  4. Stability problems after 4.4.0 update
15 Posts 9 Posters 4.3k Views 4 Watching
  • Jeroen 1s
    Jeroen 1s
    Jeroen 1s
    After the upgrade that includes improvements for power consumption with the new SDK, this seems to come at the cost of stability.
    I am using an Iphone 11 (lOS 18.5) in combination with a Carplay system from Carpuride.
    Problems encountered:
    Getting frozen during navigation
    Remaining distance and time is no longer updated during navigation
    GPS location sometimes does not update properly and lags.
    • Nick Carthew
      To balance this topic, I too use an iPhone 11 running iOS 18.5 and I have no issues but I am not using CarPlay or a Carpuride, purely phone navigation.
      • Westerwald_Rider
        Westerwald_Rider
        Westerwald_Rider
        @Jeroen-1s : HI Jeroen, I got the same issue with android 13 and SAMSUNG S20 FE, Carpuride W903.
        I got a freeze during the first time with carplay. I restartet my Smartphone, the carpuride and it runs.
        It hangs up, when motors stops at signal light and you start the engine. I think it hangs at CARPLAY to transfer the display. Because the smartphone voice will direct you. So far you can hear it. In my case the voice was very quiet. But it works, when you set volume strengt in the MRA app. And don't touch the volume buttons on your steering wheel. If you restart carplay for a short time and resume to navigation it runs. Please bag my pardon, my experience is very young and fresh. I will check these out during my holiday trip.
        I tried it first for short navigation targets in Areas I know where I am. So I am able to check out the app. I used it in my car and later with my Bike.
        Issues:
        Hang up when you start your engine at signal light.
        the volume is very low, see other thread.
        positive:
        I learned a lot of new corners in my home area.
        have a good ride
        best regards from Westerwald
          @Nick-Carthew this issues are occurring only on CarPlay and AA.
          I tried as well with my iPhone 13 and AA on my car and got frozen almost every time I tried to use it. Luckily I managed to downgrade the app on my Android to 4.3.9, and I will use it as is.
          Adrian
          • Larry Greenfield
            Larry Greenfield
            Larry Greenfield
            I’m having exactly the same problem with iPhone 11 and Carpuride 702B so it’s not just you. Position freezes on both the phone and the CarPlay. Resetting the route updates the location but it still doesn’t move.
            But does not seem to be 200% reproducible yet.
            • Jeroen 1s
              Jeroen 1s
              Jeroen 1s
              Over the past two days, I embarked on a lengthy tour of nearly 1,000 km. It was a great opportunity to test the Myroute app again thoroughly. Unfortunately, halfway through the first day of the tour, I had to load my GPX files into TomTom Go due to many instability issues with Myroute.
              • In the first few hours, the phone became very hot and slow, maps were no longer updated and navigation seemed to stop working.
              • After a full reset of the device, it worked fine again for a while. However, after a while, the device started recalculating and got stuck again. The distance travelled was no longer updated and the directions were no longer accurate.
              This was the point at which I finally decided to go back to TomTom Go. Myroute App is a brilliant product in terms of functionality because everything is in one ecosystem. However, stability during navigation is obviously the most important thing for me and many other drivers. You can see that TomTom has been fully developed and no longer contains any bugs, which means that, in my opinion, TomTom Go is still the best. When MyRoute is as stable as TomTom, I will be the first to switch back, but I fear that this will take some time. A lifetime subscription is still a bridge too far for me at the moment 😉
              • Jeroen 1s Jeroen 1s
                @Jeroen-1s said in Stability problems after 4.4.0 update:
                Since big steps have been set concerning the power drain, phones getting so hot they don't function normally anymore are largely a thing of the past. It would be good at such a time to make a screenshot of the battery usage, to be able to see which app is drawing the current. It could as well be a system app or process generating this, while you blame the MRA app. I know it is easy to think the MRA app is the culprit because that is what you are using at that moment, and it is not impossible of course, but it would be good to see proof about that, and a support ticket so they can perhaps do something about it.
                -1
                  @Con-Hennekens said in Stability problems after 4.4.0 update:
                  Sorry to say this, but I agree with @Jeroen-1s ... I used TomTom Go last year for a Balkan Tour trip, and worked perfectly without any issues, so please stop pretending that MRA is perfect, meanwhile all these users are complaining about stability issues! I bought the app and planner (GOLD member) and I cannot use it without a downgrade to the previous version ....
                  I understand that there is no fix for now, even Corjan admitted this, so please stop praising MRA when someone has issues with the app !
                  Adrian
                  MotoCon Manzo91 2 Replies Last reply
                  • Adrian Avram Adrian Avram
                    @Adrian-Avram, I am not pretending that MRA is perfect, but if you want to solve anything, you need to look at other possible culprits too. There are many...
                      Manzo91
                      Manzo91
                      Manzo91
                      @Adrian-Avram same situation .. i hope next update resolve all the issues.
                        In my case, its MRA. This has already been decided, and now I am waiting for the next update, maybe it will fix things ...
                        Adrian
                        • Tom Grzelinski
                          Tom Grzelinski
                          Tom Grzelinski
                          @Corjan-Meijerink - Hi Corjan, I will soon start another 3000 mile journey through Europe with MRA as my main navigation... and I was going to use it through CarPlay this time. Will there be an update to solve these reported problems before mid-September? If not, I'll use it on my phone as I have in previous years.
                          @Nick-Carthew Hi Nick, have you had any problems at all running 4.4.0 just on the iPhone?
                          Cheers,
                          Tom
                          Porsche 911 and VW Transporter T6.1 running CarPlay.
                          iPhone 17 Pro running Waze and MRA.
                          MRA Routeplanner on web via Mac
                          • EMW-motorridders
                            EMW-motorridders
                            EMW-motorridders
                            wrote on last edited by EMW-motorridders
                            Any device that you use on the road and perform calculations consumes quite a bit of electricity which warms up the battery. I always make sure that these devices are on a motorcycle in the wind so they can cool down. It is also best to turn off all other applications to avoid heating up the battery such as Waze, Google maps, ...or other route planners.
                            And then it works perfectly.
                            You can also take aluminum cooling fins from an old music amplifier and stick them to the back of your iPhone. There are heat spreading tapes for that that stick on both sides. That is often used to transfer heat from NVMe M.2 or similar type SSD cards to the cooling fin.
                            These are just suggestions, up to you to work it out. Best yet is to buy a used refurbished iPhone 12,13,14 ..... It works wonderfully just as well.
                            • Tom Grzelinski Tom Grzelinski
                              Cheers,
                              Tom
                              @Tom-Grzelinski said in Stability problems after 4.4.0 update:
                              Zero problems running 4.4.0 on my iPhone 11 nor are there any problems on my wife’s iPhone SE.
                              All of our navigation is done offline.
                              Tom Grzelinski 1 Reply Last reply
                                Tom Grzelinski
                                Tom Grzelinski
                                Tom Grzelinski
                                @Nick-Carthew Thanks, I think I'll use MRA online to start with, but if I have problems I'll switch to offline (I have already downloaded the maps) and use Waze on the head unit (I'm in a car) for traffic updates. Cheers 👍
                                Tom Grzelinski
                                Tom Grzelinski
                                Larry Greenfield
                                Larry Greenfield
                                EMW-motorridders
                                EMW-motorridders
                                Jeroen 1s
                                Jeroen 1s
                                Westerwald_Rider
                                Westerwald_Rider
                                Manzo91
                                Manzo91
                                • Startpunt wijzigen
                                  Ad V
                                  Ad V
                                  Ed van Klink
                                  Ed van Klink
                                • Vrienden toevoegen
