  4. Routebook export
Routebook export
6 Posts 3 Posters 1.1k Views 1 Watching
  • BertMundefined Offline
    One thing I would like to see in MRA is the export for a roadbook.
    As I understand MRA is using GraphHopper and GraphHopper can do turn by turn.
    For a simple trip where not everybody has a GPX, or a puzzle route, this would be a nice add
    There are applications that can make roadbooks, like rallynavigator, but those are expensive and overkill for a simple roadbook.
    For now I used Kurviger, that can do the above and exported it to an Excel file as you can see in the example:
    • Lex.Kloet.RXundefined Offline
      Lex.Kloet.RX
      You can get a turn by turn on paper when you export the route as a .pdf file
      BertMundefined 1 Reply Last reply
      • Lex.Kloet.RXundefined Lex.Kloet.RX
        @Lex.Kloet.RX said in Routebook export:
        And with a bicycle i can also follow a motorroute.....
        What can I do with a PDF? Nothing except printing!
        Export as CSV has advantages for example that you can change the content to your needs
        • Reinhard-32undefined Do not disturb
          Reinhard-32
          Have you ever tried GPS Babel for this task?
          https://www.gpsbabel.org/
          Kindly regards
          Reinhard
            wrote on last edited by BertM
            @Reinhard-32 said in Routebook export:
            No, as that is not the request.
            There are more programs that can do it like you can see in my first post.
            I would like to see it also in MRA, so I do not have to use Kurviger to do this.
            As it is possible in the routing API I expect it is not a to big deal to implement.
            https://www.graphhopper.com/blog/2023/04/12/leg-based-information/
            I think also the Adventure bikers would like this for creating there Rally roadbooks.
              Just noticed this should be in the Web section and not the App section.
              Maybe someone can move it?
              • Nick Carthewundefined Nick Carthew moved this topic from [App] Suggestions and Discussion on
              Lex.Kloet.RX
              BertMundefined
              Reinhard-32
              • Unable to stop navigation
                1.1k
              • Waypoints missing in 5.0.3 when navigating as track
                Herman Veldhuizenundefined
              • Suggestions For Nice Route From Rotterdam tp Spa
                Alan Daubneyundefined
                Alan Daubney
              • Carpe Iter Caretta
                Martin Wilckeundefined
                Martin Wilcke
              • Web planner SKIP button
                Stephan Dornbergundefined
                Stephan Dornberg
              • MRA connector won't see my pc-connected BMW Navigator (tomtom version, 2024 yr)
                Stephan Dornberg
                1.9k
              • Probleem met ANDROID in de wagen.
                M PRPundefined
                M PRP
