  4. MyRoute app does not answer (both car and MC)
16 Posts 4 Posters 2.7k Views 2 Watching
    @Tore-Teigene
    It looks like there is a bug. They are examaning at the moment.
    The bug involves the connection with Android Auto. See other posts regarding the subject!!
    @white-mouse-on-the-motorbike in the beta version 346 the problem is solved
    • Tore Teigene
      Tore Teigene
      Tore Teigene
      For some strange reason it suddenly started on my MC, but it will not follow the route i have set. It shows the blue line to follow (so it knows where i am (gps = ok)) But when i start the ride nothing happens. if i stop and press the comass sign (bottom right on mobile) it repositions to new place (which is correct), but again when continuing the ride nothing happens.
      Tim Watson 1 Reply Last reply
      • Tore Teigene Tore Teigene
        Tim Watson
        Tim Watson
        Tim Watson
        @Tore-Teigene Hi. Assuming you're using Android Auto, when the navigation stops have you tried getting your phone out and clicking the Navigate button on the phone in MRA? That sometimes gets the navigation to start working again on the AA device. Or it crashes MRA completely. One of the two usually happens! 🙂
        Tore Teigene 1 Reply Last reply
        • Tim Watson Tim Watson
          Tore Teigene
          Tore Teigene
          Tore Teigene
          @Tim-Watson
          Jepp.Tried that also. No luck 🤨
            @Tim-Watson
            @Tore-Teigene are you a bêta tester. Because in the last update, 346 the problem was solved.
              Tore Teigene
              Tore Teigene
              Tore Teigene
              @Marinus-van-Deudekom
              At the bottom of the Account page it says 4.3.2 - 346
              Is that the beta version or the official ?
                @Tore-Teigene 346 is only in the beta version
                It seems strange that the problem still exists at your side because I myself and a lot of others voor it working since the update
                  Tore Teigene
                  Tore Teigene
                  Tore Teigene
                  Ok, you have any directions on how to go back to the "official" version ?
                    @Tore-Teigene If the problem still exists on your side I would put in a service ticket and get help from our Devs to solve your problem. If you want to leave the Beta program delete the app and start installing it again. My advice would be to keep the Beta version eventhough you might run into some trouble but that's why it's called a beta 🙂
                      Tore Teigene
                      Tore Teigene
                      Tore Teigene
                      Well, when the tool refuses to work it makes no sense to keep it installed.
                      I followed your suggestion buyt i still end up with the same version. There is no option to choose beta version or not from what i can see.
                      Please advice.
                        Please advice.
                        This soûl do the trick
                          Tore Teigene
                          Tore Teigene
                          Tore Teigene
                          Thanks Marinus. I'll give it some more tries before i do the uninstall option.
                          Marinus van Deudekom a white mouse on the motorbike 2 Replies Last reply
                            @Tore-Teigene That would be my idea😁
                              @Tore-Teigene
                              Jeg vet ikke om det hjelper, men prøv å tømme appens hurtigminne. Jeg hadde også noen merkelige problemer her om dagen, og de ble alle løst med det.
                              Ik weet niet of het helpt, maar probeer eens het cache geheugen van de app leeg te maken. IK had laatst ook wat vreemde problemen en die zijn daarmee allemaal opgelost.
                              Tore Teigene
                              Tore Teigene
                              Tim Watson
                              Tim Watson
                                Stephen Rowland
                                Stephen Rowland
                              • Statement on map spinning
                                1.6k
                              • Electric Car Travel Mode
