  3. Delete waypoints
Delete waypoints
17 Posts 8 Posters 4.5k Views 2 Watching
  • steve 2k
    steve 2k
    steve 2k
    Hi Guys,
    I am planning a route but want to delete the waypoints apart from the start and finish.
    How do I do this without the route changing and sticking to my planned route?
    TA Steve
    Herko ter Horst Dolomiti 2 Replies Last reply
    • steve 2k steve 2k
      Hi Guys,
      TA Steve
      @steve-2k You can't, waypoints are what make a route go the way it goes (unless the waypoints happen to be only on the fastest route). Why do you want to do this?
      steve 2k 1 Reply Last reply
        steve 2k
        steve 2k
        steve 2k
        @herko-ter-horst
        I had problems awhile ago when I missed a waypoint and the Nav kept sending me back to it rather than carrying onto the next waypoint?
        TA S
        • steve 2k steve 2k
          @herko-ter-horst
          TA S
          @steve-2k What nav system or app are you using?
          In any case: the best you can do is make sure your waypoints are regular "shaping" points, not "via" points (indicated by a hand-symbol in MyRoute-app_.
          The MRA Navigation app will automatically skip "shaping" points if you miss them. It will try to keep sending you to Via-points. The same goes for Garmin nav systems.
          In some nav systems, you'll need to manually skip the point if you miss it and don't want to visit it anymore.
          As I said, waypoints are what make a route go where you want it to go, so it's not possible to delete waypoints and still expect the route to go where you want it (unless that also happens to be the fastest route, in which case the waypoint doesn't add anything).
          steve 2k Stefan Hummelink 2 Replies Last reply
            steve 2k
            steve 2k
            steve 2k
            @herko-ter-horst Thanks for the info. I have a better understanding of how it works now. How do I change it to shaping points rather than waypoints?
            • steve 2k steve 2k
              @steve-2k MyRoute app uses shaping points by default (except for the first and last point in a route), so unless you changed a waypoint to a "via" point already, you don't need to do anything. A "via" point is indicated by a "hand" shape, instead of the regular inverted droplet shape for shaping points. You can use the waypoint menu that pops up when you select a waypoint to switch between the two states. See this support article for more information about that.
              Note that it completely depends on the nav system or app how these different types of points are treated.
              The MRA Navigation app and most recent Garmin devices have support for them, but TomTom does not. For TomTom and most other systems/apps, you're probably better off using a "track" instead of a "route" with waypoints. Such a track is contained in the GPX-files MyRoute-app produces.
              More information about exporting your route to various navigation systems can be found here.
                @herko-ter-horst said in Delete waypoints:
                One small nuance: the user shall enable this option in the settings! Default this option is set to off I believe.
                  steve 2k
                  steve 2k
                  steve 2k
                  @stefanhummelink Not sure what you mean? I have a Garmin Zumo XT if that helps?
                  • steve 2k steve 2k
                    @steve-2k What he means is that the MRA Navigation app (which is a separate app) only automatically skips shaping points if you turn that on. If you're using a Garmin device for navigation, that doesn't apply to you.
                    According to the information I found here, the should be a button on the display of your Garmin Zumo XT to skip waypoints (regardless of whether they are "via" points or "shaping" points). And apparently, it should automatically skip any waypoints you miss if you turn route recalculation off on the device.
                    Stefan Hummelink steve 2k 2 Replies Last reply
                      I didn't want to cause any confusion haha. My comment concerns MRA Navigation only, just as @Herko-ter-Horst writes.
                        steve 2k
                        steve 2k
                        steve 2k
                        @herko-ter-horst Thanks for the input
                        • steve 2k steve 2k
                          @steve-2k Another thing to check to ensure that you are not directed back to a route point is to make sure that ALL route points are positioned accurately on the route line and away from junctions, roundabouts and viaducts. This is to allow for any discrepancies in satellite signal accuracy. To check each route point, fully zoom in to the first route point by using the magnifying glass and adjust if needed, then use the right arrow to move to the next. Do this for all route points. It’s quick and easy to do, I can check and adjust 50 route points in one minute. 8A8B4056-2445-4CEB-BA79-3D203F28E023.jpeg
                          • steve 2k steve 2k
                            Hi Guys,
                            TA Steve
                            Dolomiti
                            Dolomiti
                            Dolomiti
                            @steve-2k export as track, load back in as track πŸ˜‰
                            Dave J 0 Madden Jorge 0 2 Replies Last reply
                            • Dolomiti Dolomiti
                              @steve-2k I agree with @Dolomiti in that I think what you are wanting to see is the track and not the route. Serge at MRA has done some great webinars on this and I would suggest having a look. YouTube or have a look at MRA's Academy page. The Zumo XT will also allow you to show the track (in different colours) in the background as the device navigates the track. ☺
                              Ducati Multistrada V4 Rally
                              iPhone 15 Pro
                              CHIGEE AIO-6 LTE
                              • Karl Marx 0
                                Karl Marx 0
                                Karl Marx 0
                                @herko-ter-horst links shared you has worked for me especially this one https://support.myrouteapp.com/support/solutions/articles/12000075572-manual-waypoints-
                                Thanks for sharing.
                                Karl Marx 0 1 Reply Last reply
                                • Dolomiti Dolomiti
                                  Madden Jorge 0
                                  Madden Jorge 0
                                  Madden Jorge 0
                                  • Karl Marx 0 Karl Marx 0
                                    Thanks for sharing.
                                    Karl Marx 0
                                    Karl Marx 0
                                    Karl Marx 0
                                    @Karl-Marx-0 said in Delete waypoints:
                                    Thanks for sharing.
                                    Yes this worked.
                                    steve 2k
                                    steve 2k
                                    Karl Marx 0
                                    Karl Marx 0
                                    Madden Jorge 0
                                    Madden Jorge 0
                                    Dolomiti
                                    Dolomiti
                                    • Hello everyone
                                    • Route changed?
                                    • Beurs aanbieding
                                    • Hoe lang moet je abo hebbes voor toegang??
                                    • Hello from Thailand
                                    • How to plan correctly
                                      Christian Feurstein
                                      Christian Feurstein
                                    • Wissel Here-TomTom
