  4. Alternative to Here
Alternative to Here
15 Posts 11 Posters 3.9k Views 4 Watching
  • Fred Gilbertundefined Offline
    Fred Gilbert
    If Here is causing high battery usage. Why can't a different map be used?
    Dave J 0undefined Rob Verhoeffundefined 2 Replies Last reply
    • Fred Gilbertundefined Fred Gilbert
      Dave J 0undefined Offline
      @Fred-Gilbert Look at this thread @Corjan-Meijerink (MRA Dev Team) in a similar topic says,
      “Well OSM doesn’t have a navigation tool (SDK) for our development platform (Flutter). So yeah, pretty impossible.
      As the battery usage is caused by the map rendering, we are looking into workarounds for that, but pretty complex too 😉
      I get another answer from HERE next week so I’ll just keep nagging them 🙂.”
      Ducati Multistrada V4 Rally
      iPhone 15 Pro
      CHIGEE AIO-6 LTE
      • Dave J 0undefined Dave J 0
        Dikke Wimundefined Offline
        Dikke Wim
        @Dave-J-0
        Good that you keep nagging them. The high CPU usage is pretty annoying and on my iPhone and the brightness of my screen is often dimmed ....
        Hoping you find a solution.
        Keep up the good work.
          M. Schrijverundefined Offline
          Maybe Cost related but is TomTom an alternatieve?
          richtea999undefined Lynchy67undefined 2 Replies Last reply
            richtea999undefined Offline
            @M-Schrijver TomTom already have an app - it seems very unlikely that they'd give away the family jewels (so to speak!) to another app developer.
            Especially when MRA is such good competition, and doesn't need dedicated h/w.
            Rob Verhoeffundefined Jack van Tilburgundefined 2 Replies Last reply
              Rob Verhoeffundefined Offline
              @richtea999 Well, so does Here with his HERE WeGo navigation app...
              https://play.google.com/store/apps/details?id=com.here.app.maps&hl=nl&gl=US
                Jack van Tilburg
                @richtea999 said in Alternative to Here:
                BMW Connected app is based on TomTom.
                And I use it very often (40k km ).
                The iPhone doesn't overheat and power is no problem.
                But the iPhone does not emulate the screen on the device. Screendata is being sent to the TFT.
                But I think that most of the features of Next are impossible to implement in the TomTom engine.
                  Lynchy67undefined Offline
                  @M-Schrijver
                  If you have an MRA Gold account you can already use the Tom Tom Curvy/Windy Routes Options.
                  Set up your Tom Tom Route using the Tom Tom Map.
                  Then “Expand” X amount of waypoints into it.
                  You will then need to switch it to the Here map and check that all the “Expanded” Waypoints are on the Here Map Routeline.
                  haweboundefined Herko ter Horstundefined 2 Replies Last reply
                  • Lynchy67undefined Lynchy67
                    @M-Schrijver
                    haweboundefined Offline
                    hawebo
                    @Lynchy67 Dein Vorschlag entspricht dem Tutorial für die Erstellung kurvenreicher Routen in MRA. Das funktioniert auch gut so.
                    Aber leider löst es nicht das Problem des hohen Stromverbrauchs bei der Navigation mit den HERE-Karten.
                      @M-Schrijver
                      @Lynchy67 That doesn't help at all with the issues MRA Navigation has using the HERE map.
                        @Fred-Gilbert HERE is the only map provider that supports the Flutter design platform. Since this app is being developed on that platform, it is not possible to choose another map provider for the navigation engine.
                        See also this post with the awnser from Corjan.
                        haweboundefined 1 Reply Last reply
                          hawebo
                          @Rob-Verhoeff said in Alternative to Here:
                          Danke Rob! Damit hat sich meine Frage nach einem Kartenwechsel wohl auch erledigt 😕
                            @Herko-ter-Horst
                            I have no issues navigating at all.
                            I always use the offline option
                            My Samsung S21+ always gives me a positive increase whenever I'm Navigating
                            I never use Voice prompts and I choose the Simple option for the Maps.
                            I only use the Offline Navigation and Skip waypoints automatically.
                            Everything else in the Functional option is turned off.
                              @Herko-ter-Horst
                              Drabslabundefined Offline
                              @Lynchy67 said in Alternative to Here:
                              @Herko-ter-Horst
                              I read such drastic measures befoe on the forum.
                              If you turn off everything that makes Next interesting, then it works 🙂
                              That may be good as a temporary hack, but not as final solution, I hope.
                              • Drabslabundefined Drabslab
                                @Herko-ter-Horst
                                @Drabslab
                                The only things interesting to me are my coloured Via Points showing me the POI’s.
                                Scenery, Viewpoints, Historic or notable Buildings, Lakes, Ponds, Mountains, Food/Drink and Fuel.
                                Dave J 0undefined
                                richtea999undefined
                                Dikke Wimundefined
                                Dikke Wim
                                haweboundefined
                                hawebo
                                Fred Gilbert
                                Jack van Tilburg
                                Drabslabundefined
                                Lynchy67undefined
                                  pehaundefined
                                  peha
                                • Veekeersinfo en omleiden
                                  Bouke Entundefined
                                • Updated beta! 5.2.1 (486)
                                • Play Knop in Route Lab
                                  Kris Lemaireundefined
                                  Kris Lemaire
                                  Leike Lodiersundefined
                                • Move blocks of routepoints
