  4. Navigation stopped working during Tour
89 Posts 24 Posters 28.3k Views 9 Watching
  • Thomas Neumeyer
    Thomas Neumeyer
    Thomas Neumeyer
    Thank you Peter
      I translated it. Its a different problem. The routing stops and the position arrow does not move anymore. Closing the app does not help. It's asking if I want to continue the tour but its not follo8my movement. Only after several times closing the app it works but not for good and stopped again. So far no news about my ticket sent.
      Qualo
      Qualo
      Qualo
      @Thomas-Neumeyer
      Hola Thomas
      Es exactamente el mismo problema. Pasadas una 2 / 3 horas la pantalla se congela y no recibo instrucciones, y el reinicio de la app no soluciona nada. Otras apps funcionan perfectamente.
      Ulefone me indica si quiero devolverla o si quiero enviarles el report de uso para ver que ocurre, pero esto último me han enviado instrucciones a medias y creo que la devolveré y listo, no quiero perder mas tiempo.
      Hi Thomas
      It's exactly the same problem. After 2 or 3 hours, the screen freezes and I don't receive any instructions, and restarting the app doesn't fix anything. Other apps work perfectly. Ulefone is asking if I want to return it or send them a usage report to see what's happening, but they only sent me half-baked instructions for the latter, and I think I'll just return it and be done with it; I don't want to waste any more time.
      • Thomas Neumeyer
        Thomas Neumeyer
        Thomas Neumeyer
        Thanks for sharing. I will contact Ulefone. Maybe they take it back. I just liked the brightness of the screen. Regards Thomas
        Marinus van Deudekom Qualo 2 Replies Last reply
          Another 1000 km with the latest MRA version without any issues.
            @Thomas-Neumeyer as a last resort. Did you try setting it back to Factory settings and then start from scratch. Seems weird that you’re the only one with troubles. Maybe it works
              Additionally, are there any other apps running in the background?
              • Thomas Neumeyer
                Thomas Neumeyer
                Thomas Neumeyer
                I made factory reset two times and no, there are no other apps in background. I also just installed myroute app to avoid any issues. I contacted Ulefone, lets see how this works. Strange is just that all other Apps for navigation are working.
                • Thomas Neumeyer
                  Thomas Neumeyer
                  Thomas Neumeyer
                  And it seems that at least another user has the same problem with Ulefone.
                  • Marinus van Deudekom
                    What does Ulefone say.
                    If they dont offer a solution mabey MRA support van help out via a ticket
                    Thomas Neumeyer 1 Reply Last reply
                      I experienced exactly this last weekend. I cannot say it was temperature but it was hot. What is says above matches exactly my experience. Swipe-closing the app did not help, rebooting the phone did. Probably a force-close from the Android Apps menu would have solved it to. For me, this is the only resembling experience I had during a 4 day ride. I blame the phone... 😉
                        Thomas Neumeyer
                        Thomas Neumeyer
                        Thomas Neumeyer
                        @Marinus-van-Deudekom First answer was a question since when this is the case....
                        • Thomas Neumeyer
                          Thomas Neumeyer
                          Thomas Neumeyer
                          I got some feedback from Ulefone, they stated it is the app with some incompatibility and I should use some other navigation app. 🙂
                            That was way to easy for them to blame the other party instead of investigations it themselves.
                            • Thomas Neumeyer
                              Thomas Neumeyer
                              Thomas Neumeyer
                              That's true, but it seems to be the case that I am not the only one with issues. I am just at the moment at home and I have no longer trip planned. Last two weeks I made 4000 km and it was not a perfect experience with Ulefone/MyRoute. Check still the Samsung.
                                You could sent a ticket including the logfiles. Maybe tech support can take a look at it just to be shure
                                • Thomas Neumeyer
                                  Thomas Neumeyer
                                  Thomas Neumeyer
                                  I did this already. Nothing they can find.
                                    Then report that back to Ulefone
                                      Qualo
                                      Qualo
                                      Qualo
                                      @Thomas-Neumeyer
                                      Yo he devuelto la tableta. Lo que más me interesaba era la luminosidad de la pantalla, como a ti. Contacté con ulefone y me ofrecieron devolución o intentar averiguar que ocurre.
                                      Decidí saber wue ocurre, pero el método era probar de nuevo grabando desde mi móvil y activar el modo recopilación de Android.
                                      Finalmente la devolví, no tengo tanto tiempo para eso...
                                      I returned the tablet. What interested me most was the brightness of the screen, like you. I contacted ulefone and they offered me a return or try to find out what is happening.
                                      I decided to find out what's going on, but the method was to try again by recording from my phone and turn on Android collection mode.
                                      I finally gave it back, I don't have that much time for that.
                                      After summer (too hot to route all day...) I will consider a Samsung Active Tab 5, an Android screen or stick with my old Samsung S21 that works perfectly.
                                        @Thomas-Neumeyer, or you should use another phone... I guess you told them that too? 😉
                                        • Bouke Ent
                                          i have ulefone armor x10 and that runs MRA now fine without any problems. mine runs android 12 i believe and there is not much bloteware on it. i run 5.1 beta. my only problem is spinning screen when standing still but that is a know Here problem.
                                          with version 5.0 i had some problems like craches/freese or delay but with 5.1 i work good.
                                          i only use phone for MRA and i do not play music. no AA and no recalculation.
                                          • 4
                                          • 5
                                          Òscar
                                          Òscar
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          OGRIII
                                          OGRIII
                                          Léon Hassing
                                          Léon Hassing
                                          TuonoPants
                                          TuonoPants
                                          Qualo
                                          Qualo
                                          guenniguenzelsen
                                          guenniguenzelsen
                                          Raul Arteaga
                                          Raul Arteaga
                                          Chalkster 0
                                          Chalkster 0
                                          rofowe
                                          rofowe
                                          Scottish Biker Abroad
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.5k
                                          • One crash today
                                          • Download club route folders
                                            peha
                                            peha
                                            Mosimann
                                            Mosimann
                                          • Elektrisch rijden
                                            John mq
                                            John mq
