  4. Routebook export
Routebook export
6 Posts 3 Posters 2.2k Views 1 Watching
  • BertM
    One thing I would like to see in MRA is the export for a roadbook.
    As I understand MRA is using GraphHopper and GraphHopper can do turn by turn.
    For a simple trip where not everybody has a GPX, or a puzzle route, this would be a nice add
    There are applications that can make roadbooks, like rallynavigator, but those are expensive and overkill for a simple roadbook.
    For now I used Kurviger, that can do the above and exported it to an Excel file as you can see in the example:
    • Travellexxie
      You can get a turn by turn on paper when you export the route as a .pdf file
      BertM 1 Reply Last reply
      • Travellexxie Travellexxie
        @Lex.Kloet.RX said in Routebook export:
        And with a bicycle i can also follow a motorroute.....
        What can I do with a PDF? Nothing except printing!
        Export as CSV has advantages for example that you can change the content to your needs
        • Reinhard-32
          Reinhard-32
          Reinhard-32
          Have you ever tried GPS Babel for this task?
          https://www.gpsbabel.org/
          Kindly regards
          Reinhard
          Montana 700i and Mac
          • Reinhard-32 Reinhard-32
            wrote on last edited by BertM
            @Reinhard-32 said in Routebook export:
            No, as that is not the request.
            There are more programs that can do it like you can see in my first post.
            I would like to see it also in MRA, so I do not have to use Kurviger to do this.
            As it is possible in the routing API I expect it is not a to big deal to implement.
            https://www.graphhopper.com/blog/2023/04/12/leg-based-information/
            I think also the Adventure bikers would like this for creating there Rally roadbooks.
            • BertM
              Just noticed this should be in the Web section and not the App section.
              Maybe someone can move it?
              • Nick Carthew Nick Carthew moved this topic from [App] Suggestions and Discussion on
              Reinhard-32
              Reinhard-32
                Rory Burke
                Rory Burke
