  4. Unable to calculate route
58 Posts 12 Posters 23.2k Views 5 Watching
  • Aiello antonino
    So if you are in a place where there is no connection, even if there are offline maps, do you risk not being able to follow an itinerary because there is no connection?
    Marinus van Deudekom MotoCon 2 Replies Last reply
      @Aiello-antonino If you end up in a place where there's no internet available for you you can turn to navigating off line. Make shure that the sync. your routes is enabled so you can start those route anywhere
      • Aiello antonino
        Everything you write was already done when what I wrote happened...
        • Aiello antonino
          I did some tests, I put it in airplane mode to recreate yesterday's situation and this is what comes out, 2 different behaviors if you change certain settings, but IMPOSSIBLE to be able to use the app if there is no signal
          With these settings
          THIS HAPPENS
          IF I CHANGE THE SETTINGS IN THE PHOTO BOX
          THIS HAPPENS
          So in these conditions, if I were to find myself somewhere (I'm planning a trip to Turkey and I don't know if I'll always have an internet connection) where there's no connection, I wouldn't be able to navigate with the app...
          Nick Carthew Peter Zehentreiter 2 Replies Last reply
            With these settings
            THIS HAPPENS
            THIS HAPPENS
            @Aiello-antonino said in Unable to calculate route:
            You need 3 things to navigate offline.
            All of the offline maps that you will use.
            All of the routes should be synced
            Offline navigation selected in the functional section of Navigation settings.
            With all these in place you can navigate entirely offline without any data connection.
            Aiello antonino 1 Reply Last reply
              With these settings
              THIS HAPPENS
              THIS HAPPENS
              @Aiello-antonino I tried to recreate your problems, but was unable to get the error you mentioned.
              Please try the following settings; they work perfectly for me.
              Im currently in Germany and the Route I opened is in Italy, without any problems.
              You can see from the screenshot that this mobile phone is completely offline, without a SIM card and without Wi-Fi.
              Screenshot_20260112-212429.MyRoute-app.png Screenshot_20260112-212443.MyRoute-app.png Screenshot_20260112-212453.MyRoute-app.png Screenshot_20260112-212515.MyRoute-app.png Screenshot_20260112-212529.MyRoute-app.png Screenshot_20260112-212548.MyRoute-app.png Screenshot_20260112-212613.MyRoute-app.png
              BMW R 1250 GS
              DMD-NOR7E 7"
              SPC Universal mount
              Motorola Edge 40 "offline"
              Sena SLR 3
              Sena 50 R
              Aiello antonino 2 Replies Last reply
                @Nick-Carthew As you can see from the photos I did everything you write, I forgot to upload the photo where you can see that I have all the maps offline, but here it is...!
                  @Peter-Zehentreiter I just checked your settings and they are the same as mine in the various tests, but it doesn't work for me…
                    @Peter-Zehentreiter can you please try this route?
                    https://www.myrouteapp.com/it/social/route/12491866?mode=share
                      Try to use Car modus instead of Motorcycle modus. See what's happens
                      • Aiello antonino
                        I don't understand...now it's working perfectly as I thought it should be...
                          @M.-Schrijver I didn't change anything and now it works...I don't know what to think...
                          • Aiello antonino
                            It's behaving very strangely. Although all the library's openings and paths are synced, it seems some aren't. The one I was trying earlier, which I linked to, started working, and I don't understand why. Now I'm trying to load others, but some work, and others don't... I just don't understand. I'll leave you with one that can't calculate the path at the moment. Could it be that I'm doing something wrong?
                            https://www.myrouteapp.com/it/social/route/558376?
                              @Aiello-antonino Both routes you set up for us to test, work for me.
                              However, for the route “Villach/panoramica delle vette,” there is a note that routes with off-road points only work online.
                              I briefly checked your waypoints, and some of them are not correct on the line.
                              When setting your waypoints, you should also make sure not to place them in the middle of an intersection or roundabout, but rather after them.
                              Screenshot_20260113-051215.MyRoute-app.png Screenshot_20260113-051254.MyRoute-app.png Screenshot_20260113-051317.MyRoute-app.png Screenshot_20260113-051536.MyRoute-app.png Screenshot_20260113-051613.MyRoute-app.png Screenshot_20260113-051635.MyRoute-app.png Screenshot_20260113-051650.MyRoute-app.png Screenshot_20260113-051705.MyRoute-app.png
                              BMW R 1250 GS
                              DMD-NOR7E 7"
                              SPC Universal mount
                              Sena SLR 3
                              Sena 50 R
                              • Aiello antonino
                                #21
                                Quando c’è stata la nota, dopo il percorso è partito anche se eri offline?
                                MotoCon Peter Zehentreiter 2 Replies Last reply
                                  This is very explicitly NOT the case.
                                  I will not repeat all that has been said by others, but solely what I said myself earlier:
                                  It is not phone signal that is the problem here. You are probably too far away from any road for the app to decide where to start. Once you are at your bike or car, it will most likely just work. I get this also sometimes when in my backyard testing things.
                                  I regularly are confronted with this issue, when testing things from the couch or in my backyard with a too large distance from any road. Lack of GPS signal could probably also cause this, or being on an uncharted road. In reality, where you start a route from within your car or near your bike that is actually ON a road, this will not happen.
                                    @Aiello-antonino, another thing to check is if you really have ALL segments of the needed maps offline. Sometimes it happens when a map update is interrupted, that some segments are skipped. So check your maps, and see if ALL needed segments have a checkmark.
                                      Yes the route started after the information!
                                      And again the phone is completly offline, no simcard, no wifi.
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Sena SLR 3
                                      Sena 50 R
                                        #25
                                        @Con-Hennekens As you say, however, it is not always like this, this is my route in Turkey, despite being very far, the 1º WP is igoumenitsa, the trip is calculated despite the ferry, and starting the navigation leaves... Yes, I don't understand what it can depend on, sometimes it works sometimes it doesn't... In the tests done I always had the maps downloaded on the device
                                        •  IMG_2806.jpeg elemento elenco
                                          #26
                                          @Aiello-antonino Like Con mentioned, download Maps again, it could be that it looks like the maps are downloaded but during an interruption while downloading something went wrong with a map.
                                          In addition, have you set all the way points on the route "panoramic del vette" accurat on the line and did you test the route again?
                                          BMW R 1250 GS
                                          DMD-NOR7E 7"
                                          SPC Universal mount
                                          Sena SLR 3
                                          Sena 50 R
                                          Òscar
                                          Òscar
                                          David Rudgley
                                          David Rudgley
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
                                          • Download club route folders
