  4. Route ignores obvious left turn
24 Posts 5 Posters 8.9k Views 3 Watching
  • twinfan Offline
    twinfan Offline
    twinfan
    OSM provides for problem reporting and map fixes. I made this note:
    alt text
    • twinfan twinfan
      alt text
      martin-phogel.de Offline
      martin-phogel.de
      @twinfan said in Route ignores obvious left turn:
      I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
      As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
      • twinfan Offline
        twinfan Offline
        twinfan
        @Martin-Wilcke said in Route ignores obvious left turn:
        From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
        • twinfan twinfan
          martin-phogel.de
          I have taken a closer look at this spot.
          The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
          I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
          • twinfan Offline
            twinfan Offline
            twinfan
            Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
            • twinfan Offline
              twinfan Offline
              twinfan
              I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
              ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
              • twinfan twinfan
                martin-phogel.de
                Here is an overview of all valid keys, their values, meaning and examples:
                https://wiki.openstreetmap.org/wiki/Map_features
                Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                https://forum.myrouteapp.com/post/58690
                • twinfan twinfan
                  martin-phogel.de
                  @twinfan
                  According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                  So, I recommend making the following changes (for both directions):
                  • Delete the lift gate barrier:
                  Add the "two-half barrier arm" attribute to the railway crossing:
                  • twinfan Offline
                    twinfan Offline
                    twinfan
                    Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                    • twinfan Offline
                      twinfan Offline
                      twinfan
                      I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                      Tom
                      • twinfan twinfan
                        martin-phogel.de
                        @twinfan
                        https://www.openstreetmap.org/note/4613925
                        Cool! 👍
                        • twinfan twinfan
                          Tom
                          martin-phogel.de
                          @twinfan
                          It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                          Brian McG 1 Reply Last reply
                          • twinfan Offline
                            twinfan Offline
                            twinfan
                            @Martin-Wilcke, thanks for checking and nice to see it worked!
                              @twinfan
                              Brian McG Offline
                              Brian McG Offline
                              @Martin-Wilcke the refresh cycle is not to do with OSM,
                              an edit to the OSM map can appear & be publicly available within a matter of hours.
                              As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                              it can lag by many many months as you have seen.
                              Here map data can take from a few days to several weeks to update
                              MRA update their Here data a lot more regularly, I think with every MRA update
                              • Brian McG Brian McG
                                martin-phogel.de
                                @Brian-McG said in Route ignores obvious left turn:
                                I know. With other apps, this change was visible within a few days.
                                That's what I mean by
                                Does MRA mirror the complete OSM map data on their own server?
                                  Brian McG Offline
                                  Brian McG Offline
                                  Apologies if I misinterpreted your previous post, terminology often does not translate well.
                                  e.g. for me the term "mirror" implies the same data is available in 2 or multiple locations at similar times.
                                  So I would not use "mirror" regarding MRA's OSM data as it is out of date for a considerable amount of time compared to the data available from OSM. It is why I used the term "snapshot".
                                  Sorry, I do not know where or how MRA host / store their data, I would just be guessing.
                                  Maybe someone else has the answer?
                                    martin-phogel.de
                                    @Brian-McG
                                    If we're being precise, we're not talking about the map data that is displayed, but rather about the data used for routing.
                                    I assumed that MRA uses a service (i.e. a REST API) that takes over the routing and thus also accesses a server on which the routing data is stored.
                                    If MRA stores the routing data on its server (yes, as a snapshot), then the developers must also have implemented a routing engine (presumably based on one of the available frameworks).
                                    Regardless of how it is technically implemented, the OSM data is obviously updated in long cycles. However, we should bear in mind that MRA focuses on HERE data, which is why the time lag in OSM data is not so important in my view.
                                    Mopetenpit
                                    Mopetenpit
                                    martin-phogel.de
                                    martin-phogel.de
                                    Next Stop
                                    Next Stop
                                    twinfan
                                    twinfan
                                    • Welke instelling
                                      1.1k
                                      Thomas Schäfer
                                      Thomas Schäfer
                                    • opslaan naar plantomtom
                                      chris 18
                                      chris 18
                                    • Seizoen sluitingen wegen
                                      PAT62
                                      PAT62
                                    • App loopt vast
                                    • Rejoining routes
                                      Sytze van der Laan
                                      Sytze van der Laan
