  4. Unable to calculate route
58 Posts 12 Posters 23.2k Views 5 Watching
    @Aiello-antonino I tried to recreate your problems, but was unable to get the error you mentioned.
    Please try the following settings; they work perfectly for me.
    Im currently in Germany and the Route I opened is in Italy, without any problems.
    You can see from the screenshot that this mobile phone is completely offline, without a SIM card and without Wi-Fi.
    Screenshot_20260112-212429.MyRoute-app.png Screenshot_20260112-212443.MyRoute-app.png Screenshot_20260112-212453.MyRoute-app.png Screenshot_20260112-212515.MyRoute-app.png Screenshot_20260112-212529.MyRoute-app.png Screenshot_20260112-212548.MyRoute-app.png Screenshot_20260112-212613.MyRoute-app.png
    @Peter-Zehentreiter I just checked your settings and they are the same as mine in the various tests, but it doesn't work for me…
      @Peter-Zehentreiter can you please try this route?
      https://www.myrouteapp.com/it/social/route/12491866?mode=share
        Try to use Car modus instead of Motorcycle modus. See what's happens
        Aiello antonino 1 Reply Last reply
        • Aiello antonino
          I don't understand...now it's working perfectly as I thought it should be...
            @M.-Schrijver I didn't change anything and now it works...I don't know what to think...
            • Aiello antonino
              It's behaving very strangely. Although all the library's openings and paths are synced, it seems some aren't. The one I was trying earlier, which I linked to, started working, and I don't understand why. Now I'm trying to load others, but some work, and others don't... I just don't understand. I'll leave you with one that can't calculate the path at the moment. Could it be that I'm doing something wrong?
              https://www.myrouteapp.com/it/social/route/558376?
                @Aiello-antonino Both routes you set up for us to test, work for me.
                However, for the route “Villach/panoramica delle vette,” there is a note that routes with off-road points only work online.
                I briefly checked your waypoints, and some of them are not correct on the line.
                When setting your waypoints, you should also make sure not to place them in the middle of an intersection or roundabout, but rather after them.
                Screenshot_20260113-051215.MyRoute-app.png Screenshot_20260113-051254.MyRoute-app.png Screenshot_20260113-051317.MyRoute-app.png Screenshot_20260113-051536.MyRoute-app.png Screenshot_20260113-051613.MyRoute-app.png Screenshot_20260113-051635.MyRoute-app.png Screenshot_20260113-051650.MyRoute-app.png Screenshot_20260113-051705.MyRoute-app.png
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                • Aiello antonino
                  #21
                  Quando c’è stata la nota, dopo il percorso è partito anche se eri offline?
                  MotoCon Peter Zehentreiter 2 Replies Last reply
                    So if you are in a place where there is no connection, even if there are offline maps, do you risk not being able to follow an itinerary because there is no connection?
                    @Aiello-antonino said in Unable to calculate route:
                    This is very explicitly NOT the case.
                    I will not repeat all that has been said by others, but solely what I said myself earlier:
                    It is not phone signal that is the problem here. You are probably too far away from any road for the app to decide where to start. Once you are at your bike or car, it will most likely just work. I get this also sometimes when in my backyard testing things.
                    I regularly are confronted with this issue, when testing things from the couch or in my backyard with a too large distance from any road. Lack of GPS signal could probably also cause this, or being on an uncharted road. In reality, where you start a route from within your car or near your bike that is actually ON a road, this will not happen.
                      @Aiello-antonino, another thing to check is if you really have ALL segments of the needed maps offline. Sometimes it happens when a map update is interrupted, that some segments are skipped. So check your maps, and see if ALL needed segments have a checkmark.
                        Yes the route started after the information!
                        And again the phone is completly offline, no simcard, no wifi.
                        BMW R 1250 GS
                        DMD-NOR7E 7"
                        SPC Universal mount
                        Sena SLR 3
                        Sena 50 R
                          #25
                          @Con-Hennekens As you say, however, it is not always like this, this is my route in Turkey, despite being very far, the 1º WP is igoumenitsa, the trip is calculated despite the ferry, and starting the navigation leaves... Yes, I don't understand what it can depend on, sometimes it works sometimes it doesn't... In the tests done I always had the maps downloaded on the device
                          •  IMG_2806.jpeg elemento elenco
                            #26
                            @Aiello-antonino Like Con mentioned, download Maps again, it could be that it looks like the maps are downloaded but during an interruption while downloading something went wrong with a map.
                            In addition, have you set all the way points on the route "panoramic del vette" accurat on the line and did you test the route again?
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              #27
                              @Peter-Zehentreiter I haven't moved anything but it works...🤦🏼‍♂️
                                @Aiello-antonino Then everything's fine.
                                Be glad you can at least drive when you feel like it.
                                Here it's freezing cold, slippery as in an ice rink, and there are mountains of snow everywhere.
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                  @Peter-Zehentreiter Yes, I'm glad that everything is working... But I wonder why these problems... Also if it were to happen again and I'm in Turkey, for example, what and maybe I'll do this summer... It would be a big problem
                                    #30
                                    @Aiello-antonino A two-week data pass with 20 GB of data costs €29.95 >>>provider Telekom.
                                    Das würde ich machen wenn ich in ein Land Reise wo kein Roaming funktioniert, da eine Internet Verbindung auch anderweitig immer sinnvoll ist.
                                    Aber offline Navigation funktionierte bei mir bis dato immer!
                                    Oops......Here in english
                                    I would do that if I were traveling to a country where roaming doesn't work, as an internet connection is always useful in other ways too.
                                    But offline navigation has never failed so far!
                                    BMW R 1250 GS
                                    DMD-NOR7E 7"
                                    SPC Universal mount
                                    Sena SLR 3
                                    Sena 50 R
                                    • Aiello antonino
                                      #31
                                      Of course I'll get a data SIM, I mean if I find myself in an area where there's no connection whatsoever...
                                      • MotoCon
                                        You can count on it the internet connection NOT being the culprit.
                                        • Aiello antonino
                                          I don't know what to say... but I would like to understand exactly what the problem...it works now...not on Sunday...
                                          Òscar
                                          Òscar
                                          David Rudgley
                                          David Rudgley
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
                                          • Download club route folders
