  3. [App] Announcements
  4. New update 5.2 - Avoid roadblocks, persistent map items, POI management and share
61 Posts 32 Posters 13.8k Views 13 Watching
    @Cookie-On-Tour said:
    One thing, on Car Play/Android Auto - pressing the gas station button that shows the nearest gas station should add the station to the route on the fly as a waypoint.
    That's how it works in the app, but not on AA/CP, since there it is no button (prohibited) but just an info tile. The intended gas station will be the first suggestion when you go into the menu to add a gasstation.
    Cookie On Tour
    Cookie On Tour
    Cookie On Tour
    Strange, why should that be prohibited??? There are already buttons to stop or change things. At Google Maps you also have buttons to report construction zones, accidents, there is a button to add another destination and more.
    So a simple button, that would not even change the entire screen/interface, that would just add a stop behind the scene to the route should not be possible?
    Joerg
    (Cookie-On-Tour.de)
      Ask Google or Apple; the restrictions in AA/CP are unbelievable. I believe the MRA team would make it possible if not restricted.
        #38
        Nice update. First time I rode multiple days with a version which has the yellow arrows on the routeline. Very good idea/suggestion. A few times it helped me solving direction questions.
        Stability wise. MRA has come a long way. But please keep pushing on the stability. There are still issues.
        1.
        Had it before.
        Today I rode under bridge and on that exact moment MRA hangs. GPS loss. Restarting the route solved the issue.
        This is more though
        After lunch MRA wouldn't start navigating. Map with route was visible. But current speed and altimeter stayed empty (--). Restarting the route or app did not solve the problem. I had to reboot the whole phone to get it solved. That shouldn't be a solution. Ideally restarting the app should be the most severe solution to solve problems.
        It costed me 5-10 minutes to solve this problem today.
        • Marinus van Deudekom
          With AA it seems to depend on your configuration. You have some serious problems. On the other hand I dont at all and that makes me wonder. I had a Skoda yeti with a Dutch brand screen in it witch was put in when I bought the car. No problems there. I recently bought a Kia Niro EV with the factory entertainment screen in it and that doesn't give me any problems either. To say it in Dutch, schiet mij maar lek. My phone stayed the same one the screens changed.
          • KeesV
            KeesV
            KeesV
            When driving tracks the "Roadblock" feature is not available. Will this become available later?
            Axel Härtl 1 Reply Last reply
            • KeesV KeesV
              Axel Härtl
              Axel Härtl
              Axel Härtl
              #41
              @KeesV
              Hi Kees,
              By definition, tracks (unlike routes) are followed exactly as specified. A deviation—in this case, a detour due to a road closure—is therefore generally not provided for.
              Best, Axel
              BMW R 1200 RT
              Tourenorientiert
              MRA lifetime member
                It's on the wishlist
                KeesV 1 Reply Last reply
                  KeesV
                  KeesV
                  KeesV
                  @Marinus-van-Deudekom
                  Thanks, that's good to know!
                  • Aiello antonino
                    #44
                    I can't figure out how to change the settings for for example, AVOID HIGHWAY, without having to restart everything... thanks!
                      @Aiello-antonino Whilst the navigation is running... click on the three dots in the bottom right-hand corner, then go to ‘Avoidance options’ and enable the desired settings.
                      The system will recalculate immediately.
                      BMW R 1250 GS
                      DMD-NOR7E 7"
                      SPC Universal mount
                      Motorola Edge 40 "offline"
                      Sena SLR 3
                      Sena 50 R
                      • Aiello antonino
                        Thanks! I didn't see there were other options on the menu! Excellent!
                        • Kirsten De Weerd
                          Kirsten De Weerd
                          Kirsten De Weerd
                          Any plans on making the Roadblock feature available on CarPlay?
                          Or is it hidden somewhere and haven't I found it yet?
                          • Kirsten De Weerd Kirsten De Weerd
                            @Kirsten-De-Weerd needs to be added later!
                            • Sigurður Pétursson 0
                              I'm on 5.2.1 on iPhone and I can't see the new featured, like RoadBlock and changing avoidance while navigating a route?
                              • Sigurður Pétursson 0 Sigurður Pétursson 0
                                @Sigurður-Pétursson-0 While navigating a route open the navigation menu, three dots bottom right of the screen.
                                Sigurður Pétursson 0 1 Reply Last reply
                                  @Nick-Carthew I tried that, however, if I select a single destination and Navigate, I have all the options, RoadBlock and Avoidance, just not when I select one of the routes from my library!
                                    @Sigurður-Pétursson-0 That is because you have Navigate routes as tracks selected. Go to Navigation settings > Functional > Track navigation and turn off Navigate routes as tracks
                                      Hi @nick-carthew, I've checked but I'm struggling to find this important point documented in the manual anywhere! Perhaps I missed it.
                                      Nick Carthew Sigurður Pétursson 0 2 Replies Last reply
                                      • Stevedo 6 0 Stevedo 6 0
                                        @Stevedo-6-0 A track cannot be manipulated the same way that a route can, hence the Roadblock option is not an option for track navigation. There is a mention that route and track navigation have their differences in section 7 - Navigation of the Mobile app manual.
                                          Hi @nick-carthew, I already understood everything you just wrote. The issue that @sigurður-pétursson-0 has is that he does not have all (some?) of the roadblock options when he navigates routes as tracks. Clearly that was something he was expecting to work. You suggested that he needs to turn off the option Navigate routes as tracks for the roadblock function to work. I'm sure you are correct here.
                                          My point is, this important point is not documented. Why not add a single sentence to the Roadblock section of the manual clearly identifying this difference.
                                          Please don't insult me by suggesting that the text you copied i.e. "The most important thing to know is that there are slight differences between these navigation styles." in any way covers it. What am I supposed to do, guess what these differences are?
                                          Nick Carthew Guzzist MotoCon 3 Replies Last reply
                                          • 4
                                          Cookie On Tour
                                          Cookie On Tour
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          Edwin_M
                                          Edwin_M
                                          Garry Davis
                                          Garry Davis
                                          Axel Härtl
                                          Axel Härtl
                                          KeesV
                                          KeesV
                                          Jon Hye-Knudsen
                                          Jon Hye-Knudsen
                                          Rae Sewell
                                          Rae Sewell
                                            Marcel Versluis
                                            Marcel Versluis
                                          • MRA Navigation Next: Synchronisation by folder
                                            Parantapa
                                            Parantapa
                                            TomOnTour
                                            TomOnTour
                                          • Android Auto TFT
                                          • Route punt overslaan
                                          • Notche
                                            Adriaan Vonk
                                            Adriaan Vonk
