  4. Route ignores obvious left turn
24 Posts 5 Posters 8.9k Views 3 Watching
  • martin-phogel.de Offline
    martin-phogel.de
    I don't think it's because of the OSM data.
    There are two potential limitations: A railway barrier and a U-turn restriction, but neither should prevent a left turn:
    Other planning programmes based on OSM allow this:
    This is probably due to the route engine (API) MRA uses.
    • twinfan Offline
      twinfan Offline
      twinfan
      Thanks all for the quick replies. A map problem was my conclusion, too. I've made that left turn many times and there are no restrictions.
      Is there a means to report this problem? In the past I've done so with Garmin's maps.
      Tom
      • twinfan Offline
        twinfan Offline
        twinfan
        Answered this last question by creating an OSM account and posting a note at that location.
        • twinfan twinfan
          martin-phogel.de
          @twinfan said in Route ignores obvious left turn:
          What exactly do you mean by that?
          • twinfan Offline
            twinfan Offline
            twinfan
            OSM provides for problem reporting and map fixes. I made this note:
            alt text
            • twinfan twinfan
              alt text
              martin-phogel.de
              I know. But what exactly causes the problem, in your opinion, and what should be changed or corrected?
              As mentioned above, other planners based on OSM allow a left turn, so it's not an OSM Map issue. Do you disagree?
              • twinfan Offline
                twinfan Offline
                twinfan
                @Martin-Wilcke said in Route ignores obvious left turn:
                From what I read in the earlier posts the HERE and TomTom maps route correctly when selected. So does the Garmin City Navigator North America NT 2025.2 map on my Zumo XT. I think it is a problem with the OSM map but I have no idea how one would fix it.
                • twinfan twinfan
                  martin-phogel.de
                  I have taken a closer look at this spot.
                  The issue is probably caused by an extra barrier:lift_gate entry in addition to the railway:level_crossing. In my opinion, this is wrong.
                  I've added this to your comment, let's see if a mapper with local knowledge makes a change there.
                  • twinfan Offline
                    twinfan Offline
                    twinfan
                    Thank you, @Martin-Wilcke . I was contemplating learning more about OSM editing but it is very complex and I wouldn't want to make things worse.
                    • twinfan Offline
                      twinfan Offline
                      twinfan
                      I also thought it odd that there were signals shown in only three of the four corners but, then again, I don't understand the mapping "language."
                      ![alt text](e15f6f5e-9fe8-4731-a067-62de0d06c9ae-image.png image url)
                      • twinfan twinfan
                        martin-phogel.de
                        Here is an overview of all valid keys, their values, meaning and examples:
                        https://wiki.openstreetmap.org/wiki/Map_features
                        Search for railway:level_crossing and barrier:lift_gate; these are the key types related to this issue.
                        It is worth familiarising yourself with the different categories because there is an extra bonus: you can search for OSM POIs in a given area, export them as GPX and import them into MRA. This way, you can create your own POI libraries in MRA. We have discussed an example ("castles in the UK") here:
                        https://forum.myrouteapp.com/post/58690
                        • twinfan twinfan
                          martin-phogel.de
                          @twinfan
                          According to Google Street View, there is a railway crossing with two half barrier arms but no extra lift gate (this is the mapping error):
                          So, I recommend making the following changes (for both directions):
                          • Delete the lift gate barrier:
                          Add the "two-half barrier arm" attribute to the railway crossing:
                          • twinfan Offline
                            twinfan Offline
                            twinfan
                            Thank you, @Martin-Wilcke, I will give it a try. I use that intersection regularly, today in fact.
                            • twinfan Offline
                              twinfan Offline
                              twinfan
                              I made your recommended changes and checked the box asking for a review from an experience mapper, just in case. I also found another intersection about one mile earlier in the route that had a similar condition and revised it. This explains how MRA chose the route it did on my initial try. Thank you again for your guidance. I enjoyed learning about OSM!
                              Tom
                              • twinfan twinfan
                                martin-phogel.de
                                @twinfan
                                https://www.openstreetmap.org/note/4613925
                                Cool! 👍
                                • twinfan twinfan
                                  Tom
                                  martin-phogel.de
                                  @twinfan
                                  It took a loooooong time (probably due to the refresh cycle of the OSM server used by MRA), but it finally works now!
                                  Brian McG 1 Reply Last reply
                                  • twinfan Offline
                                    twinfan Offline
                                    twinfan
                                    @Martin-Wilcke, thanks for checking and nice to see it worked!
                                      @twinfan
                                      Brian McG Offline
                                      Brian McG Offline
                                      @Martin-Wilcke the refresh cycle is not to do with OSM,
                                      an edit to the OSM map can appear & be publicly available within a matter of hours.
                                      As I understand it, MRA take a snapshot of the OSM map data & the timing of the snapshot is quite irregular,
                                      it can lag by many many months as you have seen.
                                      Here map data can take from a few days to several weeks to update
                                      MRA update their Here data a lot more regularly, I think with every MRA update
                                      • Brian McG Brian McG
                                        martin-phogel.de
                                        @Brian-McG said in Route ignores obvious left turn:
                                        I know. With other apps, this change was visible within a few days.
                                        That's what I mean by
                                        Does MRA mirror the complete OSM map data on their own server?
                                          Brian McG Offline
                                          Brian McG Offline
                                          Apologies if I misinterpreted your previous post, terminology often does not translate well.
                                          e.g. for me the term "mirror" implies the same data is available in 2 or multiple locations at similar times.
                                          So I would not use "mirror" regarding MRA's OSM data as it is out of date for a considerable amount of time compared to the data available from OSM. It is why I used the term "snapshot".
                                          Sorry, I do not know where or how MRA host / store their data, I would just be guessing.
                                          Maybe someone else has the answer?
                                          Mopetenpit
                                          Mopetenpit
                                          martin-phogel.de
                                          martin-phogel.de
                                          Next Stop
                                          Next Stop
                                          twinfan
                                          twinfan
                                          • Welke instelling
                                            1.1k
                                          • The slow death of Zumo...
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Rejoining routes
                                          • Seizoen sluitingen wegen
                                            PAT62
                                            PAT62
                                            Thomas Schäfer
                                            Thomas Schäfer
                                            Terry Cox 0
                                            Terry Cox 0
                                            Karl-Heinz Schwendner
