  4. Tablet kan geen route berekenen met offline kaarten.
38 Posts 8 Posters 16.6k Views 2 Watching
  • Leike Lodiers
    Ik heb de kaarten gedownload voor offline gebruik op mijn carpe iter v4b. Als ik nu een track of route download voor offline gebruik! En ik klik op navigeren vraagt mra om online te gaan omdat hij geen route kan berekenen met de offline kaarten... 🥺🥺
    I downloaded the maps for offline use on my carpe iter v4b. Now when I download a track or route for offline use! And I click on navigate, MRA asks to go online because he cannot calculate a route with the offline maps...
    RetiredWingMan Leike Lodiers jpgoderis MotoCon 4 Replies Last reply
    • Leike Lodiers Leike Lodiers
      @Lei-Lodiers sorry I only know English. The most common cause of this error is:
      1. A downloaded map is missing for an area covering the route or your current location to the route.
      2. You did not start the route from the download folder.
        There may be other causes.
        @RetiredWingMan hi thxs for you're responce. I posted the text in english to.
        i did download all the maps.
        I downloaded the route from the download file
          Which profile did you use?
          Car, Motorcycle, Camper, ETC
          Try switching profiles
            @M-Schrijver motor
              TRy profile CAR
                TRy profile CAR
                @M-Schrijver tryed all of them. No succes
                  Profile Motor can have this behaviour but profile Car should always work.
                  I'm not sure why it doesn't work. I can only guess.
                  • Roadworks somewhere on your route?
                  • A conflict between your settings in the planner and navigation. Like unpaved road enabled in planner and disabled in navigation?
                    @Lei-Lodiers can you share a link to the route. Make sure it's public.
                      @RetiredWingMan same problem with all routes I'm a basic member with 14 days trail version
                      Bekijk '01 Dagtoer Zuid Limburg 17mrt 2024 start - lunch' in MyRoute-app! https://www.myrouteapp.com/route/open/9074489
                        @Lei-Lodiers I took a look at your track but can't see any reason for the error. I converted it to a route and was able to load it fine. Sorry, I can't help here.
                          @RetiredWingMan the loading is no problem. It's the offline mode with no wifi or phone connection. And then try to navigate.
                          https://photos.app.goo.gl/iXkd1L3RB1or1o1G9
                          https://photos.app.goo.gl/F1KRzJFteQF5uZCH6
                          Without any connection it keeps switching between these two options
                            @Lei-Lodiers Are you using the Make offline available when you download?
                              @Nick-Carthew yep
                                I've never used that option and for me works offline good.
                                So what does it do?
                                Leike Lodiers 2 Replies Last reply
                                  So what does it do?
                                  @M-Schrijver said in Tablet kan geen route berekenen met offline kaarten.:
                                  So what does it do?
                                  Can it be because i'm a 14 days premium trail user and not a gold or silver member?
                                    So what does it do?
                                    @Lei-Lodiers No, your 14 day free trial should give you full access to everything
                                      So what does it do?
                                      @M-Schrijver I tryed it on my phone but there's the same problem when I want to use the offline maps it won't navigate until I go on-line
                                        You say you have downloaded the offline maps on your phone/tablet.
                                        Please would you check if you also downloaded the map for the area where you planned the route on?
                                        Because it seems it is a map problem not a license problem.
                                          @Lei-Lodiers put in a clip of the problem
                                          https://photos.app.goo.gl/Mvb8DmodxYxp4ypv5
                                          jpgoderis
                                          jpgoderis
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
