  4. Navigation stopped working during Tour
89 Posts 24 Posters 21.1k Views 9 Watching
  • Thomas Neumeyer Offline
    Thomas Neumeyer
    That’s great to hear Peter. I have to report that not a single day the app was working without freezing. Nothing helped, no factory reset of the tablet and fresh installation. I can not use it anymore. Maybe it’s just on the Ulefone. I try Samsung when I am at home.
    b0hd1 1 Reply Last reply
    • guenniguenzelsen Offline
      guenniguenzelsen
      Hi
      For me (as I have started this topic), the issue seems to be solved.
      During my two-days tour it was working as expected with the updated v5.1.
      Thanks
      Thomas
        b0hd1 Offline
        b0hd1 Offline
        @Thomas-Neumeyer On a Spanish BMW forum, there is another member with problems with Ulefone and MRA.
        • https://t.me/MRa_by_b0hd1
        • YouTube: @demco17
          Thomas Neumeyer
          What does it says in the forum? I really love the app and I don't want to give it up. It's just always the same after several hours. Tab is also not hot or something. I can perfectly continue with maps, osmand and dmd2 (which is not made for touring). Thomas
            Thomas Neumeyer
            I translated it. Its a different problem. The routing stops and the position arrow does not move anymore. Closing the app does not help. It's asking if I want to continue the tour but its not follo8my movement. Only after several times closing the app it works but not for good and stopped again. So far no news about my ticket sent.
            Qualo Con Hennekens 2 Replies Last reply
              Thomas Neumeyer
              Last tour yesterday from south Germany to north. Same issue after about two hours map stopped to move like GPS was stopping in the app. App itself was working but position was on the same spot after restart.
                I did this many times. App starts but map ist not moving. And I can not stop every hundert meters and restart again and hope that it works. I really love the App but at the moment I dont use it.
                  Peter Zehentreiter Offline
                  @Thomas-Neumeyer Hi Thomas, I am sorry to hear that you have some bad experience.
                  I was driving yesterday over 500 km without any problem.
                  I guess your current problems are related to the Ulefone.
                  Hopefully you will have a better experience when you'll try another phone.
                  I know it doesn't help right know.......
                  Best regards
                  Peter
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Motorola Edge 40 "offline"
                  Sena SLR 3
                  Sena 50 R
                    Thomas Neumeyer
                    Thank you Peter
                      Qualo Offline
                      Qualo Offline
                      Qualo
                      @Thomas-Neumeyer
                      Hola Thomas
                      Es exactamente el mismo problema. Pasadas una 2 / 3 horas la pantalla se congela y no recibo instrucciones, y el reinicio de la app no soluciona nada. Otras apps funcionan perfectamente.
                      Ulefone me indica si quiero devolverla o si quiero enviarles el report de uso para ver que ocurre, pero esto último me han enviado instrucciones a medias y creo que la devolveré y listo, no quiero perder mas tiempo.
                      Hi Thomas
                      It's exactly the same problem. After 2 or 3 hours, the screen freezes and I don't receive any instructions, and restarting the app doesn't fix anything. Other apps work perfectly. Ulefone is asking if I want to return it or send them a usage report to see what's happening, but they only sent me half-baked instructions for the latter, and I think I'll just return it and be done with it; I don't want to waste any more time.
                        Thomas Neumeyer
                        Thanks for sharing. I will contact Ulefone. Maybe they take it back. I just liked the brightness of the screen. Regards Thomas
                        Marinus van Deudekom Qualo 2 Replies Last reply
                        • Jörgen Offline
                          Jörgen Offline
                          Another 1000 km with the latest MRA version without any issues.
                            Marinus van Deudekom Offline
                            @Thomas-Neumeyer as a last resort. Did you try setting it back to Factory settings and then start from scratch. Seems weird that you’re the only one with troubles. Maybe it works
                            • Jörgen Offline
                              Jörgen Offline
                              Additionally, are there any other apps running in the background?
                                Thomas Neumeyer
                                I made factory reset two times and no, there are no other apps in background. I also just installed myroute app to avoid any issues. I contacted Ulefone, lets see how this works. Strange is just that all other Apps for navigation are working.
                                  Thomas Neumeyer
                                  And it seems that at least another user has the same problem with Ulefone.
                                    What does Ulefone say.
                                    If they dont offer a solution mabey MRA support van help out via a ticket
                                    Thomas Neumeyer 1 Reply Last reply
                                      I experienced exactly this last weekend. I cannot say it was temperature but it was hot. What is says above matches exactly my experience. Swipe-closing the app did not help, rebooting the phone did. Probably a force-close from the Android Apps menu would have solved it to. For me, this is the only resembling experience I had during a 4 day ride. I blame the phone... 😉
                                        Thomas Neumeyer
                                        @Marinus-van-Deudekom First answer was a question since when this is the case....
                                          Thomas Neumeyer
                                          I got some feedback from Ulefone, they stated it is the app with some incompatibility and I should use some other navigation app. 🙂
                                          • 4
                                          • 5
                                          TuonoPants
                                          TuonoPants
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Léon Hassing
                                          Léon Hassing
                                          Qualo
                                          Qualo
                                          guenniguenzelsen
                                          guenniguenzelsen
                                          Raul Arteaga
                                          Raul Arteaga
                                          Chalkster 0
                                          Chalkster 0
                                          rofowe
                                          rofowe
                                          OGRIII
                                          OGRIII
                                          Scottish Biker Abroad
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • scherm bevrirzing
                                          • Update 5.2.2 - Quick fix
                                            1.3k
                                          • Position Arrow
                                            Huibertus
                                            Huibertus
                                          • Carpuride W702 icm Carplay
                                            17.5k
