  4. Alternative to Here
Alternative to Here
15 Posts 11 Posters 5.2k Views 4 Watching
    Maybe Cost related but is TomTom an alternatieve?
    @M-Schrijver TomTom already have an app - it seems very unlikely that they'd give away the family jewels (so to speak!) to another app developer.
    Especially when MRA is such good competition, and doesn't need dedicated h/w.
    Rob Verhoeff TorqueRider 2 Replies Last reply
    • richtea999 richtea999
      @richtea999 Well, so does Here with his HERE WeGo navigation app...
      https://play.google.com/store/apps/details?id=com.here.app.maps&hl=nl&gl=US
      đŸïž BMW K1600GT-P (2013) | Nolan N100-5 with Sena 30K
      đŸ“± iOS on iPhone 13 & 16 (mounted on Quadlock or AliExpress extention on BMW-cradle)
      đŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
        @richtea999 said in Alternative to Here:
        BMW Connected app is based on TomTom.
        And I use it very often (40k km ).
        The iPhone doesn't overheat and power is no problem.
        But the iPhone does not emulate the screen on the device. Screendata is being sent to the TFT.
        But I think that most of the features of Next are impossible to implement in the TomTom engine.
          @M-Schrijver
          If you have an MRA Gold account you can already use the Tom Tom Curvy/Windy Routes Options.
          Set up your Tom Tom Route using the Tom Tom Map.
          Then “Expand” X amount of waypoints into it.
          You will then need to switch it to the Here map and check that all the “Expanded” Waypoints are on the Here Map Routeline.
          hawebo Herko ter Horst 2 Replies Last reply
          • Lynchy67 Lynchy67
            @M-Schrijver
            hawebo
            hawebo
            hawebo
            @Lynchy67 Dein Vorschlag entspricht dem Tutorial fĂŒr die Erstellung kurvenreicher Routen in MRA. Das funktioniert auch gut so.
            Aber leider löst es nicht das Problem des hohen Stromverbrauchs bei der Navigation mit den HERE-Karten.
            Navigation: Gigaset GX4 PRO, Android 14
            BackUp: Google Pixel 7a, Android 17
            • Lynchy67 Lynchy67
              @M-Schrijver
              @Lynchy67 That doesn't help at all with the issues MRA Navigation has using the HERE map.
              Lynchy67 1 Reply Last reply
              • Fred Gilbert Fred Gilbert
                If Here is causing high battery usage. Why can't a different map be used?
                @Fred-Gilbert HERE is the only map provider that supports the Flutter design platform. Since this app is being developed on that platform, it is not possible to choose another map provider for the navigation engine.
                See also this post with the awnser from Corjan.
                hawebo 1 Reply Last reply
                  hawebo
                  hawebo
                  hawebo
                  @Rob-Verhoeff said in Alternative to Here:
                  Danke Rob! Damit hat sich meine Frage nach einem Kartenwechsel wohl auch erledigt 😕
                    @Herko-ter-Horst
                    I have no issues navigating at all.
                    I always use the offline option
                    My Samsung S21+ always gives me a positive increase whenever I'm Navigating
                    I never use Voice prompts and I choose the Simple option for the Maps.
                    I only use the Offline Navigation and Skip waypoints automatically.
                    Everything else in the Functional option is turned off.
                    Drabslab 1 Reply Last reply
                    • Lynchy67 Lynchy67
                      @Herko-ter-Horst
                      @Lynchy67 said in Alternative to Here:
                      @Herko-ter-Horst
                      I read such drastic measures befoe on the forum.
                      If you turn off everything that makes Next interesting, then it works 🙂
                      That may be good as a temporary hack, but not as final solution, I hope.
                      • Drabslab Drabslab
                        @Herko-ter-Horst
                        @Drabslab
                        The only things interesting to me are my coloured Via Points showing me the POI’s.
                        Scenery, Viewpoints, Historic or notable Buildings, Lakes, Ponds, Mountains, Food/Drink and Fuel.
                        Dikke Wim
                        Dikke Wim
                        hawebo
                        hawebo
                        Fred Gilbert
                        Fred Gilbert
                          MartinW
                          MartinW
                        • BĂ©ta to no-bĂ©ta
                          Cleo
                          Cleo
                          Rob Draaisma 0
                          Rob Draaisma 0
