  3. Delete waypoints
Delete waypoints
17 Posts 8 Posters 4.9k Views 2 Watching
    @herko-ter-horst said in Delete waypoints:
    The MRA Navigation app will automatically skip "shaping" points if you miss them. It will try to keep sending you to Via-points. The same goes for Garmin nav systems.
    One small nuance: the user shall enable this option in the settings! Default this option is set to off I believe.
    steve 2k
    steve 2k
    steve 2k
    @stefanhummelink Not sure what you mean? I have a Garmin Zumo XT if that helps?
    • steve 2k steve 2k
      @steve-2k What he means is that the MRA Navigation app (which is a separate app) only automatically skips shaping points if you turn that on. If you're using a Garmin device for navigation, that doesn't apply to you.
      According to the information I found here, the should be a button on the display of your Garmin Zumo XT to skip waypoints (regardless of whether they are "via" points or "shaping" points). And apparently, it should automatically skip any waypoints you miss if you turn route recalculation off on the device.
      Stefan Hummelink steve 2k 2 Replies Last reply
        I didn't want to cause any confusion haha. My comment concerns MRA Navigation only, just as @Herko-ter-Horst writes.
          steve 2k
          steve 2k
          steve 2k
          @herko-ter-horst Thanks for the input
          • steve 2k steve 2k
            @steve-2k Another thing to check to ensure that you are not directed back to a route point is to make sure that ALL route points are positioned accurately on the route line and away from junctions, roundabouts and viaducts. This is to allow for any discrepancies in satellite signal accuracy. To check each route point, fully zoom in to the first route point by using the magnifying glass and adjust if needed, then use the right arrow to move to the next. Do this for all route points. It’s quick and easy to do, I can check and adjust 50 route points in one minute. 8A8B4056-2445-4CEB-BA79-3D203F28E023.jpeg
            • steve 2k steve 2k
              Hi Guys,
              I am planning a route but want to delete the waypoints apart from the start and finish.
              How do I do this without the route changing and sticking to my planned route?
              TA Steve
              Dolomiti
              Dolomiti
              Dolomiti
              @steve-2k export as track, load back in as track 😉
              Dave J 0 Madden Jorge 0 2 Replies Last reply
              • Dolomiti Dolomiti
                @steve-2k I agree with @Dolomiti in that I think what you are wanting to see is the track and not the route. Serge at MRA has done some great webinars on this and I would suggest having a look. YouTube or have a look at MRA's Academy page. The Zumo XT will also allow you to show the track (in different colours) in the background as the device navigates the track. ☺
                Ducati Multistrada V4 Rally
                iPhone 18 Pro
                CHIGEE AIO-6 LTE
                Google Pixel 6 Pro
                • Karl Marx 0
                  Karl Marx 0
                  Karl Marx 0
                  @herko-ter-horst links shared you has worked for me especially this one https://support.myrouteapp.com/support/solutions/articles/12000075572-manual-waypoints-
                  Thanks for sharing.
                  Karl Marx 0 1 Reply Last reply
                  • Dolomiti Dolomiti
                    Madden Jorge 0
                    Madden Jorge 0
                    Madden Jorge 0
                    • Karl Marx 0 Karl Marx 0
                      Thanks for sharing.
                      Karl Marx 0
                      Karl Marx 0
                      Karl Marx 0
                      @Karl-Marx-0 said in Delete waypoints:
                      Thanks for sharing.
                      Yes this worked.
                      steve 2k
                      steve 2k
                      Karl Marx 0
                      Karl Marx 0
                      Madden Jorge 0
                      Madden Jorge 0
                      Dolomiti
                      Dolomiti
                        TomOnTour
                        TomOnTour
                      • Newsletter optimisation
                      • route aanklikken in overzichtskaart
                      • Trekking tool: sun/shade
                      • How can I change colours in the route overview?
                        Kudee
                        Kudee
                      • Skip feature in the MRA Classic
                        TomOnTour
                        TomOnTour
