  2. Routes & Tracks
  3. track between waypoints is not showing
28 Posts 6 Posters 11.2k Views
  • Andrew 15 Andrew 15
    @steve-lynch Well aren't I embarrassed!
    that was the issue all along.
    i cannot believe it was that, im so stupid.
    Thank you all for your patience and taking the time to talk me through it. it was really stressing me out 馃う
    Steve Lynch
    Steve Lynch
    Steve Lynch
    @andrew-15
    No problem Andrew.
    Enjoy your trip.
    You don鈥檛 stop riding when you get old, you get old when you stop riding.
    • Nick Carthew
      @Andrew-15 We all learn from our mistakes. I bet you don鈥檛 make the same mistake again 馃槄 Enjoy your tour 馃憤馃徏
      Matias Arn贸 Ibarz 0 1 Reply Last reply
        Matias Arn贸 Ibarz 0
        Matias Arn贸 Ibarz 0
        Matias Arn贸 Ibarz 0
        @nick-carthew
        A mi, me pasa exactamente lo mismo, y tengo el % de transparencia al 20%.....
        Alguien puede ayudarme.??
        Gracias.
        • Matias Arn贸 Ibarz 0 Matias Arn贸 Ibarz 0
          @nick-carthew
          Gracias.
          @matias-arn贸-ibarz-0 said in track between waypoints is not showing:
          Gracias.
          Please post a link to your route.
          Don't forget to set the privacy setting to 'public'.
          • TorqueRider TorqueRider
            Gracias.
            Matias Arn贸 Ibarz 0
            Matias Arn贸 Ibarz 0
            Matias Arn贸 Ibarz 0
            @jack-van-tilburg
            https://www.myrouteapp.com/route/open/6163803
              @jack-van-tilburg
              #21
              I don't understand what's going on here.
              With OpenStreetMap (OSM) I don't see a route line.
              I see that with TomTom and Here map.
              This is food for a technician. Possibly an issue with OSM?
              Matias Arn贸 Ibarz 0 TorqueRider 2 Replies Last reply
                Matias Arn贸 Ibarz 0
                Matias Arn贸 Ibarz 0
                Matias Arn贸 Ibarz 0
                @jack-van-tilburg said in track between waypoints is not showing:
                With Opens Street Map (OSM) I don't see a route line.
                Es posible que sea un problema de servidor..... hasta ayer funcion贸 bien, pude hacer rutas, pero hoy al querer continuar ya no funcionaba.....
                Una soluci贸n, por favor....!!
                  Also when creating a new route I don't see a line when using OSM.
                  The calculation of the route also takes a very long time.
                  James Blythe 1 Reply Last reply
                    James Blythe
                    James Blythe
                    James Blythe
                    @jack-van-tilburg
                    Yes, having problems too. No track line showing. Transparency NOT set to 100%.
                    These are routes that previously displayed fine. Running slow too.
                    • Nick Carthew
                      I have reported the problem with the OpenStreetMap to the developers.
                      • Nick Carthew
                        The OpenStreetMap will be operational again shortly.
                          Steve Lynch
                          Steve Lynch
                          Steve Lynch
                          OSM is now showing the route line for me.
                          • Steve Lynch Steve Lynch
                            Matias Arn贸 Ibarz 0
                            Matias Arn贸 Ibarz 0
                            Matias Arn贸 Ibarz 0
                            @steve-lynch said in track between waypoints is not showing:
                            Si.... ya funciona...
                            Gracias.
                            With your input, this post could be even better 馃挆
                            Matias Arn贸 Ibarz 0
                            Matias Arn贸 Ibarz 0
                            Steve Lynch
                            Steve Lynch
                            James Blythe
                            James Blythe
                            Andrew 15
                            Andrew 15
                            • Hide warnings on the map
                              Vincible
                              Vincible
                            • Map Layers
                              Martin White
                              Martin White
                              Michael 2v
                              Michael 2v
                            • Bollard trouble
                            • Library: Folders at the Top of the Menu
