  4. V5.0.0 : map remain on screen, hiding menu
26 Posts 9 Posters 6.6k Views 5 Watching
    white.mouseundefined Offline
    My Android version is 12 and my phone is a Samsung S10e!
      We are indeed working on it 🙂
        @lluis-Castells I tried to recreate the issue on my blackview by7100 & could not get it to happen
        as a matter of curiosity if you go into the android settings & turn off the "navigation" buttons, so remove the back/home button panel & enable gestures, what happens?
        lluis Castellsundefined Offline
        lluis Castells
        Thanks for the suggestion. It does exactly the same thing.
        • Forestundefined Offline
          Forest
          Menu button (top right of the screen) is not the only choice to get this effect.
          In the list at the bottom there are 7 possible choices but only one freezes the screen.
          See new video : https://youtube.com/shorts/JIXdgY1VJ-Y?feature=share
          If it can help.
          BMW R1200RT LC (K52) 2015
          Samsung S24+
          Android 16
            I am pretty sure this is has been resolved!
            Update 5.0.1 will provide the solution.
            We will test it now internally and roll out a beta as soon as possible.
            Also trying to resolve the "disappearing keyboard" issue
              Fixed in 5.0.1
              Expecting release early next week.
              In beta tomorrow probably.
                Forest
                5.0.1 downloaded.
                Seem (I am careful) to solve the issue.
                I can finally access to the navigation.
                Many thanks to everyone involved in the fix.
                Samsung S24+
                Android 16
                • Forestundefined Forest
                  5.0.1 downloaded.
                  @Forest great!
                  Otherwise on the home screen tap the map layer icon > scroll all the way down > open the advanced settings.
                  You can then change the map configuration to help you in solving any issues. This setting is only available on older Androids.
                  • lluis Castellsundefined Offline
                    lluis Castells
                    Problem solved on my BV9600 Pro with update 5.0.1. Thanks
                    • Bouke Entundefined Offline
                      501 433 gives on samsung active 2 and samsung S8 no solution. I think both android 9. on my main navigation phone ulefone x10 with android 11 it works ok. did use setting in map layers and virtual display and it seems to fix it for active 2
                      • Nick Dawsonundefined Offline
                        Nick Dawson
                        Samsung Galaxy running Android 9.
                        I am experiencing similar problems.
                        I want to use the device as a spare for a planned trip to South America next month (for two months).
                        Loaded MyRouteApp, opens fine but when I go to Routes and Tracks, I get a map.
                        If I turn the screen sideways, I can see half of the menus which should be displayed below hence I think this is a display issue.
                        I cannot really get any further - I intended to download maps for S.America to the device and use these off-line but cannot even get to the settings menu.
                        My current phone running the latest software works fine but I don't want to risk this a my prime device for the trip (hence the old Samsung).
                        has compatibility with older Android versions been resolved?
                        thank you in anticipation
                          Nick Dawson
                          I would upload a video but do not have enough privileges.
                          Essentially the map doesn't disappear so the menu options are not available.
                          This is using the navigation part of the software.
                          The MyRouteApp section to edit and create routes appears to work fine.
                          Hope the above helps.
                          Nick Dawsonundefined 1 Reply Last reply
                          • Nick Dawsonundefined Nick Dawson
                            Nick Dawson
                            I am running V 5.0.2
                              The latest version V5.0.2 is available and has fixed this issue...
                                Nick Dawson
                                That is the version I am running.
                                Could it have been fixed on 5.0.1 and the fix been missed on 5.0.2?
                                  Nick Dawson
                                  The fix to go to the advanced map settings (for older android devices) works.
                                  Thank you
                                  Bouke Entundefined
                                  Nick Dawson
                                  Forestundefined
                                  Forest
                                  lluis Castells
                                    pehaundefined
                                    peha
                                    Stephen l. Weberundefined
                                    Stephen l. Weber
                                  • Veekeersinfo en omleiden
                                  • Last Route selection inconsistant
                                    RetiredWingManundefined
                                  • Updated beta! 5.2.1 (486)
                                    Leike Lodiersundefined
