  3. [App] Announcements
  4. New update 5.2 - Avoid roadblocks, persistent map items, POI management and share
61 Posts 32 Posters 13.8k Views 13 Watching
  • KeesV
    KeesV
    KeesV
    When driving tracks the "Roadblock" feature is not available. Will this become available later?
    Axel Härtl 1 Reply Last reply
    • KeesV KeesV
      Axel Härtl
      Axel Härtl
      Axel Härtl
      #41
      @KeesV
      Hi Kees,
      By definition, tracks (unlike routes) are followed exactly as specified. A deviation—in this case, a detour due to a road closure—is therefore generally not provided for.
      Best, Axel
      BMW R 1200 RT
      Tourenorientiert
      MRA lifetime member
      • Marinus van Deudekom
        It's on the wishlist
        KeesV 1 Reply Last reply
          KeesV
          KeesV
          KeesV
          @Marinus-van-Deudekom
          Thanks, that's good to know!
          • Aiello antonino
            #44
            I can't figure out how to change the settings for for example, AVOID HIGHWAY, without having to restart everything... thanks!
              @Aiello-antonino Whilst the navigation is running... click on the three dots in the bottom right-hand corner, then go to ‘Avoidance options’ and enable the desired settings.
              The system will recalculate immediately.
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Motorola Edge 40 "offline"
              Sena SLR 3
              Sena 50 R
              • Aiello antonino
                Thanks! I didn't see there were other options on the menu! Excellent!
                • Kirsten De Weerd
                  Kirsten De Weerd
                  Kirsten De Weerd
                  Any plans on making the Roadblock feature available on CarPlay?
                  Or is it hidden somewhere and haven't I found it yet?
                  • Kirsten De Weerd Kirsten De Weerd
                    @Kirsten-De-Weerd needs to be added later!
                    • Sigurður Pétursson 0
                      I'm on 5.2.1 on iPhone and I can't see the new featured, like RoadBlock and changing avoidance while navigating a route?
                      • Sigurður Pétursson 0 Sigurður Pétursson 0
                        @Sigurður-Pétursson-0 While navigating a route open the navigation menu, three dots bottom right of the screen.
                        Sigurður Pétursson 0 1 Reply Last reply
                          @Nick-Carthew I tried that, however, if I select a single destination and Navigate, I have all the options, RoadBlock and Avoidance, just not when I select one of the routes from my library!
                            @Sigurður-Pétursson-0 That is because you have Navigate routes as tracks selected. Go to Navigation settings > Functional > Track navigation and turn off Navigate routes as tracks
                              Hi @nick-carthew, I've checked but I'm struggling to find this important point documented in the manual anywhere! Perhaps I missed it.
                              Nick Carthew Sigurður Pétursson 0 2 Replies Last reply
                              • Stevedo 6 0 Stevedo 6 0
                                @Stevedo-6-0 A track cannot be manipulated the same way that a route can, hence the Roadblock option is not an option for track navigation. There is a mention that route and track navigation have their differences in section 7 - Navigation of the Mobile app manual.
                                  Hi @nick-carthew, I already understood everything you just wrote. The issue that @sigurður-pétursson-0 has is that he does not have all (some?) of the roadblock options when he navigates routes as tracks. Clearly that was something he was expecting to work. You suggested that he needs to turn off the option Navigate routes as tracks for the roadblock function to work. I'm sure you are correct here.
                                  My point is, this important point is not documented. Why not add a single sentence to the Roadblock section of the manual clearly identifying this difference.
                                  Please don't insult me by suggesting that the text you copied i.e. "The most important thing to know is that there are slight differences between these navigation styles." in any way covers it. What am I supposed to do, guess what these differences are?
                                  Nick Carthew Guzzist MotoCon 3 Replies Last reply
                                    #56
                                    @Stevedo-6-0 When the Roadblock feature was introduced, the text in the announcement clearly states 'While navigating a route' and the word route is emphasised by using bold text.
                                    Without fear of insulting you, I will use another screenshot from the manual that shows the instructions for Roadblocks. The word route is used 3 times.
                                    I see you have just created another topic in this forum" https://forum.myrouteapp.com/topic/11455/missing-functionality-in-mra-next
                                    Why not make a list of your criticisms/suggestions and put them in a support ticket.
                                      @Stevedo-6-0 ...I will not blame you, but let me kindly ask: are you sure you do understand clearly the difference about route and track?
                                      In a route, you have only a couple of route points, and each Navi device/app calculate the possible way from one point to the next. There is space for different interpretation in case, several streets could be used to reach the next point.
                                      In a track, you have thousands of tracks points, and usually no Navi device/app calculates and guides you. You simply have to follow the drawn line on the map. Except: MyRoute-App Navigation Next is able to navigate you also by a track.
                                      But because of the thousands of track points, there is no space for different interpretation by different Navi devices/apps. In consequence: there is no space to suggest detours in case of road blocks.
                                      You are right: it should be clearly described in focus for beginners. But if you have learned about tracks, routes, gpx data - it's clear without very detailed descriptions. 😉
                                        @Stevedo-6-0, no one is here to insult anybody, please keep this in mind.
                                        I really wish everyone would take the effort of reading the manual as carefully as you, that would certainly be visible in the amount of questions in this forum. On the other hand, if all those people would trip over the same small issues, we would have an explosion of topics 😉
                                        I think @nick-carthew did a good suggestion of gathering your findings. It would make a nice guideline for support to attack and refine the manual. Remember, MRA is a very small team, which makes it a challenge to have everything correct at the right time.
                                          @Nick-Carthew Thank you, that was exactly that. I've turned of Navigate as Track and got all the features in every route. The reason it was on in the first place was to prevent the Navigator to take shortcuts between my way/shaping points. If that happens again, I guess I just need more way/shaping points.
                                          Thank you for your help
                                          • 4
                                          Cookie On Tour
                                          Cookie On Tour
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          Edwin_M
                                          Edwin_M
                                          Garry Davis
                                          Garry Davis
                                          Axel Härtl
                                          Axel Härtl
                                          KeesV
                                          KeesV
                                          Jon Hye-Knudsen
                                          Jon Hye-Knudsen
                                          Rae Sewell
                                          Rae Sewell
                                            Marcel Versluis
                                            Marcel Versluis
                                          • MRA Navigation Next: Synchronisation by folder
                                            Parantapa
                                            Parantapa
                                            TomOnTour
                                            TomOnTour
                                          • Android Auto TFT
                                          • Route punt overslaan
                                          • Notche
                                            Adriaan Vonk
                                            Adriaan Vonk
