  4. Carpuride 702BS
Carpuride 702BS
14 Posts 9 Posters 4.1k Views 4 Watching
  • Jörgenundefined Offline
    @Neil-Hinkins Hi, there are lot of discussions about Carpuride in this forum, try to use the search function.
    Her a starter: https://www.youtube.com/watch?v=_HX4-t5BZlM
    Leslie Barnesundefined 1 Reply Last reply
    • Neil Hinkinsundefined Neil Hinkins
      Has anyone tried the Carpuride 701BS with MRA on a BMW gs
      Im trying to find out what the funtions are as in can you scroll the map in and out and clear down way points with the multi funtion wheel.
      Brian Sprottundefined Offline
      Brian Sprott
      @Neil-Hinkins I have it Neil. You can zoom in and out on Apple Carplay but NOT currently on Android. It works perfectly by scrolling through the various options. It doesnt just zoom by scrolling the wheel. You have to scroll to the "+" or "-" and select from there. It is well worth it if you have Carplay IMO
      Neil Hinkinsundefined 1 Reply Last reply
        Marius Grossundefined Offline
        Marius Gross
        @Neil-Hinkins: I can confirm what Brian said. I recently tested the 702 BS with MRA and found that the zoom "+" or "-" does not work on Android. This is exactly why I bought the Carpuride, but I was not aware that this function does not work. I hope that a solution will be found soon.
        Neil Hinkinsundefined bluetuzundefined 2 Replies Last reply
        • Brian Sprottundefined Brian Sprott
          Neil Hinkinsundefined Offline
          Neil Hinkins
          @Brian-Sprott Thank you for your answer it's exactly what I wanted to know.
          • Marius Grossundefined Marius Gross
            Neil Hinkins
            @Marius-Gross Thank you for your reply.
              bluetuzundefined Offline
              bluetuz
              @Marius-Gross I can confirm too. It is posible to zoom in CarPlay but not in Android Auto. Tested in both OS today
              • Fridjofundefined Offline
                Fridjof
                is there a schedule for the fix available?
                best regards
                • Jörgenundefined Jörgen
                  Leslie Barnesundefined Offline
                  Leslie Barnes
                  @Jörgen using google maps i have verbale directions but in MRA not? any suggestions?
                  Leslie
                  • Leslie Barnesundefined Leslie Barnes
                    Leslie
                    @Leslie-Barnes Oh, not directly. There are so many possibilities.
                    Are announcements switched off?
                    • Leslie Barnesundefined Offline
                      Leslie Barnes
                      Zo ver als ik weet alles staat aan
                        M. Schrijverundefined Offline
                        Selecteer een TTS Engine en selecteer een stem. Probeer het dan nog eens.
                        Deze staan nu op "onbekend"
                          Leslie Barnes
                          @M-Schrijver Thank you, that did the trick everything is working great now.
                            @Leslie-Barnes
                            Please show the current Fofo for setting. Thank you 👋
                            Fridjofundefined
                            Fridjof
                            bluetuzundefined
                            bluetuz
                            Brian Sprott
                            Marius Gross
                            Leslie Barnes
                            Neil Hinkins
                              richard 3vundefined
                              richard 3v
                            • Crashes na update
                              Jan Weerheimundefined
                              Jan Weerheim
                              Reinhard Punzundefined
                              Reinhard Punz
                              3.1k
                            • Duizend bochten
