  4. Route ignores obvious left turn
24 Posts 5 Posters 7.1k Views 3 Watching
  • twinfanundefined Offline
    twinfan
    Greetings,
    I am a seasoned Garmin BaseCamp/Zumo XT user but just started with MRA using a Basic account. I did this in order to generate routes while on a trip using my iPad if for some reason my original plans change. This happened last fall when our route took us into areas with heavy forest fire smoke. We canceled our original trip plans and headed the other direction. I created new routes directly on the Zumo which was cumbersome to say the least. I like what I'm seeing so far with MRA and can envision moving to it exclusively as I get more experience with it.
    I created a day trip on my iPad and found a situation where MRA would not follow the obvious road. Even when I added shaping points (locations shown by red dots between shaping points 5 and 6) it created convoluted paths to get to them but not follow the simplest, most direct route. It doesn't seem likely this is a map choice problem, that is the free OSM vs. the subscription HERE map. Could it just be an error in the OSM map? My only avoidance is unpaved roads. BTW, this route loaded into the Zumo makes the correct turn as you would expect between the two shaping points.
    Tom
    alt text
    • Mopetenpitundefined Offline
      Mopetenpit
      This seems to be a problem with the OSM map. If I change the standard map from OSM to Here or Tomtom, the route works as expected. However, changing from OSM to Here/Tomtom is only possible in the Gold version.
      • Next Stopundefined Offline
        Next Stop
        As @Mopetenpit said, the Here maps seems to work fine, so presume it's an issue with OSM
        • Martin Wilckeundefined Online
          Martin Wilcke
          I don't think it's because of the OSM data.
          There are two potential limitations: A railway barrier and a U-turn restriction, but neither should prevent a left turn:
          Other planning programmes based on OSM allow this:
          This is probably due to the route engine (API) MRA uses.
            twinfan
            Thanks all for the quick replies. A map problem was my conclusion, too. I've made that left turn many times and there are no restrictions.
            Is there a means to report this problem? In the past I've done so with Garmin's maps.
            Tom
              twinfan
              Answered this last question by creating an OSM account and posting a note at that location.
              Martin Wilckeundefined 1 Reply Last reply
              • twinfanundefined twinfan
                Martin Wilcke
                @twinfan said in Route ignores obvious left turn:
                What exactly do you mean by that?
                  twinfan
                  OSM provides for problem reporting and map fixes. I made this note:
                  alt text
                    alt text
                    Martin Wilcke
                    I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
                    As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
                      twinfan
                      @Martin-Wilcke said in Route ignores obvious left turn:
                      From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
                        Martin Wilcke
                        I have taken a closer look at this spot.
                        The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
                        I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
                          twinfan
                          Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
                            twinfan
                            I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                            ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                              Martin Wilcke
                              wrote on last edited by Martin Wilcke
                              Here is an overview of all valid keys, their values, meaning and examples:
                              https://wiki.openstreetmap.org/wiki/Map_features
                              Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                              It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                              https://forum.myrouteapp.com/post/58690
                                Martin Wilcke
                                @twinfan
                                According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                                So, I recommend making the following changes (for both directions):
                                • Delete the lift gate barrier:
                                Add the "two-half barrier arm" attribute to the railway crossing:
                                  twinfan
                                  Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                                    twinfan
                                    I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                                    Tom
                                      Martin Wilcke
                                      @twinfan
                                      https://www.openstreetmap.org/note/4613925
                                      Cool! 👍
                                        Tom
                                        Martin Wilcke
                                        @twinfan
                                        It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                                          twinfan
                                          @Martin-Wilcke, thanks for checking and nice to see it worked!
                                          Martin Wilcke
                                          Mopetenpitundefined
                                          Mopetenpit
                                          Next Stopundefined
                                          Next Stop
                                          twinfanundefined
                                          twinfan
                                            Lluis Arasanzundefined
                                          • Here kaart
                                            CD130undefined
                                          • back to old situation with 2 apps
                                            Bouke Entundefined
                                          • Basecamp-Kurviger Overlay!
                                            CD130undefined
                                          • Voeg bij de routepunten de straatnaam en gemeente toe.
                                            Nomko Nomdenundefined
                                            Nomko Nomden
                                          • Waypoint met foto
                                            Robinekeundefined
                                            Robineke
                                          • Default POIs
