Audio cuttet via Bluetooth
The same issue with current final and previous final release. The slider doesn't work as it should.
When you adjust the slider the whole direction chain will be delayed incl. the command to open the audio channel. -
@corjan-meijerink : any News about this Problem?
@corjan-meijerink Hello Corjan, is the delay Problem solved with the latest update?
Fya: I did a Test Today. The Delay is still there and so the App is not useable for me.
Also no response from you @corjan-meijerink
This is not very friendly! -
I did my first ride of the year today and used verion 5.0.4 (451). Till the lunch the audio seems fine, but i'm not sure. I did not pay much attention to it. After the lunch i noticed a missing part at the beginning of the instructions.
My audio delay was already set to 1 sec. Therefore i started playing with the delay and hoped to hear some difference.
I did hear differences but not what i expected.I did not matter if I set the delay to 0 or 2 seconds. The first small part of the directions was always missing.
The only thing what happens was the delay when the instructions were spoken. With the of 2 sec delay, the instructions came 2 seconds later.B.t.w I have a Sena SRL 3 headset.
@M.-Schrijver
Hello M.
have you still the Audio Problem like me?
First second of the Audio command is missing.Thanks and regards
Günter -
With the last version I don't know. I did one ride with the lastest was focused on the separation of audio channels in Android Auto. That works fine.
during this test i had media playing and MRA did it's thing. All was clear and complete. In previous versions in this setting. MRA was a bit low on volume but everything was there (both on the same audio channel). When only MRA was active, i heard only partially directions. The audio delay function doesn't help in this case (anymore). It simple shifts the whole sequence (open the channel, give directions and closing the channel) according the set delay. -
This is not very friendly!This is not very friendly!
It's still a public forum and this is not a support ticket
Pushing me definitely won't help me finding motivation for looking into an issue one users reports.From my point of view: the issue was fixed (and confirmed fixed). We haven't touched it since. Only updated another independent Android Auto audio channel issue with luckily is now also solved.
To be fair, I don't really see many complaints about this.
The biggest issue with the Android Auto audio channels has been solved. -
We take all feedback serious but please, create a support ticket.
Then we have an official way to communicate.
Obviously audio is critical. -
Check the settings between the devices they use and then use it in the app under Settings
Then you would have to have your ges. Describe installation ..
All individual devices and how you have coupled something otherwise we can not help you.
I use an iPhone Xr on the R1250GS in the BMW-Cradel and do not know this problem ...
iPhone paired with TFT - motorcycle
Helmet coupled with TFT - motorcycle
Hello, on Version 6 same problem.
Anybody else?@Haug dus you follow up on Corjan's advise to create a support ticket
