  4. Tablet kan geen route berekenen met offline kaarten.
38 Posts 8 Posters 15.1k Views 2 Watching
  • Leike Lodiers Leike Lodiers
    @RetiredWingMan same problem with all routes I'm a basic member with 14 days trail version
    Bekijk '01 Dagtoer Zuid Limburg 17mrt 2024 start - lunch' in MyRoute-app! https://www.myrouteapp.com/route/open/9074489
    RetiredWingMan Offline
    @Lei-Lodiers I took a look at your track but can't see any reason for the error. I converted it to a route and was able to load it fine. Sorry, I can't help here.
      Leike Lodiers Offline
      @RetiredWingMan the loading is no problem. It's the offline mode with no wifi or phone connection. And then try to navigate.
      https://photos.app.goo.gl/iXkd1L3RB1or1o1G9
      https://photos.app.goo.gl/F1KRzJFteQF5uZCH6
      Without any connection it keeps switching between these two options
        Nick Carthew Online
        Nick Carthew Online
        @Lei-Lodiers Are you using the Make offline available when you download?
          @Nick-Carthew yep
          • M. Schrijver Offline
            I've never used that option and for me works offline good.
            So what does it do?
            Leike Lodiers 2 Replies Last reply
              So what does it do?
              @M-Schrijver said in Tablet kan geen route berekenen met offline kaarten.:
              So what does it do?
              Can it be because i'm a 14 days premium trail user and not a gold or silver member?
                So what does it do?
                Nick Carthew Online
                Nick Carthew Online
                @Lei-Lodiers No, your 14 day free trial should give you full access to everything
                  So what does it do?
                  @M-Schrijver I tryed it on my phone but there's the same problem when I want to use the offline maps it won't navigate until I go on-line
                    You say you have downloaded the offline maps on your phone/tablet.
                    Please would you check if you also downloaded the map for the area where you planned the route on?
                    Because it seems it is a map problem not a license problem.
                      Ik heb de kaarten gedownload voor offline gebruik op mijn carpe iter v4b. Als ik nu een track of route download voor offline gebruik! En ik klik op navigeren vraagt mra om online te gaan omdat hij geen route kan berekenen met de offline kaarten... 🥺🥺
                      I downloaded the maps for offline use on my carpe iter v4b. Now when I download a track or route for offline use! And I click on navigate, MRA asks to go online because he cannot calculate a route with the offline maps...
                      @Lei-Lodiers put in a clip of the problem
                      https://photos.app.goo.gl/Mvb8DmodxYxp4ypv5
                        I see what you mean. But i cannot replicate it.
                        I am also on "Offline" navigation. But i can select my route from my online collection. That is one big difference. Even with WIFI of i can select a route from my online collectiom
                        When i selected a route from my "downloads" folder (for offline navigation) i can still navigate.
                        I also did a test where i disabled WIFI and Mobile data. In this case i was, just like you, diverted to the downloads folder. Here i select a route. Pressed on Navigate and the route did start on my phone
                          @M-Schrijver on my phone it's the same problem.. I don't now why it won't work.... Reset all deleted and re-installed the app bud stil the same problem acurs.. Even did the duck duck go uninstall I did read about.
                            Did you check if the offline maps really are downloaded?
                              @M-Schrijver where can i check this? The app says they are..
                                @Lei-Lodiers go to offline maps and scroll to the maps for NL and make sure there is a checkmark beside it.
                                • Bouke Ent Offline
                                  Bouke Ent Offline
                                  #26
                                  i did test it on my phone with 305 build, no internet offline maps for NL, DE and BEL. in setting use offline navigation. did download route and store it in downloads and started route as a route and not as a track. i have gold MRA and MRA Next.
                                  it works with me.
                                    @RetiredWingMan all maps are there the strange thing is it happens on my carpe iter tablet and on my samsun s21 ultra. So I think there's something wrong with my account...
                                      @Leike-Lodiers just bought the gold and next lifetime membership. Re installed the app and maps. Problem remains .
                                        @Nick-Carthew upgraded to gold lifetime still the same problem.
                                          jpgoderis Offline
                                          jpgoderis Offline
                                          jpgoderis
                                          @Leike-Lodiers ik heb hetzelfde probleem hier met mijn CI tab.
                                          Ik kan zelfs geen offline kaarten downloaden op de tab. Als ik een route wil navigeren lukt het ook niet zelfs verbonden via wifi met het net.
                                          Ik heb een ticket aangemaakt en gechat met Corjan en hij ging het probleem doorgeven.
                                          jpgoderis
                                          jpgoderis
                                          • Update 5.2.2 - Quick fix
                                            1.4k
                                          • Welke instelling
                                          • nieuwe Belgische gebruiker
                                            chris 18
                                            chris 18
                                            3.2k
                                          • instelling voor exact track rijden
                                          • Position Arrow
