  2. Routes & Tracks
  3. New Zealand Routes
New Zealand Routes
22 Posts 5 Posters 2.9k Views 1 Watching
  • Bull Tahr Bull Tahr
    @BertM I switched them back to Friends until I'm confident they are following the MRA Standards for Routes. I'll friend you and if you can have a look and let me know if they are up to snuff, be greatly appreciated! Cheers B
    @Bull-Tahr It’s not MRA standards that your routes need to follow. But they do need to be accurately defined and if your intention is for other users to use them, then the routes should also be adjusted so that all planning maps follow the same routes.
    These are of course the minimum standards that MRA RouteXpert routes use but they are also standards that as route planners we should all follow.
    Bull Tahr 1 Reply Last reply
      Bull Tahr
      Bull Tahr
      Bull Tahr
      Could you spare a few minutes and check a few of mine for format etc, esp since you have ridden some of these roads.....
      πŸŽ₯ YouTube: https://www.youtube.com/@DustyVisorMotorcycles
      🌐 https://linktr.ee/dustyvisor
      πŸ“˜ Facebook: https://www.facebook.com/dustyvisormotorcycles/
      πŸ“· Instagram: https://www.instagram.com/dustyvisormotorcycles/
      • BertM
        wrote on last edited by BertM
        @bull-tahr To get your routes visible in your route libary you must use the Car profile and not the motor profile, this is a bug in the program that hopefully will be solved in the upcomming version.
        routes are looking good, one comments and this is what I prefer.
        On the below you have the stop as a Via point, I personal do not use via points for that, as it is a choice to stop. with a via point you must always hit the point otherwise the program will always lead you back to that point. To hit the point on a busy carpark will be a challange.
        • Bull Tahr
          Bull Tahr
          Bull Tahr
          True that, I can adjust the Via back to the highway. I thought that Photo stops are preferred as Vias and not just points, this is why, but I understand what you are saying about having to go thru a very busy carpark! I will adjust. Thanks so much.
          BertM 1 Reply Last reply
          • Bull Tahr
            Bull Tahr
            Bull Tahr
            All adjusted, I think. 1 thing, Viewpoint and Camera POIs, just wondering why these are 2 seperate POI catergories and not the same thing really. If it's worth looking at, you might want to stop and take a photo??
              You are right that it should be a via point with your explanation
                At Every viewpoint you can take a photo but not every place you take a photo is a viewpointπŸ˜‰
                • BertM BertM
                  To see the routes of a friend you must be friends and the routes must be set to at least friends to see them in your friends library.
                  The car or bike profile is of no interest.
                  However if you use the bike profile bare in mind that those routes, once exported by the recipiΓ«nt to their nav can't be used since Garmin does not allow the bike profile. Therefore the carefully composed route will be recalculated by the Garmin and thus messed up.
                  My advise use the car profile like all the RouteXperts do
                  • Bull Tahr
                    Bull Tahr
                    Bull Tahr
                    Got that, Car Profile. Good to know. Cheers,
                    Bull
                      I do not know why you mentioned this as it is confirmed a bug in the webapplication.
                      @bull-tahr :
                      if you want to get the routes visible in your libary you have to set them to "Public", use the Car profile AND you have to publish you route.
                      your libary is still not visable so I presume you have not published your routes.
                      I can see you still have some routes with the motor profile
                      if the above criteria are met , you should see the routes in your profile:
                      To prove the remark about the bug, when the routes are visible in your libary, switch one back to the "motor" modus and you will see it will not pop-up anymore in your libary.
                      Bull Tahr Marinus van Deudekom 2 Replies Last reply
                      • BertM BertM
                        @bull-tahr :
                        Bull Tahr
                        Bull Tahr
                        Bull Tahr
                        @BertM Thanks for all that. The South Island folder is now all published, car mode and public to view. In library tab I only see 30 routes in New Zealand all RouteXpert, none of mine. Maybe it's Route Expert only or I am on the basic account ATM.... Either way, you should be able to see the South Island folder and routes now.
                        Thanks for all the help!
                        • BertM BertM
                          @bull-tahr :
                          @bull-tahr :
                          I did not
                            @bull-tahr :
                            I did not
                            What the word says: it is conformed by the Developers that it is a bug in the system.
                            If you want to publish your routes in the libary and do not know this bug and as @bull-tahr use the motor mode they will never show up.
                            It that simple.
                            • Bull Tahr
                              Bull Tahr
                              Bull Tahr
                              Try them now Bert, All edited to the settings you mentioned... Thanks.
                                @bull-tahr
                                Succes! I can see the routes now πŸ˜‰
                                • BertM
                                  @bull-tahr
                                  LOL
                                  Clear how the Kiwi's think of our driving πŸ™‚
                                  • Marinus van Deudekom
                                    Maybe I have magical fingers because I could see all of his routes from the start
                                    Bull Tahr
                                    Bull Tahr
                                    A Former User?
                                    [[global:former-user]]
                                      JP d
                                      JP d
                                      2.4k
                                      Guzt
                                      Guzt
                                      1.8k
                                    • Beta abonnement
                                      BMW1300GSA
                                      BMW1300GSA
                                    • SilverFox Controller C2
                                      Hans Lamers
                                      Hans Lamers
                                    • Nieuw startpunt
                                      Jeroen ekkel c
                                      Jeroen ekkel c
                                      1.3k
                                    • Tracklog to Routetrack Conversion & Creation
