  4. Carpuride 702BS
Carpuride 702BS
14 Posts 9 Posters 5.8k Views 4 Watching
  • Neil Hinkins
    Neil Hinkins
    Neil Hinkins
    Has anyone tried the Carpuride 701BS with MRA on a BMW gs
    Im trying to find out what the funtions are as in can you scroll the map in and out and clear down way points with the multi funtion wheel.
    Brian Sprott Marius Gross 2 Replies Last reply
    • Nick Carthew Nick Carthew moved this topic from General Discussion on
      @Neil-Hinkins Hi, there are lot of discussions about Carpuride in this forum, try to use the search function.
      Her a starter: https://www.youtube.com/watch?v=_HX4-t5BZlM
      Leslie Barnes 1 Reply Last reply
      • Neil Hinkins Neil Hinkins
        Brian Sprott
        Brian Sprott
        Brian Sprott
        @Neil-Hinkins I have it Neil. You can zoom in and out on Apple Carplay but NOT currently on Android. It works perfectly by scrolling through the various options. It doesnt just zoom by scrolling the wheel. You have to scroll to the "+" or "-" and select from there. It is well worth it if you have Carplay IMO
        Neil Hinkins 1 Reply Last reply
          Marius Gross
          Marius Gross
          Marius Gross
          @Neil-Hinkins: I can confirm what Brian said. I recently tested the 702 BS with MRA and found that the zoom "+" or "-" does not work on Android. This is exactly why I bought the Carpuride, but I was not aware that this function does not work. I hope that a solution will be found soon.
          Neil Hinkins bluetuz 2 Replies Last reply
          • Brian Sprott Brian Sprott
            Neil Hinkins
            Neil Hinkins
            Neil Hinkins
            @Brian-Sprott Thank you for your answer it's exactly what I wanted to know.
            • Marius Gross Marius Gross
              Neil Hinkins
              Neil Hinkins
              Neil Hinkins
              @Marius-Gross Thank you for your reply.
                bluetuz
                bluetuz
                bluetuz
                @Marius-Gross I can confirm too. It is posible to zoom in CarPlay but not in Android Auto. Tested in both OS today
                • Fridjof
                  Fridjof
                  Fridjof
                  is there a schedule for the fix available?
                  best regards
                    Leslie Barnes
                    Leslie Barnes
                    Leslie Barnes
                    @Jörgen using google maps i have verbale directions but in MRA not? any suggestions?
                    Leslie
                    Jörgen 1 Reply Last reply
                    • Leslie Barnes Leslie Barnes
                      Leslie
                      @Leslie-Barnes Oh, not directly. There are so many possibilities.
                      Are announcements switched off?
                      • Leslie Barnes
                        Leslie Barnes
                        Leslie Barnes
                        Zo ver als ik weet alles staat aan
                          Selecteer een TTS Engine en selecteer een stem. Probeer het dan nog eens.
                          Deze staan nu op "onbekend"
                          • M. Schrijver M. Schrijver
                            Leslie Barnes
                            Leslie Barnes
                            Leslie Barnes
                            @M-Schrijver Thank you, that did the trick everything is working great now.
                              @Leslie-Barnes
                              Please show the current Fofo for setting. Thank you 👋
                              Brian Sprott
                              Brian Sprott
                              Fridjof
                              Fridjof
                              bluetuz
                              bluetuz
                              Marius Gross
                              Marius Gross
                              Leslie Barnes
                              Leslie Barnes
                              Neil Hinkins
                              Neil Hinkins
                                Alderweireld Rudi 0
                                Alderweireld Rudi 0
                              • Weather as a service
                                Don Stauffer
                                Don Stauffer
                                Andy Smith 5
                                Andy Smith 5
