  4. MyRoute app does not answer (both car and MC)
16 Posts 4 Posters 2.7k Views 2 Watching
  • Tore Teigene
    Tore Teigene
    Tore Teigene
    MyRoute app does not respond (Close / Wait)
    A few weeks ago it worked perfect. Now Myroute does not answer when connecting to car or MC. Other apps work (like music player and phone).
    MC is a Honda African Twin Adventure Sport 2024 model so should be pretty updated. Same with car Skoda Enyaq 80x iV 2022 model. Phone is a Samsung Galaxy S23 Ultra / Android version 14
    I have of course uninstalled MyRoute and installed it again.
    I am a Gold Member with lifetime membership on both.
    So wtf has happened ? Anyone else seen the same ?
    • Tore Teigene Tore Teigene
      @Tore-Teigene
      It looks like there is a bug. They are examaning at the moment.
      The bug involves the connection with Android Auto. See other posts regarding the subject!!
        @Tore-Teigene
        @white-mouse-on-the-motorbike in the beta version 346 the problem is solved
        • Tore Teigene
          Tore Teigene
          Tore Teigene
          For some strange reason it suddenly started on my MC, but it will not follow the route i have set. It shows the blue line to follow (so it knows where i am (gps = ok)) But when i start the ride nothing happens. if i stop and press the comass sign (bottom right on mobile) it repositions to new place (which is correct), but again when continuing the ride nothing happens.
          Tim Watson 1 Reply Last reply
            Tim Watson
            Tim Watson
            Tim Watson
            @Tore-Teigene Hi. Assuming you're using Android Auto, when the navigation stops have you tried getting your phone out and clicking the Navigate button on the phone in MRA? That sometimes gets the navigation to start working again on the AA device. Or it crashes MRA completely. One of the two usually happens! 🙂
            Tore Teigene 1 Reply Last reply
            • Tim Watson Tim Watson
              Tore Teigene
              Tore Teigene
              Tore Teigene
              @Tim-Watson
              Jepp.Tried that also. No luck 🤨
                @Tim-Watson
                @Tore-Teigene are you a bêta tester. Because in the last update, 346 the problem was solved.
                  Tore Teigene
                  Tore Teigene
                  Tore Teigene
                  @Marinus-van-Deudekom
                  At the bottom of the Account page it says 4.3.2 - 346
                  Is that the beta version or the official ?
                    @Tore-Teigene 346 is only in the beta version
                    It seems strange that the problem still exists at your side because I myself and a lot of others voor it working since the update
                      Tore Teigene
                      Tore Teigene
                      Tore Teigene
                      Ok, you have any directions on how to go back to the "official" version ?
                        @Tore-Teigene If the problem still exists on your side I would put in a service ticket and get help from our Devs to solve your problem. If you want to leave the Beta program delete the app and start installing it again. My advice would be to keep the Beta version eventhough you might run into some trouble but that's why it's called a beta 🙂
                          Tore Teigene
                          Tore Teigene
                          Tore Teigene
                          Well, when the tool refuses to work it makes no sense to keep it installed.
                          I followed your suggestion buyt i still end up with the same version. There is no option to choose beta version or not from what i can see.
                          Please advice.
                            Please advice.
                            This soûl do the trick
                              Tore Teigene
                              Tore Teigene
                              Tore Teigene
                              Thanks Marinus. I'll give it some more tries before i do the uninstall option.
                              Marinus van Deudekom a white mouse on the motorbike 2 Replies Last reply
                                @Tore-Teigene That would be my idea😁
                                  @Tore-Teigene
                                  Jeg vet ikke om det hjelper, men prøv å tømme appens hurtigminne. Jeg hadde også noen merkelige problemer her om dagen, og de ble alle løst med det.
                                  Ik weet niet of het helpt, maar probeer eens het cache geheugen van de app leeg te maken. IK had laatst ook wat vreemde problemen en die zijn daarmee allemaal opgelost.
                                  Tore Teigene
                                  Tore Teigene
                                  Tim Watson
                                  Tim Watson
                                    Stephen Rowland
                                    Stephen Rowland
                                  • Statement on map spinning
                                    1.6k
                                  • Electric Car Travel Mode
