to solve the problem. Very sympathetic. I've had the problem for about 3 days.
                            HERE terrain / satellite / hybrid maps are visible as expected.
                            I am looking into the loading issues right now. We are experiencing quite some visitors at this point. Trying to add some more capacity!
                            Rob Verhoeff Herko ter Horst 2 Replies Last reply
                            • Frans Halleen
                              Frans Halleen
                              Frans Halleen
                              Maps are visible, thank you for your help
                                @Corjan-Meijerink no more dropouts. Thnx 👍
                                  @Corjan-Meijerink it's not fixed when I look at it now. The TomTom map also seems to be flaky, especially when zooming first in, then out a single level.
                                    @Herko-ter-Horst weird... no lag in zooming in or out over here with any map (10:12pm).
                                    Edit 10:35pm: it becomes weirder... I started a complete new session in Firefox and then zoom in to the max. The screen builds up pretty quick. Zooming out again and I experience lag in building the map. So @Herko-ter-Horst do has a point!
                                      TJ189
                                      TJ189
                                      TJ189
                                      Here Default still not responding correctly
                                      TJ189
                                      TJ189
                                      Frans Halleen
                                      Frans Halleen
                                      Robert Bürgisser
                                      Robert Bürgisser
                                        TomOnTour
                                        TomOnTour
                                      • Newsletter optimisation
                                      • route aanklikken in overzichtskaart
                                      • Trekking tool: sun/shade
                                      • How can I change colours in the route overview?
                                        Kudee
                                        Kudee
                                      • Skip feature in the MRA Classic
                                        TomOnTour
                                        TomOnTour
