  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 5.5k Views 9 Watching
  • LennyO Offline
    LennyO Offline
    Hello, all!
    I think I have seen this discussed before, but can not find it...
    Anyway, the North-South-East-West Red segment on the elevation circle is not working properly and therefore is very confusing.
    Has this been looked into and if yes, what is the latest on that?
    Thanks!
    • RetiredWingMan Offline
      The red segment shows the direction to north.
      LennyO 1 Reply Last reply
        LennyO Offline
        LennyO Offline
        @RetiredWingMan
        Well.... it should ! But..... look at this pictures. I am standing in the same spot facing due South. My Pap is oriented North.
        • Corjan Meijerink Offline
          We aren't a compass app.
          If you stand still be don't do much effort 🙂
          • superg Offline
            superg Offline
            It's given you the direction when you are moving .
            • white.mouse Offline
              white.mouse Offline
              Just look at the pictures in this thread made by Jörgen!
              • white.mouse white.mouse
                LennyO Offline
                LennyO Offline
                @white.mouse Sorry, what pictures in which thread?
                • Jim Allen Offline
                  Jim Allen Offline
                  Jim Allen
                  When one navigates with the app one sees the altitude with a compass indication around the circle. These red segment
                  indicators should show the direction that one is traveling In fact the indicator correctly indicates north and south but east and west is backwards. While traveling east the red bar indicator shows west. In other words with I travel west the red indicator should be on the left. That is not the case now. I am using an iPhone 14 pro max with revision 5.2.0 - 473.
                    white.mouse Offline
                    wrote on last edited by white.mouse
                    sorry,
                    Here's the link
                    https://forum.myrouteapp.com/topic/11064/compass-is-not-working-properly/8?_=1785773867949
                    or
                    https://forum.myrouteapp.com/post/81307
                    • LennyO Offline
                      LennyO Offline
                      Ok, thanks to all!
                      I guess I needed a mental adjustment to understand that the red segment just says where the North is in relation to the direction I am traveling (to my nose... )
                      That said, please confirm that the following pictures show the expected behavior of the Red segment. My map is oriented NORTH, so you can easily see in which direction I am moving. Thank you!
                      IMG_0005.jpg IMG_0007.jpg IMG_0010.jpg IMG_0012.jpg IMG_0014.jpg IMG_0016.jpg
                        Marinus van Deudekom Offline
                        To me that makes no sense at all. But then again I never use North up.
                        Something tells me in top of that it only works when using the dynamic camera view but I'm nooit shure
                          LennyO Offline
                          LennyO Offline
                          @Marinus-van-Deudekom The behavior of the Red segment is the same in every mode. I just verrified it on a ride this morning. In the Dynamic mode the Blue Arrow in the bottom right acts as a compass too, and it coinsides with the Red segment behavior.
                            Agree that it looks strange in the north up view.
                            The red sections points to where north is.
                            Compared to your physical orientation, not the map on your screen.
                            Brian McG 2 Replies Last reply
                              Brian McG Offline
                              Brian McG Offline
                              North is north is north, if the map is north up then north is up
                              In north up mode should the red section on the compass not always be at the top & not change?
                              • Brian McG Brian McG
                                LennyO Offline
                                LennyO Offline
                                @Brian-McG Evidently only if you are heading North all the time 🙂
                                • Stanisław Offline
                                  Stanisław Offline
                                  I think in north-up map orientation, the red segment should simply disappear, as it is not useful 🙂
                                  Regards
                                  Staszek
                                    Brian McG Offline
                                    Brian McG Offline
                                    @Corjan-Meijerink apologies I think I now see your logic about your physical orientation & the direction of the altitude pointer, although for me it took some mental gymnastics to get there
                                    the way I think it is working is you have to discount everything else in the MRA display & treat the altitude pointer compass as a separate device, like imagining an old fashioned compass sitting on the fuel cap of your bike
                                    if I am riding heading east, then north is on my left shoulder & the altitude pointer compass wil point to the left of my phone screen
                                    if I am riding heading west, then north is on my right shoulder & the altitude pointer compass will point to the right of my phone screen
                                    again apologies but for me it was just not an intuitive bit of UI
                                    • LennyO Offline
                                      LennyO Offline
                                      I also had a hard time with this....
                                      I guess the simplest way to grasp the Red segment position in relation to your movement is to imagine yourself sitting inside the elevation circle heading in the 12 o'clock direction.
                                        It’s completely correct! Has no relation with the map. Indeed like an actual compass strapped om your screen.
                                        It makes sense but in north up it’s confusing.
                                        Pinning it north or hiding it will make most sense I guess.
                                        • Con Hennekens Offline
                                          It seems current generations do not have much experience with (analogue) compasses anymore 😉
                                          Guzzist 1 Reply Last reply
                                          • 3
                                          • 4
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                          • Update 5.2.2 - Quick fix
                                          • Export to BMW CRN
                                          • Did somebody see 5.2.2 (489) on android Yet!
                                          • Berekende route tijd
                                          • Suggestion about making routes visible in a folder
