  4. Route ignores obvious left turn
24 Posts 5 Posters 8.1k Views 3 Watching
  • Mopetenpitundefined Online
    Mopetenpit
    This seems to be a problem with the OSM map. If I change the standard map from OSM to Here or Tomtom, the route works as expected. However, changing from OSM to Here/Tomtom is only possible in the Gold version.
    • Next Stopundefined Offline
      Next Stop
      As @Mopetenpit said, the Here maps seems to work fine, so presume it's an issue with OSM
      • martin-phogel.deundefined Offline
        martin-phogel.de
        I don't think it's because of the OSM data.
        There are two potential limitations: A railway barrier and a U-turn restriction, but neither should prevent a left turn:
        Other planning programmes based on OSM allow this:
        This is probably due to the route engine (API) MRA uses.
        • twinfanundefined Offline
          twinfan
          Thanks all for the quick replies. A map problem was my conclusion, too. I've made that left turn many times and there are no restrictions.
          Is there a means to report this problem? In the past I've done so with Garmin's maps.
          Tom
            twinfan
            Answered this last question by creating an OSM account and posting a note at that location.
            martin-phogel.deundefined 1 Reply Last reply
            • twinfanundefined twinfan
              martin-phogel.de
              @twinfan said in Route ignores obvious left turn:
              What exactly do you mean by that?
                twinfan
                OSM provides for problem reporting and map fixes. I made this note:
                alt text
                  alt text
                  martin-phogel.de
                  I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
                  As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
                    twinfan
                    @Martin-Wilcke said in Route ignores obvious left turn:
                    From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
                      martin-phogel.de
                      I have taken a closer look at this spot.
                      The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
                      I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
                        twinfan
                        Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
                          twinfan
                          I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                          ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                            martin-phogel.de
                            Here is an overview of all valid keys, their values, meaning and examples:
                            https://wiki.openstreetmap.org/wiki/Map_features
                            Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                            It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                            https://forum.myrouteapp.com/post/58690
                              martin-phogel.de
                              @twinfan
                              According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                              So, I recommend making the following changes (for both directions):
                              • Delete the lift gate barrier:
                              Add the "two-half barrier arm" attribute to the railway crossing:
                                twinfan
                                Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                                  twinfan
                                  I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                                  Tom
                                    martin-phogel.de
                                    @twinfan
                                    https://www.openstreetmap.org/note/4613925
                                    Cool! 👍
                                      Tom
                                      martin-phogel.de
                                      @twinfan
                                      It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                                        twinfan
                                        @Martin-Wilcke, thanks for checking and nice to see it worked!
                                        • martin-phogel.deundefined martin-phogel.de
                                          @twinfan
                                          Brian McGundefined Offline
                                          @Martin-Wilcke the refresh cycle is not to do with OSM,
                                          an edit to the OSM map can appear & be publicly available within a matter of hours.
                                          As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                                          it can lag by many many months as you have seen.
                                          Here map data can take from a few days to several weeks to update
                                          MRA update their Here data a lot more regularly, I think with every MRA update
                                          Mopetenpitundefined
                                          Mopetenpit
                                          martin-phogel.de
                                          Next Stopundefined
                                          Next Stop
                                          twinfanundefined
                                          twinfan
                                          • Expand
                                            Martin Woodfordundefined
                                            Martin Woodford
                                          • Tracklog fails
                                          • Moving the map
                                          • Altijd weer terug naar startpunt
                                          • Luftlinie zwischen zwei Punkten
                                            Tuxiundefined
                                            Tuxi
                                          • Change Favorites icons on map
                                            2.2k
                                          • Routepunt overslaan
                                            JP dundefined
                                            JP d
