  4. Alternative to Here
Alternative to Here
15 Posts 11 Posters 5.0k Views 4 Watching
  • Fred Gilbert
    Fred Gilbert
    Fred Gilbert
    If Here is causing high battery usage. Why can't a different map be used?
    Dave J 0 Rob Verhoeff 2 Replies Last reply
    • Fred Gilbert Fred Gilbert
      @Fred-Gilbert Look at this thread @Corjan-Meijerink (MRA Dev Team) in a similar topic says,
      “Well OSM doesn’t have a navigation tool (SDK) for our development platform (Flutter). So yeah, pretty impossible.
      As the battery usage is caused by the map rendering, we are looking into workarounds for that, but pretty complex too 😉
      I get another answer from HERE next week so I’ll just keep nagging them 🙂.”
      Ducati Multistrada V4 Rally
      iPhone 18 Pro
      CHIGEE AIO-6 LTE
      Dikke Wim 1 Reply Last reply
      • Dave J 0 Dave J 0
        Dikke Wim
        Dikke Wim
        Dikke Wim
        @Dave-J-0
        Good that you keep nagging them. The high CPU usage is pretty annoying and on my iPhone and the brightness of my screen is often dimmed ....
        Hoping you find a solution.
        Keep up the good work.
          Maybe Cost related but is TomTom an alternatieve?
          richtea999 Lynchy67 2 Replies Last reply
          • M. Schrijver M. Schrijver
            @M-Schrijver TomTom already have an app - it seems very unlikely that they'd give away the family jewels (so to speak!) to another app developer.
            Especially when MRA is such good competition, and doesn't need dedicated h/w.
            Rob Verhoeff TorqueRider 2 Replies Last reply
            • richtea999 richtea999
              @richtea999 Well, so does Here with his HERE WeGo navigation app...
              https://play.google.com/store/apps/details?id=com.here.app.maps&hl=nl&gl=US
                @richtea999 said in Alternative to Here:
                BMW Connected app is based on TomTom.
                And I use it very often (40k km ).
                The iPhone doesn't overheat and power is no problem.
                But the iPhone does not emulate the screen on the device. Screendata is being sent to the TFT.
                But I think that most of the features of Next are impossible to implement in the TomTom engine.
                  Lynchy67
                  Lynchy67
                  Lynchy67
                  @M-Schrijver
                  If you have an MRA Gold account you can already use the Tom Tom Curvy/Windy Routes Options.
                  Set up your Tom Tom Route using the Tom Tom Map.
                  Then “Expand” X amount of waypoints into it.
                  You will then need to switch it to the Here map and check that all the “Expanded” Waypoints are on the Here Map Routeline.
                  hawebo Herko ter Horst 2 Replies Last reply
                  • Lynchy67 Lynchy67
                    @M-Schrijver
                    hawebo
                    hawebo
                    hawebo
                    @Lynchy67 Dein Vorschlag entspricht dem Tutorial für die Erstellung kurvenreicher Routen in MRA. Das funktioniert auch gut so.
                    Aber leider löst es nicht das Problem des hohen Stromverbrauchs bei der Navigation mit den HERE-Karten.
                    Navigation: Gigaset GX4 PRO, Android 14
                    BackUp: Google Pixel 7a, Android 17
                    • Lynchy67 Lynchy67
                      @M-Schrijver
                      @Lynchy67 That doesn't help at all with the issues MRA Navigation has using the HERE map.
                      Lynchy67 1 Reply Last reply
                        @Fred-Gilbert HERE is the only map provider that supports the Flutter design platform. Since this app is being developed on that platform, it is not possible to choose another map provider for the navigation engine.
                        See also this post with the awnser from Corjan.
                        hawebo 1 Reply Last reply
                          hawebo
                          hawebo
                          hawebo
                          @Rob-Verhoeff said in Alternative to Here:
                          Danke Rob! Damit hat sich meine Frage nach einem Kartenwechsel wohl auch erledigt 😕
                            Lynchy67
                            Lynchy67
                            Lynchy67
                            @Herko-ter-Horst
                            I have no issues navigating at all.
                            I always use the offline option
                            My Samsung S21+ always gives me a positive increase whenever I'm Navigating
                            I never use Voice prompts and I choose the Simple option for the Maps.
                            I only use the Offline Navigation and Skip waypoints automatically.
                            Everything else in the Functional option is turned off.
                            Drabslab 1 Reply Last reply
                            • Lynchy67 Lynchy67
                              @Herko-ter-Horst
                              Drabslab
                              Drabslab
                              Drabslab
                              @Lynchy67 said in Alternative to Here:
                              @Herko-ter-Horst
                              I read such drastic measures befoe on the forum.
                              If you turn off everything that makes Next interesting, then it works 🙂
                              That may be good as a temporary hack, but not as final solution, I hope.
                              • Drabslab Drabslab
                                @Herko-ter-Horst
                                Lynchy67
                                Lynchy67
                                Lynchy67
                                @Drabslab
                                The only things interesting to me are my coloured Via Points showing me the POI’s.
                                Scenery, Viewpoints, Historic or notable Buildings, Lakes, Ponds, Mountains, Food/Drink and Fuel.
                                Dikke Wim
                                Dikke Wim
                                Drabslab
                                Drabslab
                                hawebo
                                hawebo
                                Fred Gilbert
                                Fred Gilbert
                                Lynchy67
                                Lynchy67
                                • Startpunt wijzigen
                                  Ed van Klink
                                  Ed van Klink
                                • Vrienden toevoegen
