  4. V5.0.0 : map remain on screen, hiding menu
26 Posts 9 Posters 8.2k Views 5 Watching
  • BMcG BMcG
    @lluis-Castells I tried to recreate the issue on my blackview by7100 & could not get it to happen
    as a matter of curiosity if you go into the android settings & turn off the "navigation" buttons, so remove the back/home button panel & enable gestures, what happens?
    lluis Castells
    lluis Castells
    lluis Castells
    Thanks for the suggestion. It does exactly the same thing.
    • Forest
      Forest
      Forest
      Menu button (top right of the screen) is not the only choice to get this effect.
      In the list at the bottom there are 7 possible choices but only one freezes the screen.
      See new video : https://youtube.com/shorts/JIXdgY1VJ-Y?feature=share
      If it can help.
      BMW R1200RT LC (K52) 2015
      Samsung S24+
      Android 16
        I am pretty sure this is has been resolved!
        Update 5.0.1 will provide the solution.
        We will test it now internally and roll out a beta as soon as possible.
        Also trying to resolve the "disappearing keyboard" issue
          Fixed in 5.0.1
          Expecting release early next week.
          In beta tomorrow probably.
          • Forest
            Forest
            Forest
            5.0.1 downloaded.
            Seem (I am careful) to solve the issue.
            I can finally access to the navigation.
            Many thanks to everyone involved in the fix.
            Samsung S24+
            Android 16
            • Forest Forest
              5.0.1 downloaded.
              @Forest great!
              Otherwise on the home screen tap the map layer icon > scroll all the way down > open the advanced settings.
              You can then change the map configuration to help you in solving any issues. This setting is only available on older Androids.
              • lluis Castells
                lluis Castells
                lluis Castells
                Problem solved on my BV9600 Pro with update 5.0.1. Thanks
                • Bouke Ent
                  501 433 gives on samsung active 2 and samsung S8 no solution. I think both android 9. on my main navigation phone ulefone x10 with android 11 it works ok. did use setting in map layers and virtual display and it seems to fix it for active 2
                  • Nick Dawson
                    Nick Dawson
                    Nick Dawson
                    Samsung Galaxy running Android 9.
                    I am experiencing similar problems.
                    I want to use the device as a spare for a planned trip to South America next month (for two months).
                    Loaded MyRouteApp, opens fine but when I go to Routes and Tracks, I get a map.
                    If I turn the screen sideways, I can see half of the menus which should be displayed below hence I think this is a display issue.
                    I cannot really get any further - I intended to download maps for S.America to the device and use these off-line but cannot even get to the settings menu.
                    My current phone running the latest software works fine but I don't want to risk this a my prime device for the trip (hence the old Samsung).
                    has compatibility with older Android versions been resolved?
                    thank you in anticipation
                    • Nick Dawson
                      Nick Dawson
                      Nick Dawson
                      I would upload a video but do not have enough privileges.
                      Essentially the map doesn't disappear so the menu options are not available.
                      This is using the navigation part of the software.
                      The MyRouteApp section to edit and create routes appears to work fine.
                      Hope the above helps.
                      Nick Dawson 1 Reply Last reply
                      • Nick Dawson Nick Dawson
                        Nick Dawson
                        Nick Dawson
                        Nick Dawson
                        I am running V 5.0.2
                          The latest version V5.0.2 is available and has fixed this issue...
                          iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
                          • Nick Dawson
                            Nick Dawson
                            Nick Dawson
                            That is the version I am running.
                            Could it have been fixed on 5.0.1 and the fix been missed on 5.0.2?
                            • Nick Dawson
                              Nick Dawson
                              Nick Dawson
                              The fix to go to the advanced map settings (for older android devices) works.
                              Thank you
                              Nick Dawson
                              Nick Dawson
                              Forest
                              Forest
                              lluis Castells
                              lluis Castells
                              • Startpunt wijzigen
                                Giancarlo e
                                Giancarlo e
                              • Route exporteren uit beta
                                Ed van Klink
                                Ed van Klink
                              • Vrienden toevoegen
