  4. Route ignores obvious left turn
24 Posts 5 Posters 9.5k Views 3 Watching
  • twinfan
    twinfan
    twinfan
    Answered this last question by creating an OSM account and posting a note at that location.
    • twinfan twinfan
      martin-phogel.de
      martin-phogel.de
      martin-phogel.de
      @twinfan said in Route ignores obvious left turn:
      What exactly do you mean by that?
      • twinfan
        twinfan
        twinfan
        OSM provides for problem reporting and map fixes. I made this note:
        alt text
        • twinfan twinfan
          alt text
          martin-phogel.de
          martin-phogel.de
          martin-phogel.de
          I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
          As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
          • twinfan
            twinfan
            twinfan
            @Martin-Wilcke said in Route ignores obvious left turn:
            From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
            • twinfan twinfan
              martin-phogel.de
              martin-phogel.de
              martin-phogel.de
              I have taken a closer look at this spot.
              The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
              I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
              • twinfan
                twinfan
                twinfan
                Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
                • twinfan
                  twinfan
                  twinfan
                  I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                  ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                  • twinfan twinfan
                    martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    Here is an overview of all valid keys, their values, meaning and examples:
                    https://wiki.openstreetmap.org/wiki/Map_features
                    Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                    It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                    https://forum.myrouteapp.com/post/58690
                    • twinfan twinfan
                      martin-phogel.de
                      martin-phogel.de
                      martin-phogel.de
                      @twinfan
                      According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                      So, I recommend making the following changes (for both directions):
                      • Delete the lift gate barrier:
                      Add the "two-half barrier arm" attribute to the railway crossing:
                      • twinfan
                        twinfan
                        twinfan
                        Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                        • twinfan
                          twinfan
                          twinfan
                          I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                          Tom
                          • twinfan twinfan
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            @twinfan
                            https://www.openstreetmap.org/note/4613925
                            Cool! 👍
                            • twinfan twinfan
                              Tom
                              martin-phogel.de
                              martin-phogel.de
                              martin-phogel.de
                              @twinfan
                              It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                              Brian McG 1 Reply Last reply
                              • twinfan
                                twinfan
                                twinfan
                                @Martin-Wilcke, thanks for checking and nice to see it worked!
                                  @twinfan
                                  @Martin-Wilcke the refresh cycle is not to do with OSM,
                                  an edit to the OSM map can appear & be publicly available within a matter of hours.
                                  As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                                  it can lag by many many months as you have seen.
                                  Here map data can take from a few days to several weeks to update
                                  MRA update their Here data a lot more regularly, I think with every MRA update
                                  • Brian McG Brian McG
                                    martin-phogel.de
                                    martin-phogel.de
                                    martin-phogel.de
                                    @Brian-McG said in Route ignores obvious left turn:
                                    I know. With other apps, this change was visible within a few days.
                                    That's what I mean by
                                    Does MRA mirror the complete OSM map data on their own server?
                                      Apologies if I misinterpreted your previous post, terminology often does not translate well.
                                      e.g. for me the term "mirror" implies the same data is available in 2 or multiple locations at similar times.
                                      So I would not use "mirror" regarding MRA's OSM data as it is out of date for a considerable amount of time compared to the data available from OSM. It is why I used the term "snapshot".
                                      Sorry, I do not know where or how MRA host / store their data, I would just be guessing.
                                      Maybe someone else has the answer?
                                        martin-phogel.de
                                        martin-phogel.de
                                        martin-phogel.de
                                        @Brian-McG
                                        If we're being precise, we're not talking about the map data that is displayed, but rather about the data used for routing.
                                        I assumed that MRA uses a service (i.e. a REST API) that takes over the routing and thus also accesses a server on which the routing data is stored.
                                        If MRA stores the routing data on its server (yes, as a snapshot), then the developers must also have implemented a routing engine (presumably based on one of the available frameworks).
                                        Regardless of how it is technically implemented, the OSM data is obviously updated in long cycles. However, we should bear in mind that MRA focuses on HERE data, which is why the time lag in OSM data is not so important in my view.
                                        martin-phogel.de
                                        martin-phogel.de
                                        Next Stop
                                        Next Stop
                                        Mopetenpit
                                        Mopetenpit
                                        twinfan
                                        twinfan
                                        • Custom POI color and icons
                                        • File en omrijden
                                        • A11 Making the Algorithm More Visible – Overview and Planner File
                                        • File / Creation date
                                          Robineke
                                          Robineke
                                        • F003 POI Folder & group missing in the app
                                        • F005 Menu covered
                                          12.8k
