  4. Navigation stopped working during Tour
89 Posts 24 Posters 18.3k Views 9 Watching
  • Thomas Neumeyer Offline
    Thomas Neumeyer
    Hello Con, yes I sent the log file. Today the same issue. Navigation was perfect for three hours and then it stopped. Restart was possible but map was frozen. Without another app I would have been in trouble. Yesterday I put tablet to factory settings and installed the app new. No joy.
      @Thomas-Neumeyer, Even when it freezes like you experienced, instead of using another app you can also just restart the MRA app, is it not?
        Thomas Neumeyer
        I did this many times. App starts but map ist not moving. And I can not stop every hundert meters and restart again and hope that it works. I really love the App but at the moment I dont use it.
        white.mouse 1 Reply Last reply
        • Peter Zehentreiter Online
          Did a 400 km ride today, App worked without any problem.
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
            Thomas Neumeyer
            That’s great to hear Peter. I have to report that not a single day the app was working without freezing. Nothing helped, no factory reset of the tablet and fresh installation. I can not use it anymore. Maybe it’s just on the Ulefone. I try Samsung when I am at home.
            b0hd1 1 Reply Last reply
            • guenniguenzelsen Offline
              guenniguenzelsen
              Hi
              For me (as I have started this topic), the issue seems to be solved.
              During my two-days tour it was working as expected with the updated v5.1.
              Thanks
              Thomas
                b0hd1 Offline
                b0hd1 Offline
                @Thomas-Neumeyer On a Spanish BMW forum, there is another member with problems with Ulefone and MRA.
                • https://t.me/MRa_by_b0hd1
                • YouTube: @demco17
                  Thomas Neumeyer
                  What does it says in the forum? I really love the app and I don't want to give it up. It's just always the same after several hours. Tab is also not hot or something. I can perfectly continue with maps, osmand and dmd2 (which is not made for touring). Thomas
                    Thomas Neumeyer
                    I translated it. Its a different problem. The routing stops and the position arrow does not move anymore. Closing the app does not help. It's asking if I want to continue the tour but its not follo8my movement. Only after several times closing the app it works but not for good and stopped again. So far no news about my ticket sent.
                    Qualo Con Hennekens 2 Replies Last reply
                      Thomas Neumeyer
                      Last tour yesterday from south Germany to north. Same issue after about two hours map stopped to move like GPS was stopping in the app. App itself was working but position was on the same spot after restart.
                        white.mouse Offline
                        white.mouse Offline
                          @Thomas-Neumeyer Hi Thomas, I am sorry to hear that you have some bad experience.
                          I was driving yesterday over 500 km without any problem.
                          I guess your current problems are related to the Ulefone.
                          Hopefully you will have a better experience when you'll try another phone.
                          I know it doesn't help right know.......
                          Best regards
                          Peter
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Sena SLR 3
                          Sena 50 R
                            Thomas Neumeyer
                            Thank you Peter
                              Qualo Offline
                              Qualo Offline
                              Qualo
                              @Thomas-Neumeyer
                              Hola Thomas
                              Es exactamente el mismo problema. Pasadas una 2 / 3 horas la pantalla se congela y no recibo instrucciones, y el reinicio de la app no soluciona nada. Otras apps funcionan perfectamente.
                              Ulefone me indica si quiero devolverla o si quiero enviarles el report de uso para ver que ocurre, pero esto último me han enviado instrucciones a medias y creo que la devolveré y listo, no quiero perder mas tiempo.
                              Hi Thomas
                              It's exactly the same problem. After 2 or 3 hours, the screen freezes and I don't receive any instructions, and restarting the app doesn't fix anything. Other apps work perfectly. Ulefone is asking if I want to return it or send them a usage report to see what's happening, but they only sent me half-baked instructions for the latter, and I think I'll just return it and be done with it; I don't want to waste any more time.
                                Thomas Neumeyer
                                Thanks for sharing. I will contact Ulefone. Maybe they take it back. I just liked the brightness of the screen. Regards Thomas
                                Marinus van Deudekom Qualo 2 Replies Last reply
                                • Jörgen Offline
                                  Jörgen Offline
                                  Another 1000 km with the latest MRA version without any issues.
                                    Marinus van Deudekom Offline
                                    @Thomas-Neumeyer as a last resort. Did you try setting it back to Factory settings and then start from scratch. Seems weird that you’re the only one with troubles. Maybe it works
                                    • Jörgen Offline
                                      Jörgen Offline
                                      Additionally, are there any other apps running in the background?
                                        Thomas Neumeyer
                                        I made factory reset two times and no, there are no other apps in background. I also just installed myroute app to avoid any issues. I contacted Ulefone, lets see how this works. Strange is just that all other Apps for navigation are working.
                                          Thomas Neumeyer
                                          And it seems that at least another user has the same problem with Ulefone.
                                          • 4
                                          • 5
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          TuonoPants
                                          TuonoPants
                                          Léon Hassing
                                          Léon Hassing
                                          Qualo
                                          Qualo
                                          guenniguenzelsen
                                          guenniguenzelsen
                                          Raul Arteaga
                                          Raul Arteaga
                                          Chalkster 0
                                          Chalkster 0
                                          rofowe
                                          rofowe
                                          OGRIII
                                          OGRIII
                                          Scottish Biker Abroad
                                          • Route app reageert niet
                                            Erik Schouten
                                            Erik Schouten
                                            TomOnTour
                                            TomOnTour
