  4. The compas direction on the elevation circle is wrong
63 Posts 19 Posters 11.4k Views 9 Watching
    sorry,
    Here's the link
    https://forum.myrouteapp.com/topic/11064/compass-is-not-working-properly/8?_=1785773867949
    or
    https://forum.myrouteapp.com/post/81307
    • LennyO
      Ok, thanks to all!
      I guess I needed a mental adjustment to understand that the red segment just says where the North is in relation to the direction I am traveling (to my nose... )
      That said, please confirm that the following pictures show the expected behavior of the Red segment. My map is oriented NORTH, so you can easily see in which direction I am moving. Thank you!
      IMG_0005.jpg IMG_0007.jpg IMG_0010.jpg IMG_0012.jpg IMG_0014.jpg IMG_0016.jpg
      • Marinus van Deudekom
        To me that makes no sense at all. But then again I never use North up.
        Something tells me in top of that it only works when using the dynamic camera view but I'm nooit shure
        LennyO 1 Reply Last reply
          @Marinus-van-Deudekom The behavior of the Red segment is the same in every mode. I just verrified it on a ride this morning. In the Dynamic mode the Blue Arrow in the bottom right acts as a compass too, and it coinsides with the Red segment behavior.
            Agree that it looks strange in the north up view.
            The red sections points to where north is.
            Compared to your physical orientation, not the map on your screen.
            BMcG 2 Replies Last reply
              North is north is north, if the map is north up then north is up
              In north up mode should the red section on the compass not always be at the top & not change?
              • BMcG BMcG
                @Brian-McG Evidently only if you are heading North all the time 🙂
                • Stanisław
                  I think in north-up map orientation, the red segment should simply disappear, as it is not useful 🙂
                  Staszek
                    wrote on last edited by BMcG
                    @Corjan-Meijerink apologies I think I now see your logic about your physical orientation & the direction of the altitude pointer, although for me it took some mental gymnastics to get there
                    the way I think it is working is you have to discount everything else in the MRA display & treat the altitude pointer compass as a separate device, like imagining an old fashioned compass sitting on the fuel cap of your bike
                    if I am riding heading east, then north is on my left shoulder & the altitude pointer compass wil point to the left of my phone screen
                    if I am riding heading west, then north is on my right shoulder & the altitude pointer compass will point to the right of my phone screen
                    again apologies but for me it was just not an intuitive bit of UI
                    • LennyO
                      I also had a hard time with this....
                      I guess the simplest way to grasp the Red segment position in relation to your movement is to imagine yourself sitting inside the elevation circle heading in the 12 o'clock direction.
                        It’s completely correct! Has no relation with the map. Indeed like an actual compass strapped om your screen.
                        It makes sense but in north up it’s confusing.
                        Pinning it north or hiding it will make most sense I guess.
                        • MotoCon
                          It seems current generations do not have much experience with (analogue) compasses anymore 😉
                          Guzzist 1 Reply Last reply
                          • CD130
                            If every change has to preserve the old way of doing things, innovation simply comes to a standstill 😅 Not every new design will be everyone’s favorite right away, but progress sometimes means moving on from older concepts 🧭
                            In another topic, I already mentioned that I’m not a fan of the current display. You now have to constantly think about which direction you’re heading, whereas it should be something you can understand at a glance.
                            Dave J 0 1 Reply Last reply
                              • CD130 CD130
                                @CD130 Agree. Using a compass is to align North and then use the analogue compass to show you direction/heading you need to travel in. I then can use that dereliction to know that I and riding in the correct general direction. Knowing where North is may be fine but it is the direction of travel that matters with the app. I want a simple indication that saves me having to think.
                                Ducati Multistrada V4 Rally
                                iPhone 18 Pro
                                CHIGEE AIO-6 LTE
                                Google Pixel 6 Pro
                                  I've never an old analogue compass at all. Maybe that is the reason why i think it is more logical that the red bar shows the direction your heading and north always is on top on the compass.
                                  If this view is used does the compass then also be more sensible in the North Up view?
                                  • Dave J 0 Dave J 0
                                    Well the red segment always points to the north.
                                    And the four directions have always been North - East - South - West, clockwise!
                                    How simple do yo want!
                                    LennyO Dave J 0 2 Replies Last reply
                                      @white.mouse Actually a compass rose like this or similar instead of just segments would help a lot!
                                        @white.mouse It is simple. As your picture shows with North up and all cardinals marked. However, remove the cardinals and have red segment (North) rotating and you have to start thinking which direction you are heading. This is the point that a lot of people are making with wanting a quick, clear idea of what direction they are travelling in, particularly as the North up view does not allow you to zoom out.
                                        A compass is not just about knowing where North is but allows you to see the direction of travel and other paper map reading uses. I use Scenic app on occasions and the compass is great because I see where North is and, at the top, is the direction of travel as S, SW, SE etc.
                                        This thread also talks about the same issue (for some): https://forum.myrouteapp.com/topic/10855/compass-with-direction/5?_=1786207196667
                                        iPhone 18 Pro
                                        CHIGEE AIO-6 LTE
                                        Google Pixel 6 Pro
                                          In the current situation where the red bar shows north and the bar is on right side of the compass, you need do a conversion to conclude you are riding in west direction. When the red bar shows the direction you're heading. You instant know you're riding to the east.
                                          BMcG 1 Reply Last reply
                                          • 4
                                          Ioan Dragulescu
                                          Ioan Dragulescu
                                          Jim Allen
                                          Jim Allen
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
